front fog light indicator
Hi All
Just to double check.
Is there a front fog light indicator in the dash?
Never switch on the fogs for some time. and After installing the rear fogs, i only see the rear fog light indicator. Not sure if there was a front indicator in the first place.
thanks
thanks
mine is the Feb04 car. Ringer from this forum has a Aug03 car and his doesn't have the light. the manual also doesn't mention this. So it might be for the MM cars and later JDMs? Anyone with the early batch of rx8s can comment? thanks
don't be surprise if there's a different between old and new models
FYI you might check my old thread regarding numbers when shifting into D,incase nobody realise it
https://www.rx8club.com/showthread.p...8&page=1&pp=15
Originally Posted by rav969
hope this help ! One of them with the fog light turn on and one without.
btw, mine is a oct 2004 model
Was thinking that 03 builds came without this indicator, so hopefully someone with an early 04 or 03 JDM cars that came with fogs can confirm this.
after-market may not have as it is not connected to the main console board.
oso... if yours dun come with the foggy switch..then the connection to the meter will not be there.
if you go for OEM foggies, shd come with the right shift level with that "foggy switch".
i think i figured it out. My doesnt have the indicator as it is a JDM 03 build 6MT. The manual doesnt show the presence of the fog light on indicator. Checking with my neighbours 05JDM build 6MT, his manual shows the presence of the fog light indicator and his car has the said indicator.
Seems like there are quite a few running changes Mazda has made.
thanks for all the replies.
drebbrnator
Dec 27, 2018 07:02 PM
akagc
Aug 11, 2015 07:07 PM
SayDfuse
Aug 3, 2015 10:41 PM
