oil pump
Old Oct 10, 2006 | 10:36 PM
intrega's Avatar
oil pump
hi, anyone know where can i get the oil pump for the RX8?cos i think mine went kaput. tia
Old Oct 11, 2006 | 12:00 AM
coupe07's Avatar
SC 300HP!!
its a big job to get the oil pump out, and its not available in spore. Can i assume u r toking abt the oil pump the squirks the engine oil into the combustion chamber?
Old Oct 11, 2006 | 05:47 AM
intrega's Avatar
think thats the one...cos my 8 having very low oil pressure now as indicated by the defi meter & now got some knocking noise from the engine bay.
so do u know where can i order from overseas?thks
Old Oct 11, 2006 | 08:25 AM
CoupeM's Avatar
Night Rider
Have you checked your oil level? What about your oil temp? Is it very high? Low oil pressure could be due to a leak or lack of oil such that there is not enough oil circulating and cooling your engine sufficiently.
Old Oct 11, 2006 | 12:03 PM
coupe07's Avatar
SC 300HP!!
overseas??? u can try local parts dealer.. but expect to wait...
overseas wise, dun waste ur effort searching........ overseas dealers normally will not juz sell 1 spare part to u....
my suggestion is get workshop or parts dealer to find for u.... if its really knocking, then its serious problem for u...
Old Oct 12, 2006 | 12:53 AM
intrega's Avatar
[QUOTE=CoupeM]Have you checked your oil level? What about your oil temp? Is it very high? Low oil pressure could be due to a leak or lack of oil such that there is not enough oil circulating and cooling your engine sufficiently.[/QUOTE
at first i thought was low oil too but after changin oil still the same....oil temp is quite high, range from 100 to 115 degrees on normal driving...my mech already check the defi meter, no wrong there & no sign of oil leakage..
sigh..now also dunno wat to do...
Old Oct 12, 2006 | 12:57 AM
intrega's Avatar
hi bro, care to recommend a workshop to check for the knocking noise & source the parts for me?tia
Old Oct 12, 2006 | 02:08 AM
coupe07's Avatar
SC 300HP!!
bro, u ask me i sure say monster garage mah... we have did one oredi.... and the part was specially flown in...
Old Oct 12, 2006 | 05:27 AM
intrega's Avatar
ok thks, i'll visit monster garage soon...
Old Oct 12, 2006 | 01:20 PM
coupe07's Avatar
SC 300HP!!
let me noe, cos ur part, if urgent, have to fly in....
Old Oct 12, 2006 | 09:11 PM
intrega's Avatar
ok, will contact u.thks
Old Oct 13, 2006 | 08:17 AM
silverwolf's Avatar
THATS URGENT IF I EVER HEARD IT....
you need to get that taken car of. a low oil pressure in the 8 can cause a serious problem.
in a normal (piston engine) the lack of oil can over heat your engine and even create a minor hole in your piston (did to mine, after i had a huge anavoidable oil leak that was not my fault or lack of maintanence)
IN A ROTORY... MAN OH MAN. oil is injected into the combustion chamber, and the rotory produces more heat than a piston engine. do the math... no oil in the combustion chamber grindes your rotors and the fact that we produce mroe heat means no oil can extremely mess up your 8 and you will suffer the loss and have to pay or just give it up all together.
Old Oct 13, 2006 | 09:50 AM
intrega's Avatar
hi pal, that sounds serious...will get it done asap.thks
Old Oct 16, 2006 | 07:48 AM
silverwolf's Avatar
good luck
peace
RevMeHarder
Jun 1, 2026 02:30 PM
RXFEVER
Sep 11, 2016 02:51 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
