Mazsport Rotary tuner and service - Have developed ECU for RX-8's
Help installing Mazsport Air Separator Canister
Old Oct 23, 2008 | 06:17 PM
jskup1's Avatar
The Chief
I need some help installing this. The oem overflow tank only had two hose fittings and the small overflow hose. The mazsport tank has two hose fittings on the bottom and one more in the upper tank along with the overflow on the filler neck. Which fittings do the upper and lower hose on the oem tank match up to and what is the third hose fitting for?
Old Oct 23, 2008 | 06:48 PM
Brettus's Avatar
Boosted Kiwi
just guessing here - third hose is for turbo supply or return line ?????
Warrior777
Jun 24, 2019 04:47 PM
ableobject
Mar 22, 2016 11:37 PM
RXeckless
Aug 16, 2015 12:51 PM
akagc
Aug 11, 2015 07:07 PM
