Mazsport Rotary tuner and service - Have developed ECU for RX-8's
Why are Mazsport engine mounts better?
Old Mar 20, 2008 | 02:38 AM
sosonic's Avatar
Will the Mazsport engine mounts really last longer and possibly for the life of the car?
Mazsport has soft and hard grommets, which is recommended?
Will idle suffer with the stronger Mazsport mounts? Or does that depend on grommet type too?
Any plus versus minus issues with going with the Mazsport engine mounts versus OEM?
Old Mar 20, 2008 | 02:41 AM
Spinning Sushi's Avatar
I <3 Sushi
I'm not sure how much better the Mazsport engine mounts are but you'll feel alot more engine vibration/feel with harder grommets. Get the soft one if you want to maintain the stock-like ride quality. The engine will move more in the engine bay with the soft grommets though. So there are both up and down sides for either one.
Old Mar 20, 2008 | 04:38 PM
Crazy Boost's Avatar
Do these work with the Greddy turbo kit?
Old Mar 20, 2008 | 09:44 PM
MazsportScott's Avatar
Mazsport.net
[QUOTE=sosonic;2358851]
Q: Will the Mazsport engine mounts really last longer and possibly for the life of the car?
A: Yes they will last a VERY long time. We subject them to 350rwhp+ cars everyday!
Q: Mazsport has soft and hard grommets, which is recommended?
A: For most applications I would recommend the soft version.
Q: Will idle suffer with the stronger Mazsport mounts? Or does that depend on grommet type too?
A: Compared to the drastic vibrations caused by bad or weak factory mounts most customers report an improved idle quality.
Old Mar 20, 2008 | 09:45 PM
Mazsport.net
Yes they will, please specify your application when ordering.
Old Jul 1, 2008 | 03:41 AM
sammytcl's Avatar
should the greddy turbo application use the stock height or modified/higher/lower engine position mount?
vapor2
Nov 3, 2020 03:38 PM
Dolpho69
26
Jan 7, 2016 10:23 AM
Jazzmeson
Aug 30, 2015 02:23 AM
akagc
Aug 11, 2015 07:07 PM
harithac
Jul 25, 2015 04:21 PM
