So you think staggered tires/wheels are a great idea?
Old Jul 31, 2010 | 12:17 PM
  #126
FazdaRX_8's Avatar
cuz I think its a close out model
Old Aug 16, 2010 | 02:42 AM
  #127
GEOPAN's Avatar
Smile
8,5-9,5X19 ET35 225/40-245/35
Old Sep 19, 2010 | 11:09 PM
  #128
aftershock's Avatar
Got my staggered set a few weeks back, 20/35/245 front, rear 20"/30/275.
Old Sep 20, 2010 | 01:38 AM
  #129
FazdaRX_8's Avatar
I got them
Old Mar 1, 2011 | 07:03 PM
  #130
kingsina420's Avatar
TNC
whatsup guys i got work xt7's 18x9.5 +30 all around i dont know what would be the best tire size to run i was thinking bout doing 245/40/18 all around but is there a better combo for better performance and how much fender problems will i be running into
Old Mar 1, 2011 | 10:37 PM
  #131
monchie's Avatar
I HATE SPEEDBUMPS!
For me, staggered wheels and tires is for racing purposes.
Old Jul 14, 2011 | 06:07 PM
  #132
Roen's Avatar
Anyone try 265 all around on 9.5" wheels?
Old Jul 15, 2011 | 09:34 AM
  #133
lchaidez's Avatar
Caliente
I am riding on 18x10 with 275's all around.
I had 265's before, but i seem to enjoy these a bit more.
If car is lowered, expect to roll fenders (front and rear) and also chop or mold the wheel housing in the fenders.
Here is how the car currently sits, on Stance suspension with the fitment details mentioned above:
Last edited by lchaidez; Jul 15, 2011 at 09:40 AM. Reason: Added picture for reference.
Old Jul 15, 2011 | 04:41 PM
  #134
FazdaRX_8's Avatar
Offset?
Old Jul 16, 2011 | 07:22 PM
  #135
lchaidez's Avatar
Caliente
Originally Posted by fazdarx_8
offset?
+42
Old Dec 24, 2011 | 09:58 AM
  #136
Mr_AUTOBOT's Avatar
sideswipe#2
oh hello didnt see yall there.. just want to leave this pic to see what yall think of my 8..
19x9.5 +9 oz futura
Attached Thumbnails So you think staggered tires/wheels are a great idea?-406574_280524238661528_100001118626774_758703_213482126_n.jpg   So you think staggered tires/wheels are a great idea?-388160_280524871994798_100001118626774_758710_1329580716_n.jpg
Old Dec 24, 2011 | 11:21 AM
  #137
Yes, the taller the tire the more issues it will have. 10" and 285/30 is a good match, but you can also use up to +52mm offset @ 10" wide to get it stuffed in there well. Same issue with 19", more cost and less tire size options.
https://www.rx8club.com/showpost.php...postcount=6960
Old Jan 7, 2012 | 11:42 AM
  #138
Rei-teki's Avatar
I have 265/35 with 18x8.75 35+ in front with a 18x9.75 20+ in the rear. All of my fenders are rolled and it's lowered about an 1.5"
Old Jan 14, 2012 | 02:21 AM
  #139
JKianK's Avatar
Can i put 19x9 wheels all around
Offset: +45mm
Backspacing: 6.81"
Bolt Pattern: 5-114
Those are the specs on the wheels i want. would i be able to fit these with the right tires without modding the fenders. also what tire size should i get. I dont want to lose performance
Old Nov 17, 2013 | 06:41 PM
  #140
tofu_box's Avatar
it will fit,
I had previous a complete set of 19x9 +38 offset rims, had them wrapped in 245/35/R19 and lowered, did not encounter any issues.
If you dont want to lose performance, just make sure the rims weigh less then your original to compensate for the weight of the larger tires.
Old Nov 20, 2013 | 05:11 PM
  #141
traimbault's Avatar
great point!
Old Jul 11, 2015 | 01:45 PM
  #142
Rote8's Avatar
Whats is the largest diameter rears we can go with staggered on the rear?
4000 RPM at 80 Mph does not economize gas, and I can take off in 2nd gear as good or better than 1st gear....
Doesn't the RX8 pull speed from the front passenger wheel; so the rear diameter change would not affect my speedometer calibration?
Old Jul 22, 2015 | 05:01 PM
  #143
jasonrxeight's Avatar
Pretty sure it pulls speed from the transmission.
Old Jul 22, 2015 | 05:07 PM
  #144
I have had several sets of wheel and tire combos and my speedo is always with 1-2MPH of my GPS. I am staggered now, my rears are 19 x 9.5 +27 rear with a 255/35-19 tire and 19 x 8.5 +24 front with a 245/35-19 tire.
Old May 6, 2017 | 02:38 AM
  #145
jaimesix's Avatar
6 rotors....I want more!
After reading several posts let me say that claiming the RX8 as balanced the way it is and advising against stagering would imply the car is perfect the way it is factory and stock wheels and tires are the only way to top performance
We know that is not true Different demands for different rides (autocross, city /street performance, circle track, etc) and diferent combinations of tires and wheel widths render absolute terms like "stagered works not" fallacious
Sway bars can tune over any understeer so that wider wheels and tires on back can offer better cornering without understeering's detrimental effects
You might think bigger rear wheels-tires are giving you understeer ? Get a larger rear sway bar or decrease the size of the front one Plenty of room to work with
It can have detrimental effects if poorly implemented or perfect results if calibrated and tuned up properly
Old Aug 18, 2020 | 10:35 PM
  #146
Grendelizer's Avatar
pondering
I'm pondering running a staggered setup on my 04. 225/45 18 and 255/40 18s, only a 1.1 inch difference in width. Looking for a bit more rear grip to suit my personal driving style. Hoping that it will work like it did for my scatpack challenger. It had 245s all around, looked and handled like a fatboy on roller blades. 305s on the rear made a huge difference on it. When the fronts wear out, I'll be going to 275s on the front.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
TheRedRotor
Sep 12, 2015 07:42 AM
Juan Montenegro
Sep 10, 2015 06:28 PM
WingleBeast
Sep 9, 2015 10:10 AM
iwannarun
Sep 6, 2015 01:37 PM
