2004 Mazda Rx-8 Bulb Code List
Old Feb 20, 2007 | 04:53 PM
  #101
SecrtSqurl's Avatar
Jst wnt a relibl Turbo
I had bad luck replacing the fog lights with bubs from autoillumination. i had 3 fog lights burn out last year alone. Since switching to the Piaas, I havent had aproblem. it may be a coincidence, but it also may be a case of you get what you pay for
Old Feb 20, 2007 | 07:05 PM
  #102
BoosTED's Avatar
Originally Posted by Mafia
i was just curious as to which bulb most of you perfer for a close to xenon look for the park lights. Of course fom http://autolumination.com.. i was interested in the 6 LED super white or UV but unsure as to how it would look. Also ive heard their bulbs are not very reliable is this true?
Do a search for Velocity LED on eBay they hold up better than the autolumination bulbs.
Old Feb 21, 2007 | 10:34 PM
  #103
Mafia's Avatar
thanks for the info guys, currently i use nokya super whites for my fogs with no problems as of yet. i was just curious on autolum cause i saw alot of member using their products
Old Feb 22, 2007 | 12:00 AM
  #104
N rider89's Avatar
^NieL
autolum sucks kinda. ive been through way too many sets
Old Feb 23, 2007 | 08:00 AM
  #105
salituro64's Avatar
So where do you get good Hyper White bulbs?
Old Mar 10, 2007 | 11:59 PM
  #106
boanjangnararmine's Avatar
Toyo Kogyo => Mazda
From: Los Angeles - Arcadia - Monterey Park - La Jolla
for the vanity mirror lights i found dome light bulbs that are 8mm wide and 28 mm long... i was wondering if this would fit.. apparently the stock bulb is 6mm x 30 mm... can the somewhat fatter and and shorter bulb be shoved in and work?
Old Mar 17, 2007 | 03:50 PM
  #107
altspace's Avatar
Eccentric Shafting
Would someone please remove 9005 high beam bulb from the first post since it does not fit.
Old Mar 19, 2007 | 05:36 PM
  #108
Krasnog's Avatar
Official Reposter
Originally Posted by 4 years to Supercharge
I picked mine off of eBay. Couldn't beat the price.
Search for Xtreme white 194.
The set I have are conventional bulbs non-LED.
I'll take a few pictures tonight after it gets dark out and post them.
Pics? =)
Old Oct 20, 2007 | 04:25 PM
  #109
white311's Avatar
9K Smokin!
I installed LED's on all of my rear bulbs including the high brake light.....NOW I am getting a ABS and Slippery Warning light only when I turn my lights on...Anybody know what the deal is???????????
Old Oct 20, 2007 | 04:54 PM
  #110
Spinning Sushi's Avatar
I <3 Sushi
You probably need resistors on the bulbs.
Old Oct 20, 2007 | 05:49 PM
  #111
white311's Avatar
9K Smokin!
On all of them or just the turn signals?
Old Oct 20, 2007 | 05:50 PM
  #112
white311's Avatar
9K Smokin!
Do I need resistors on all of them or just the turn signals? Thanks in advance for the info!
Old Oct 20, 2007 | 06:44 PM
  #113
white311's Avatar
9K Smokin!
Problem solved....Returned the 3rd brake light bake to a standard bulb.....No more warnings.
Old Oct 20, 2007 | 06:53 PM
  #114
Chamberlin's Avatar
2005 Ti Gray RX-8 - SOLD
You need at least one resistor (or bulb) on at least one of the 3 rear lights.
You can put the LED back in the third brakelite, just go to Autozone and buy a ceramic resistor thing for LED lights and stick it on one of em.
Do a search on this, you will find other posts from me about this.
-C
p.s. and yes, you will need 4 resistors, one for each turn signal to make those work right.
Old Nov 14, 2007 | 07:12 PM
  #115
Beeotch's Avatar
i just bought sylvania h7 su (SilverStar ULTRA High Performance Halogen) they are for the larger lights in the headlight correct? the main lights. will they fit? if i had xenon headlights would these lights be brighter then the xenon? on autolumination.com which 194 bulbs and h11 bulbs shine the brightest in a superwhite/blue effect for my inner headlight lights an side markers and fog lights?
Old Nov 14, 2007 | 07:13 PM
  #116
Beeotch's Avatar
when i mean brightest i mean bright but not bright enough that i get pulled over.
Old Jan 15, 2008 | 07:50 AM
  #117
got 2 of the 194 HID White to try it out in my front parking light.
After about 2 months of use, 1 of them are about to die (keeps on flashing)
I got them from v-leds.com
hmm .... thinking to get PIAA. Cost 10 times the amount. but I guess you get what you paid for
Old Jan 27, 2008 | 02:17 PM
  #118
moete87's Avatar
Ohio State
What kind of LED's do you guys use in your clear corners? I have gone through 3 sets of LED's from RX8Strakes.com! I opened up my box to put in a new LED that was flickering in my right clear corner and the 1st bulb that I put in didnt even work, then the second bulb I used the color seems alittle off on the tiny LEDS that make up the bulb.
So I need some help..
Where can I get the best quality LED bulbs for my clear corners? Price isnt an issue because I just spent $60 on LEDs that I have to change every month or two.
Please help, this shouldnt be happening!
Can you guys post up some links to where I can quickly purchase the LED's..that would be great!
Jeff
Old Jan 27, 2008 | 02:32 PM
  #119
BigRed's Avatar
w8nkel
Vleds^ u can use 194s, or a bunch of different ones. i like the 194s though
  #120
BigRed's Avatar
w8nkel
btw its vleds.com
Old Jan 27, 2008 | 05:24 PM
  #121
takahashi's Avatar
You need somesort of resistor for some LED bulbs. You just cannot put a 194 into the signalling bulbs straight on. Some LED has in built resistors and they are specific for the signal bulb and they will be fine then.
Old Jan 27, 2008 | 11:50 PM
  #122
BoosTED's Avatar
I really like the high power flank LED bulbs.
It makes the side marker signal mod work better for those folks that can't see you signalling from the side.
Adding a resistor to each side should lengthen the life of your bulbs considerably.
Another thing that can make a difference is if you are not totally switched over to LED.
Old Mar 2, 2008 | 07:16 PM
  #123
Rote8's Avatar
Exclamation Can someone confirm this?
Is this correct?
I thought the 9005 and H9 bulbs worked in the high beams????????
Update:
According to Daniel Sterns lighting page H9 does not equal 9005
Danielsternlighting.com
Old Mar 2, 2008 | 08:12 PM
  #124
BoosTED's Avatar
H9 is the correct bulb for high beams.
Old Mar 12, 2008 | 08:48 AM
  #125
CnnmnSchnpps's Avatar
No means yes
Shameless plug cos I think my lights look hot
Aftermarket HIDs in H7, clear corners with:
1) Stock bulbs
2) Polarg Super-whites
3) Hoen LEDs
Sweet
