Rims that takes TPMS
Old Aug 3, 2006 | 11:04 AM
  #101
NotAPreppie's Avatar
What am I doing here?
My Mazda dealer just installed TPMS sensors in my new Racing Sparco D-Spec Stage 1 17x7 wheels when they mounted my a/s tires.
Old Aug 9, 2006 | 05:16 PM
  #102
MrBrAnNiN's Avatar
Cool
i personally like these
Old Aug 9, 2006 | 05:33 PM
  #103
I8U's Avatar
I8U
These work too: MB Motorsports Weapon
Old Aug 23, 2006 | 12:07 PM
  #104
OnRails's Avatar
Now I know for sure! Enkei RPF1. In particular the 18 X 9.5 with 45 offset.
Old Sep 10, 2006 | 04:01 AM
  #105
Mazdaspeed RX8 ver2's Avatar
Is it true that the Volks racing: SF Challenge is tmps compatible? ive heard from a few that they aren't. Also, if its true that the SF challege's are compatible, how about the Volks Racing GT-S? Any help would be appreciated, i just want to verify. Thanks!!
Old Sep 17, 2006 | 02:24 PM
  #106
DeLOCO's Avatar
DeLOCO
I was told by the manager at America's Tires, "New car specifications require TPMS. All reputable wheel manufacturers are now incorporating TPMS into their wheels. There are probably some wheels that were made prior to this change still being sold."
I have G-Games 99Bs (made by Ray's, who also makes Volks) and the stock TPMS was installed with the new wheels.
Old Sep 20, 2006 | 11:59 PM
  #107
does anyone know if any of the grams light rims especially the T57-RC or the 57F Pro take the tmps? The T57's are casting one peice while the Pro's are Forged 2 peice. How about the regular 57Pro that is casting 2 peice? Any info would help and sorry for all the questions
Old Oct 4, 2006 | 01:03 AM
  #108
Mikeluvs8's Avatar
do the tpms fit all motegi rims ?
Old Nov 1, 2006 | 01:00 PM
  #109
Umbra's Avatar
These take TPMS....
3 piece forged 19" OZ Rafaello's
Attached Thumbnails Rims that takes TPMS-dsc01246bsmall.jpg   Rims that takes TPMS-dsc01247small.jpg   Rims that takes TPMS-dsc01258small.jpg
Old Nov 30, 2006 | 11:34 PM
  #110
maskedferret's Avatar
Oooh, shiny!
Is TPMS absolutely required to have on the wheels for our car? Outside of the warning light, what effects does it have on the car by not having it? Does the warning light also incorporate a consistent beeping of any sort? I am looking to get winter tires/wheels, and really am not keen on spending the extra $250 or so for these things when I will probably just make it a ritual to check tire pressure regularly.
Old Jan 6, 2007 | 02:03 AM
  #111
Tanaka826's Avatar
anyone know if they work on FN01RC? im really thinking about getting some.
Old Jan 28, 2007 | 04:56 PM
  #112
gyeaboy's Avatar
TPMS question
Sup guys,
I'm thinking about buying some new Kazera KZ-A rims with Kumho ECSTA tires 225/40/18. They will be mounted and balanced already.
Is it easy to remove the TPMS from the stock rims/tires? I've never done this before. (Anyone got a link on how to remove them?)
Thanks.
Old Jan 31, 2007 | 08:55 PM
  #113
uncivilracer's Avatar
Turbo Racer
I am looking to buy ADR rims. Are those covered in this TPMS crap? Man I hope so. Getting a heck of a deal on them!
Old Feb 7, 2007 | 01:07 PM
  #114
Tanaka826's Avatar
57f is also capable with tpms!!
Old Feb 8, 2007 | 10:29 AM
  #115
roto8car's Avatar
Has anyone ever cracked a rim on a pothole? Can I file a claim for this $550 dollar piece of equipment?
Old Apr 9, 2007 | 12:31 AM
  #116
Ex2c's Avatar
Does anyone know if Work EMotion CR KAI takes TPMS? THANKS!!
Old Apr 9, 2007 | 01:25 AM
  #117
anyone know if the advan Connoisseur No. 51C take tmps?
Old May 20, 2007 | 02:46 AM
  #118
DDJFLW's Avatar
BSA 305 works with TPMS just fine...
Old Jul 12, 2007 | 05:39 PM
  #119
kingbob1000's Avatar
i think the light looks cool, i wish they had diffrent colors
Old Aug 16, 2007 | 12:57 PM
  #120
Mspeedpro's Avatar
Registered Abuser
bump on this.
this isnt really a list of wheels, its a jumbled thread. maybe the OP can edit the first post and start adding to a legible list??
Old Jan 1, 2008 | 01:22 PM
  #121
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
18"X8" Rota P45f will take the TPMS.
Old Jan 10, 2008 | 05:46 PM
  #122
Mspeedpro's Avatar
Registered Abuser
18x8.5 Work Emotion CR-KAI fit the TPMS just fine.
Old Jan 10, 2008 | 06:05 PM
  #123
Mazurfer's Avatar
Surf Hard, Drive Hard
Since this long dormant thread was revived:
I have a thread about my whole situation a year ago when I went through it. What my issue amounted to was that the actual rim pass through hole was a little larger than stock and the stock gromment(on the TPMS) wouldn't seal up tight enough and I would slowly lose pressure. If I drove like a bat outta hell, it would leak faster.
I finally figured out what to do after much trial and error. So, I took grommets(others have used #5 o-rings) and with the TPMS in place, take off the cap(obviously not the end cap) and work the grommet/o-ring down over the valve stem, over the cap threads and down as far as I could into the rim hole(which had a lip about midway through). Then put the cap back on and tightened it down. So essentially I have the normal gasket sealing from the inside of the lip in the rim hole and the new gasket sealing from the lip hole in the rim to the outside.
Dave
So.............the HP Racing EVO Lightnings will work, but you better do some additional work.
Also..............there is a new TPMS gasket now(newer than 05's might have it?) that looks a little better and is larger. It can be seen in my thread as well. I go find it and post it here.
Here's the short thread and it shows what I did and photos of both styles of grommets on the TPMS's if anyone needs it and or is interested.
https://www.rx8club.com/series-i-tech-garage-22/tpms-gasket-114960/
and
https://www.rx8club.com/showthread.p...12523#poststop
Old Jan 16, 2008 | 07:10 PM
  #124
cliffkemp's Avatar
motegi tracklite 2
Will the motegi tracklite 2s 17x8 fit the 6 speed, and can I use the sensors in the original wheels or will I have to buy new ones for the change in size?
Old Jan 20, 2008 | 05:49 PM
  #125
philsbluerx8's Avatar
Did anyone have experience with enkei RPM2 18*8 +35? will it take TPMS WITH no problem as well? i am thinking to get those rims recently, so i really need help right now...
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
