RX8 vs 350Z vs 370Z
Old Jul 28, 2009 | 10:23 PM
  #76
chiketkd's Avatar
Row faster, I hear banjos
Originally Posted by PedalFaster
Are you sure? More grip means more body roll means picking the inside rear wheel further off of the ground, which generally translates into more wheelspin, not less.
Set-up could dial out some of that inside rear wheel spin. Get some custom moton shocks and run some good rebound in the rear, in combination with a stiff FSB and that problem could be greatly reduced.
FWIW, the car Piccione drove was on stock shocks with a big FSB.
Old Jul 29, 2009 | 12:11 AM
  #77
PedalFaster's Avatar
I'm sure it could, but the comment you made that I was questioning was that wider rear tires would reduce wheelspin. That hasn't been my experience, although I'd be interested in hearing experiences to the contrary.
Old Jul 29, 2009 | 09:30 AM
  #78
chiketkd's Avatar
I gotcha. I would agree that wider, stickier tires *could* cause more wheelspin issues compared to the same car on less grippy rubber. I imagine the same could be said about a grippier surface compared to a less grippy surface.
The real question is, can a 370Z be set-up (within the confines of the stock class rules) to put the power at corner exit on concrete? Either way, looks like we'll all find out first-hand in the next 6-7 weeks...
Old Jul 31, 2009 | 10:24 AM
  #79
chiketkd's Avatar
I still haven't heard back from Learic, but I'll talk to her this weekend. I did ask Piccione another question and got a response...
In your opinion, is it A-stock fast (S2000, Solstice GXP, etc) or just top of the BS heap fast?
Originally Posted by leepic
Not AS fast....
Old Jul 31, 2009 | 11:07 AM
  #80
chiketkd's Avatar
I heard back from Learic...
Hey Learic,
I had a question regarding fuel load in the 370Z.
How low have you (or a co-driver) been able to run the fuel load in your 370Z, without experiencing fuel cut? Btw, do you remember what your fuel level was in Toledo when you weighed the car?
Thanks.
Originally Posted by spoolio
Hi Chike - Well, l had a bit over half a tank of gas at Toledo and Mark said there was one time that he thought he experienced fuel cut off going around the backside sweeper. I find that hard to believe but I suppose it's possible. I didn't expereince it myself....probably because I wasn't driving hard enough
Old Jul 31, 2009 | 05:52 PM
  #81
Do you talk to yourself when nobody else is around?
Old Jul 31, 2009 | 06:00 PM
  #82
chiketkd's Avatar
See you in Lincoln jackass!
Old Jul 31, 2009 | 06:22 PM
  #83
sorry, forgot the "j/k" smilie
Old Jul 31, 2009 | 06:23 PM
  #84
mwood's Avatar
Looks like the Vail Tour BS class went from "possibly interesting" to "nobody's home"...
Old Jul 31, 2009 | 06:33 PM
  #85
I thought about hitting it on the way out to the Lincoln Divisional trip, but the bills are hitting for the knee surgery ...
Old Jul 31, 2009 | 11:52 PM
  #86
mwood's Avatar
Too bad...I liked your odds to take the win...
JK, hope the knee is doing ok.
Old Jul 31, 2009 | 11:58 PM
  #87
chiketkd's Avatar
No worries. Give me some credit though...I try to at least steer my posts away from random, wild accusations made solely to "add to the chat"!
Old Aug 1, 2009 | 02:03 PM
  #88
srsly, try harder ...
Old Aug 29, 2010 | 04:50 PM
  #89
rx3oldschool's Avatar
Resurrection
Hehheh...I'm bringing this back from the dead. As an old RX-3 owner I'm interested in any feedback on the 370Z in Xcross, this was an entertaining thread, and if it is any indication of the Forum as a whole, it's an indicator of some quality members, so
Old Aug 30, 2010 | 09:30 PM
  #90
tmak26b's Avatar
It all depends on the course, the RX-8 might have an advantage, but probably not as big as you think. Still, isn't Solstice the car to beat at the nationals this year?
For the track, forget about the RX-8
Old Aug 30, 2010 | 09:59 PM
  #91
TopGear8's Avatar
mkuhnracing.com
^Nope..
Old Aug 30, 2010 | 10:23 PM
  #92
chiketkd's Avatar
Originally Posted by TopGear8
^Nope..
Agreed. The MX-5 MS-R is definitely the car to have in CS.
Old Aug 31, 2010 | 05:55 AM
  #93
So the Nissan is still crap on Xcross, then. It is heavy. It looks like the braking and overheating issues have been sorted out on the track, though. Nissan should have had an oil cooler on that thang from the start.
Old Aug 31, 2010 | 11:40 AM
  #94
tomsn16's Avatar
Yes the 350 and 370's are heavy....check the table at the start of this thread.The 350 and 370's are not crap at autoX....Nationals results next week will tell us much more cause there is a good 350/370 showing this year. With the right driver and right course the Nissan could do very very well next week.
Old Aug 31, 2010 | 06:25 PM
  #95
tmak26b's Avatar
It's course depended, I have owned, autox and tracked all 3 of the cars. The difference isn't as big as you think. I can tell you the RX-8 is the easiest but also least thrilling to drive.
Old Aug 31, 2010 | 06:40 PM
  #96
TopGear8's Avatar
mkuhnracing.com
^I disagree with pretty much everything this guy says...
Old Aug 31, 2010 | 07:06 PM
  #97
tmak26b's Avatar
That's fine. I still have owned all three cars and have driven enough to have an idea on each car's strengths and weakness.
Old Aug 31, 2010 | 07:22 PM
  #98
TopGear8's Avatar
mkuhnracing.com
Not thrilling to drive would not be considered a strength or weakness...That would be personal opinion.
Old Aug 31, 2010 | 07:51 PM
  #99
tmak26b's Avatar
I never said it was, they are just different. I still have owned and raced them all.
Old Aug 31, 2010 | 07:55 PM
  #100
TopGear8's Avatar
mkuhnracing.com
Just because you have owned them and raced them does not make the 350z faster than an RX8...The 350 might have suited your driving style better...maybe you can't keep the momentum up through the corners with the RX8..So you need the power of the Z to pull you out of corners...
Just a thought.
