Series II Technical and Trouble shooting Discuss technical details for the Series II RX-8 and any issues or problems you are facing
Mechanical Changes On RX-8 Series I to II
Old Jan 3, 2009 | 03:14 AM
  #51
auzoom's Avatar
Hmmmmmm.........
Originally Posted by MazdaManiac
Preliminary exploration into the subject has so far revealed that the metering oil is still controlled by only one load-based and one throttle-based table.
So, any difference between the two pumps will be accomplished by the pumps themselves.
Didnt see this response initially. I understood the first part, that while we have the new EMOPs, they are controlled in the same old way, ie depending on the load and throttle position determines the amount of oil metered. With the second part, are you saying that the only other differences are the actual pumps themselves, ie SI = Brand X (which just happens to be mechanical) and SII Brand Y (Which just happens to be Electric).
Also, why would they go for 2 pumps instead of one? They are downsizing on the injectors...maybe to pay for the extra MOP
Cheers
Andrew
Old Jan 3, 2009 | 10:18 AM
  #52
PotatoSoup's Avatar
Polish-American Hammarrrr
OK, so I'm clearly not an expert on rotaries, but in regard to the 2 EMOPs, maybe Mazda have been doing some studying and analysis of the RENESIS over the years and have noticed that the two rotors/housings exhibit some differences in wear or heat issues over time.
By having an individual EMOP for each rotor/housing, maybe they can account for differences between the two (dynamically, precisely tailoring oil flow across all 6 injectors) that may not be possible with one pump?
By that I mean, for example, maybe for some particular load/throttle combinations, the rear rotor is being metered, say, 4% more oil than the front rotor.
Also, hooray for this thread + sticky!
Old Jan 3, 2009 | 06:17 PM
  #53
auzoom's Avatar
Hmmmmmm.........
Thats what I would have figured, but based on MM's post about this, I would have assumed that in order to meter the pumps independantly you would have 2 seperate tables which they dont.
Also, SII only has 4 injectors
Cheers
Andrew
Old Jan 3, 2009 | 06:48 PM
  #54
PotatoSoup's Avatar
Cheers
Andrew
Yes, 4 fuel injectors and 6 oil injectors, if that's what you mean.
Old Jan 3, 2009 | 09:43 PM
  #55
MazdaManiac's Avatar
Has anyone verified that it is actually two physical MOPs?
I haven't. I only know about the PCM end of it.
Old Jan 3, 2009 | 10:24 PM
  #56
Easy_E1's Avatar
You didn't see this from earlier in the thread,,,? Courtesy of Ash8
Old Jan 3, 2009 | 10:30 PM
  #57
Erick - I sincerely want to thank you for that excellent technical contribution.
Unfortunately, I was not aware of that particular technical drawing or its presentation here on this forum.
I consider this elucidation of the subject to be most welcome and the clarification of the matter is, in my view, absolute in light of this particular bit of added information.
Old Jan 3, 2009 | 10:32 PM
  #58
Easy_E1's Avatar
When he says it like that I don't know whether he's being sincere or sarcastic. It's the exclamation point at the end.
Old Jan 3, 2009 | 10:40 PM
  #59
Lol.
Edited.
Old Jan 3, 2009 | 10:52 PM
  #60
Easy_E1's Avatar
Your very welcome Jeff. I don't know how you could have overlooked this bit of information. But it's always a pleasure to help out a fellow die hard like my self.
I just about spit my drink all over my keyboard with that comment.
Anyway if you need help with anything else Jeff, don't hesitate to ask.
Old Jan 3, 2009 | 10:53 PM
  #61
going to go with both for a thousand alex!
Old Jan 3, 2009 | 11:12 PM
  #62
auzoom's Avatar
Hmmmmmm.........
Doh!
Old Jan 3, 2009 | 11:15 PM
  #63
Easy_E1's Avatar
According to the above diagram,, the two OMP's appear to share a common union. Seems they both rely on the same oil source.
I find it funny that I can only find 4 outlets for the oil injectors on the pumps. Where are the injection lines for the other two.?
I know Mazda loves these vague pics but is there another pic with the injection lines in relation to the pumps?
Old Jan 3, 2009 | 11:22 PM
  #64
Originally Posted by ASH8
Confirmation only attached on page 2 of 3 so far in this thread...
I don't have time to read everything - I count on the concise synopsis of people like Easy!
Old Jan 3, 2009 | 11:23 PM
  #65
ASH8's Avatar
Super Moderator
METERING OIL PUMP RESISTANCE INSPECTION.
1. Disconnect the metering oil pump No1 and No2 connectors (2 terminals).
2. Measure the resistance between terminals A-B using a Tester.
* If not within the specification, replace the metering oil pump.
Metering Oil Pump No1 and No2 standard resistance.
3.6 - 4.1 OHMS ( Temp 20 oC / 68 oF)
Source: 2009 RX-8 WS Manual.
I have not checked the Parts Manual, but it appears if the EMOP's are defective you renew the complete unit as there are no serviceable components.
Old Jan 3, 2009 | 11:25 PM
  #66
auzoom's Avatar
Hmmmmmm.........
Is it possible that the outer injectors share an outlet hose?
Old Jan 3, 2009 | 11:33 PM
  #67
Easy_E1's Avatar
Thank you, thank you,,, thank you very much
Takes a bow..
Old Jan 3, 2009 | 11:36 PM
  #68
Easy_E1's Avatar
It should show up as an intermediate connector in the pic,, some where I would think.
I would like to see,, "01-11-14 Hose removal note".
  #69
If you look very carefully at the right pump on that diagram, it shows two outlets.
They just didn't want to show double banjo fittings on that diagram, so they used a split line to designate two identical connections.
Compare this to the left pump.
Old Jan 3, 2009 | 11:41 PM
  #70
Easy_E1's Avatar
I see now says the blind man. Thanks Jeff. We're doing good here tonight.
Where would they be with out us?
Old Jan 3, 2009 | 11:42 PM
  #71
ASH8's Avatar
Super Moderator
Lubrication
Here is the only other Diagram I can find of the EMOP and the Oil Tubes (as Mazda call them), the rest you have already seen, the manual does not show the Oil Tubes on their own or in a completed series or circuit.
I am sure the Parts Manual would show in more detail.
There is a supply hose that goes from one EMOP to the OCV (No. 10) Oil Control Valve, located by the Water Pump/ Front Timing Cover.
  #72
I dunno. Take a look at the pile-up in the Pettit threads, I guess.
Old Jan 3, 2009 | 11:49 PM
  #73
Easy_E1's Avatar
I get most of my info from the parts dept on computer. Manuals are great but if you want detailed pics,, you hope. Then the parts descriptions are a must have.
Nope.
Old Jan 3, 2009 | 11:53 PM
  #74
ASH8's Avatar
Super Moderator
As shown on page 2 of this thread...unfortunately there are no other complete pics of the Oil Tubes in the WS Manual.
The Hose Removal Clamp/Fitting is related to the hose interconnection of the two EMOP's, sorry I just cant find any more diagrams for you.
Old Jan 4, 2009 | 12:02 AM
  #75
Easy_E1's Avatar
Thanks for what you have posted up. I'm sure everyone appreciates it as much as I do.
