Purchasing, Financing, & Insurance Talk about dealerships, your order status, delivery experience, ordering options, financing/leasing, insurance deals, etc.
Year by Year Changes
Old Sep 19, 2008 | 08:57 AM
  #51
AntonToo's Avatar
Originally Posted by korx8
Antontoo:
What I can tell between the 40th aniversary and the 04 models is that the engine performs better... gas mileage is much better.. at least 10%... after 2000 miles... it has never flooded... the 04 would flood after sitting in the garage for more that 5 days...(I travel a lot)...
Handling... is better on the 40th aniversary but not by a whooole lot... performance seems slightly better... I beleive because of better EMU settings and more experience with the Renesis engine...
From what I can tell there is not much difference in powertrain between the 08 40th aniversrary and the 09 R3... it is mostly interior, 19" rims (that should provide something...) and some external changes...
Regards
KO
THANKS! What about ride quality? Does the 40th ride stiffer? harsher?
Old Sep 19, 2008 | 09:34 PM
  #52
RenKat's Avatar
The ECU has always been 32 bit.
Old Oct 2, 2008 | 02:57 AM
  #53
LionZoo's Avatar
road warrior
Racing Beat mentioned that the ECU for the 2004 was a 16 bit in their reflash development. It was why it took so long for a 2005 version of the flash to come out versus the 2004.
Old Oct 5, 2008 | 04:29 AM
  #54
93'roadwarrior's Avatar
Correct me if I'm wrong... but I can't find the oil filter on my 09 R3... where did it go? Did they move it or something? I thought the oil filter was by the fire wall like on the FD
Old Oct 5, 2008 | 09:15 AM
  #55
AntonToo's Avatar
you should add that the 40th edition also gets bilstein shocks and urethane filled cross member
Old Oct 6, 2008 | 12:55 AM
  #56
LionZoo's Avatar
road warrior
Originally Posted by 93'roadwarrior
Correct me if I'm wrong... but I can't fing the oil filter on my 09 R3... where did it go? Did they move it or something? I thought the oil filter was by the fire wall like on the FD
They moved it to the bottom close to the oil sump. This way the drain plug and filter are in approximately the same location.
Old Oct 6, 2008 | 12:59 AM
  #57
LionZoo's Avatar
road warrior
Shinka, 40th Anniversary, and R3 packages clarified.
Old Oct 6, 2008 | 02:02 AM
  #58
Daemos's Avatar
Antontoo:
Regards
KO
Engine is the same between 04 and 08 (including anniversary edition). Your 04 most likely possible carbon build up. my 05 doesn't flood at all, and I know a few 04s that have never flooded either. There are differences in PCM but the maps are similar. I let my 05 sit for a few months and it started right up (once I remembered to plug the battery back in). The 40th anni also had a urethane filled front cross member, and blisten shocks.
09s have a redesigned renesis engine with a third oil injector. As well as shorter gearing, with revised rear suspension which I'm not sure what that is.
the R3s have recaro seats and different shocks
Old Oct 6, 2008 | 03:28 AM
  #59
LionZoo's Avatar
road warrior
C'mon guys, all this information is contained in the first post!
Old Oct 6, 2008 | 08:25 AM
  #60
Huey52's Avatar
Registered Zoom Zoomer
OK, but I had to purchase and install my own AC condensor screen in my March '05 build Shinka.
My '05 did come with the new starter and battery due to its late March '05 build.
The Shinka also came with a 6-CD changer in the Bose audio system and also a Sirius radio installed (therefore no NAV available).
Excellent list.
Originally Posted by LionZoo
The AC Condenser screen was a mid-2005 change so I'm counting it for 2005.
Old Oct 6, 2008 | 08:32 AM
  #61
Huey52's Avatar
Yep, far more elegant design for ease of oil change. They also added a "hatch" to the engine cover for dipstick access.
They moved it [oil filter] to the bottom close to the oil sump [on the '09]. This way the drain plug and filter are in approximately the same location.
Old Oct 12, 2008 | 03:34 PM
  #62
egads's Avatar
Might want to add the '09 also adds padded leather arms rests on the drivers and passengers doors. But I guess this could be part of "interior changes". I just see you've also listed the leather wrapped parking brake.
Old Dec 10, 2008 | 02:02 PM
  #63
LionZoo's Avatar
road warrior
Part of restyled interior. Leather parking brake only comes on GT models and I was listing what was changed with that trim line.
Old Dec 11, 2008 | 07:32 PM
  #64
LionZoo's Avatar
road warrior
Updated with some minor trim level differentiation.
Old Jan 22, 2009 | 06:33 PM
  #65
always.anthony's Avatar
is looking for his torque
what's the difference for interior? and in what way is the intake pcv different?
this is all crucial for me, as for i am picking out an rx8!
Old Jan 28, 2009 | 02:04 PM
  #66
korx8's Avatar
Right! 04 through 08 engines might be the same... but I don’t think EMU code is... thus the difference in efficiency at least (much better mpg)...
40th Year Anniversary and 09 R3 have exactly the same suspension. Bilstein shocks and foam filled members... see Mazda website...
From performance (HP & Torque) standpoint 04-08 and 09 have same numbers... unfortunately... I was hoping for some more umpf... interior is most of the difference... 09 R3 has Recaro seats, new instruments cluster and Bluetooth...
Regards
KO
Old Feb 1, 2009 | 01:28 AM
  #67
3cjf897's Avatar
Sorry guys this might be a repost. Im trying to pick up a rx8 and ive been browsing around the threads and i have not yet found an answer to my question i kinda got some pieces together and there.
But my real question is whats the true difference between Sports, And Grand Touring for the 2004-2007 models, is it bad to get a 2004 because of all the Recalls?
What does the grand touring come with that the sports model doesnt?
What exactly is the Appearance or So-Call Accent-package?
What about the grand touring interior colors?
Old Feb 1, 2009 | 10:11 AM
  #68
New Yorker's Avatar
Originally Posted by 3cjf897
But my real question is whats the true difference between Sports, And Grand Touring for the 2004-2007 models…
https://www.rx8club.com/showthread.p...=Sport+Touring
Old Feb 2, 2009 | 01:01 AM
  #69
3cjf897's Avatar
thanks new yorker
but it didnt answer all my questions. lol
thanks for the help though!
Old Feb 4, 2009 | 09:12 PM
  #70
ASH8's Avatar
Super Moderator
Mechanical Changes Thread with Part Listings Diagrams..
https://www.rx8club.com/series-ii-technical-trouble-shooting-160/mechanical-changes-rx-8-series-i-ii-161665/
Old Feb 13, 2009 | 09:51 AM
  #71
Canada's Avatar
I read this in another thread, referring to 2009 restyled RX-8:
"I can not stand a single one of the cosmetic changes they've made"
I had a 2004 RX-8, but it was a company car lease and replaced it after 3 years with CX-7. Now it is time to renew again, I want to go back to RX-8 but I'd like to see a side-by-side photo comparison of the 2008 and 2009 exteriors.
Old Aug 26, 2009 | 12:03 AM
  #72
KrazyKarl's Avatar
So I was taking a look at the 2010 8s on mazdausa.com
Everything looks the same as the 2009s
What's different?
Old Aug 26, 2009 | 12:56 AM
  #73
hakuna matata!
Nothing?
Old Aug 26, 2009 | 02:03 AM
  #74
ASH8's Avatar
Super Moderator
Interesting, on the Mazda USA Media site it lists the 2010 Vehicle Range, the RX-8 is not included (maybe oversight) , but on their retail site it says 2010 RX-8.
But yeah, there is really no difference and no new colors...essentially it is a 2009....WOW only 3 colors available in the US now.. Red ,Black, Silver.
In Japan, Mazda have included a few features as standard on their line up, rain sensing wipers, Advanced keyless entry with Push Button start, Auto Dim rear view mirror, and a few other things...umm, Auto Lights ON/OFF....
Old Aug 28, 2009 | 08:03 AM
  #75
mike1161's Avatar
2010 changes
On the Mazda USA site, it now shows the 2010 lineup. The big change is that the Touring model has been dropped. Now there is just Sport, GT, and R3.
Colors have also changed - added Liquid Silver Metallic, and the Crystal White Pearl and Diamond Grey Metallic have both been dropped for 2010. The only colors now are black, red, silver, and blue (R3 only).
Also, now if you get the GT, you're forced to get the moonroof (for 09, it was an option). Don't know why they did this, I like the lines of the roof better without the sunroof. Didn't see any other significant changes. If you look at their MSRP pricing, the R3 is only $240 bucks more than the GT!
