DIY: RB Gauge Pod + Nordskog Digital Gauges
Old Feb 17, 2008 | 03:04 PM
  #51
nelsonrx8's Avatar
jedi i need the force where are u......... pmme
Old Mar 8, 2008 | 07:19 PM
  #52
added 2 new night time pics courtesy of PhotoChick.
Old Mar 10, 2008 | 05:57 PM
  #53
Incorigible's Avatar
that is sexy
Old Mar 31, 2008 | 04:03 PM
  #54
Nemesis8's Avatar
Bigus Rotus
OK, I have read this post back when you published - nice mod. I'm curious of the dimmer function. You said you used the ashtray light circuit? Is that what RB does also with there mech gauges? I'm curious about a complete dimming function I guess. Seems you said either 100% with lights off, and 50% with lights on, correct?
Old Mar 31, 2008 | 04:15 PM
  #55
Yup, Racing Beat recommends tapping into the ashtray light on their insturctions. (Nordskog had similar instructions)
I remember reading that my guagues were not intended to have full dimming options (as our gauge cluster) has but I'm pretty sure that if wired properly it might work. Not sure exactly how to pull that off though.
What guages are you trying to get to dim?
Old Mar 31, 2008 | 04:20 PM
  #56
Nemesis8's Avatar
Bigus Rotus
Have not decided on them yet, but you are persuading me to join you.
Old Mar 31, 2008 | 04:21 PM
  #57
come over to the Dark Side...
Old Mar 31, 2008 | 05:14 PM
  #58
snipaz2420's Avatar
the bukkake master!
jedi imo this is the sexiest gauge setup i've ever seen
Old Mar 31, 2008 | 05:23 PM
  #59
Thanks Snipaz!!!
Old May 12, 2008 | 11:34 AM
  #60
drjw211's Avatar
Racing beat question
hey im trying to buy the RB pod but cant find a place to buy it could u help me out? thank you
Old May 12, 2008 | 11:42 AM
  #61
drjw211: where are you located?
Did you call Racing Beat directly?
Old May 15, 2008 | 03:30 AM
  #62
drjw211's Avatar
i live in maryland, no but ill try that
Old May 16, 2008 | 10:33 PM
  #63
BoosTED's Avatar
Mmmm I'm likin' the look of those numeric gauges. Didn't think I would ever like digital readout gauges but these are stealth looking.
Old Jul 10, 2008 | 12:17 PM
  #64
Just wanted to update everyone on these guages. I finally ran into a problem with them. Here's a crappy cell phone video I took while trying to drive.
As you can see, the temp readings are all over the place!
Now the question is: What's causing the false readings? Is it the gauge itself, a connection, or a bad sending unit?
In order to try and rule out the gauge as faulty, I swapped the sending lines from my water temp and my oil temp. ie; the water temp would now show oil readings and vice versa
This was super easy to do, simply unscrew the gauge pod and swap the BLUE wires for the two gauges.
Here's a video of what happened:
That pretty much ruled out the Oil Temp gauge as now the Water temp gauge is doing the same thing.
Next step was to check all my connections. Again, this is fairly easy as the ground wires are easy to spot in the engine bay and all the gauges share the same ground wire. (post 1 talks about soldering 3 wires off the main ground)
Conclusion: must be a bad sending unit.
Since I've had the gauges for a few months, I decided it was best to contact Nordskog directly about the problem. I sent them an email and they were VERY quick to respond. The Manager at Nordskog agreed that the symptoms all pointed to a bad sending unit and all they needed was an address to ship out a replacement. now THAT'S great service!! I had the replacement part 2 days later.
Happy to report that after swapping out the sending unit this past weekend, the gauges are now working PERFECTLY! A big thanks to Nordskog for stepping up and being helpful.
Removing the RB adaptor to replace the sending unit is not all that tough but is is made more difficult since all your connections are already in place. (as opposed to when you installed it) This is where I was glad I had left plenty of extra slack when I originally installed everything. (the extra slack was zip tied underneath the dash, not in the engine bay)
Hope this helps...
Old Jul 10, 2008 | 12:38 PM
  #65
NgoRX8's Avatar
good news! glad ya got it fixed.
Old Jul 10, 2008 | 12:44 PM
  #66
yup, although ignorance was BLISS!!! I loved it when it was 105°F outside and my oil temps were only at 115°
Old Jul 17, 2008 | 05:50 AM
  #67
V1.0's Avatar
I'm still dreaming of this setup on my car...
Glad everything worked out and it's great that they sent you a replacement, sounds like a good company!
Old Jul 18, 2008 | 08:10 PM
  #68
elf's Avatar
elf
What pointy ears?
Good to hear you got the problem fixed! I remembered speaking with Nordskog support (for information) and they were quite responsive.
No problems with my gauges --- still work like a champ! But, yeah, I agree with your "ignorance is bliss" statement about temps --- it's amazing how hot this engine gets in the summer in the deserts of the southwest US
Old Sep 7, 2008 | 09:34 PM
  #69
irx08t's Avatar
Hi Jedi,great write up. You inspired me to do the same so now i have all items purchased and ready to install. I've noticed that the gauges do not sit flush on the Racing Beat pod,due to the curvature of it. Is this the same with yours?
Old Sep 7, 2008 | 09:48 PM
  #70
hey irx: glad to hear you've been inspired!
yeah, due to the natural curvature of the pod, there will be areas where it does not sit flush but because the side of the gauges are also black, you will not notice this once it's installed.
Old Sep 8, 2008 | 12:31 AM
  #71
NgoRX8's Avatar
lol, damn my gauges have a titanium finish on the sides. that's not gonna look right...
Old Sep 8, 2008 | 12:34 AM
  #72
paint is your new best friend.
Old Dec 1, 2008 | 06:37 PM
  #73
djcharlee's Avatar
Question
How come this Oil Pressure sending unit in Pic 1
Is not the same as the one in the wiring picture?
I purchased the one in the top picture, will it work, and what is that copper clamp around it? Mine did not come with one.
Thanks in Advance.
Old Dec 1, 2008 | 07:01 PM
  #74
never fear, Jedi is here!
dj: I'll call you.
Old Dec 1, 2008 | 07:07 PM
  #75
djcharlee's Avatar
LOL thanks man...
