Will It Fit Thread
Rating: Thread Rating: 4 votes, 5.00 average.
Old Dec 24, 2007 | 08:13 PM
  #51
aliveoutofhabit's Avatar
Here's my wheel future:
18x9.5 +45
or
18x9 +35
245/40R18.
From what I've read about the RP-F1 fitments, running these tires should be a piece of cake on the +45 9.5's... but I'm unsure about the +35 9's... It seems like it'll work.
Old Dec 25, 2007 | 02:30 AM
  #52
eastaznboi's Avatar
thanks a lot for all the help bigO and lurch.
I'm going to have to see how everything will play out before i order everything. thanks again!
Old Dec 25, 2007 | 04:12 AM
  #53
BigOLundh's Avatar
#1 Legend
Originally Posted by lurch519
did you roll your fenders?
im running 255/30 on the rear, and cant get my pinky between the fender and the tire.
well, if you are running a 275/35 on the rear, you might not have to as the tire is half an inch shorter than stock
did not roll the fenders
Old Dec 25, 2007 | 02:19 PM
  #54
SebtownRx8's Avatar
75shot55fueljets=GOBABYGO
19x8.5 front offset of 38
20x9.5 rear offset of 35 or 19x8.5 rear offset of 38
whats a good tire size i should look at for both setups?
Old Dec 25, 2007 | 03:32 PM
  #55
BigOLundh's Avatar
#1 Legend
For the 19X8.5 +38 (F/R) you have a lot of options. Overall i think youll be best with a 255/35/19 or 245/35/19
or for a slightly larger profile
255/40/19 or 245/40/19
Since you have the same size rim for the front/rear - might as well keep matching tires on both. May want to search all 4 and see which gives you the best price.
I cant comment on the 19s in the Front and 20s in the rear... as i have no idea what look your going for... and what tire fitment will match.
Old Dec 25, 2007 | 04:02 PM
  #56
SebtownRx8's Avatar
alright thanks dude and i just bought the 19x8.5 (F/R)
so now its time to pick some good tires
Old Dec 25, 2007 | 04:07 PM
  #57
chetrickerman's Avatar
Rota Torque 18x8.5 + 48 or +28?
dont know which tires
Old Dec 25, 2007 | 05:52 PM
  #58
DOMINION's Avatar
I don't buy Kool-Aid
Will 20x10's fit with a + 15? in gold
Old Dec 26, 2007 | 12:32 AM
  #59
BigOLundh's Avatar
#1 Legend
yes they definetely will. go for it.
Old Dec 26, 2007 | 12:33 AM
  #60
BigOLundh's Avatar
#1 Legend
there is nothing available inbetween those two offsets? if thats your option... just go with the +48. They will sit about .5" further out then your stock rim. Nevertheless... it will have the sunken battleship look, but if your ok with that... go for it.
You dont have to worry about stretching the tire to make it fit, so just go with whatever you want. 245/40/18 will work fine.
Old Dec 26, 2007 | 12:47 AM
  #61
paulmasoner's Avatar
Asshole for hire
hey BigO, i'm thinking about dropping the front about 1.2" and lifting the rear about 1.5"
if i do do you think i can fit 18x8.5 +38 FR and 20x10.5+32 rear???
i cant wait to hear if it will fit, i think this car would look badass with the old school muscle car lean
this is the guy you are all asking wheel questions to....
BigOLundh (9:03:41 PM): i clikced on the link again with that stupid song
BigOLundh (9:03:45 PM): on purpose
BigOLundh (9:03:47 PM): its so great
paulmasoner (9:04:33 PM): what song, rick rolled?
BigOLundh (9:04:44 PM): yup
paulmasoner (9:04:45 PM): haha
Old Dec 26, 2007 | 01:10 AM
  #62
BigOLundh's Avatar
#1 Legend
i dont know why everyones hating... thats a great song.
and to your question, yes it'll fit. Make sure to run slicks in the back (over 315)... and lets get to work on your Flow Master exhaust canisters. Ford re badge is a must.
Old Dec 26, 2007 | 06:34 PM
  #63
put that tire apsect ratio calculator BS away because it means nothing, tires are not created equal WRT the width size and aspect ratio cast onto the sidewall
18 x 10.5 +45 with Yokoham Advan Neova AD07 265/35-18 tires on all four corners (which BTW the 265 AD07s are wider than any other 275 street tire)
seriously lowered, no fender mods and no rubbing
Old Dec 26, 2007 | 07:03 PM
  #64
No one answered my thread I pretty much already know the answer
repost with edits:
18x9.5 +35
or
18x8.5 +30
245/40R18 on the 9.5
225/45R18 on the 8.5
If I decide to run these. They WILL NOT be staggered. I'm going to choose one fitment all the way around.
From what I've read about the RP-F1 fitments, running these tires should be a piece of cake on the +45 9.5's... but I'm unsure about the +35 9.5's... It seems like it'll work.
Old Dec 26, 2007 | 07:18 PM
  #65
BigOLundh's Avatar
#1 Legend
Seeing how Team is getting away with 18 x 10.5 +45, then 18 X 9.5 +35 seems doable
Old Dec 26, 2007 | 07:19 PM
  #66
BigOLundh's Avatar
#1 Legend
did you notice a benefit in running the 265 on a 10.5" rim... versus across a 9.5" rim?
Old Dec 26, 2007 | 08:51 PM
  #67
I bet it looks pretty bad *** (read: stretched).
Maybe I'll run 225's on a 10.5...
Where is Rishie and why hasn't he posted his uber-flush fitments?
I'd like to see pics of a 245/40 on an 18x9.5, I'm sure he could produce that. Rishie I'm local and might buy my wheels from you!!! ;] Now post some pictars!
Old Dec 26, 2007 | 10:56 PM
  #68
BigOLundh's Avatar
#1 Legend
i meant performance wise. i doubt team is gonna sacrifice even .1 seconds on an autocross course for the sexy stretched look
Old Dec 27, 2007 | 05:55 PM
  #69
TragicallyHip's Avatar
IfYerNotWasted..TheDayIs
I'm getting close to purchasing tires for my newly purchased rims, posted this information before, but figured with the extra information here it may make it easier to choose the right tire for the rear...
Obviously the 265s are my first choice, but can't find a reputable place to roll the fenders...
18x8.5 (+35) front
18x9.5 (+35) rear
Old Dec 27, 2007 | 08:39 PM
  #70
BigOLundh's Avatar
#1 Legend
18x8.5 (+35) front
18x9.5 (+35) rear
For that setup i would go with a...
Only Problem i see with this is that your front side wall is about 2.75 mm higher than the rear. Hardly noticeable
235/35/18 (F) (82.25mm Side-Profile)
265/30/18 (R) (79.5mm Side-Profile)
That stretch on the front rim might be a bit much... and will make you SLIGHTLY more prone to curb damage. If your a good driver and the roads in your neighborhood aren't too bad... this shouldn't be a major issue.
225/35/18 (F) (78.75mm Side-Profile)
If it was me i would go with the second choice.
Old Dec 27, 2007 | 09:06 PM
  #71
The three new tire sizes you mentioned, are non-existant in the Federal Tyres line-up lol...
I posted these particular 4 tires as they are the only ones that I am looking at purchasing. Their 30-series tyres are only available in 19"...
Old Dec 28, 2007 | 12:31 AM
  #72
Likely won't be an issue BUT since you don't state what tire brand/model nobody can be 100% sure
a designated tire size like 245/40R18 doesn't mean anything, the tire manufacturer can make it as wide or as narrow as they see fit, there is no legislated standard on actual vs theoretical size designations
repost with edits:
18x9.5 +35
or
18x8.5 +30
Old Dec 28, 2007 | 12:26 PM
  #73
dytrd5's Avatar
how about a F: 18x9.5 +50
R: 19x9.5 +55
Old Dec 28, 2007 | 12:39 PM
  #74
BigOLundh's Avatar
#1 Legend
dont do that
Old Dec 28, 2007 | 01:07 PM
  #75
SebtownRx8's Avatar
Hey big O would 19x8.5 F offset 38 and 19x9.5 R offset 35 work? or offset 35 on both. offset 35 19x8.5 R offset 35
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
