Pettit Super Charger Owners
Old Nov 15, 2009 | 08:31 PM
  #6501
olddragger's Avatar
hmmm--did my own--np's
did feel a little difference mid throttle and mid rpm's
hows your lft's?
did the pedal dance?
very nice job on that work
OD
Old Nov 16, 2009 | 08:40 AM
  #6502
olddragger's Avatar
well found a frayed wire to my purge control valve--fixed that and installed a different front 02 sensor. The one coming out did look like it had not enjoyed the ride. Better now but havent took a ltft look as of yet---need to drive it a little.
Now also getting a 2004 code---seems my apv is a little sticky---sigh will it ever end----HOPE NOT!
ODl
Old Nov 17, 2009 | 02:00 PM
  #6503
JMKuco's Avatar
Rotary engine addict
engine bay - new coolant reservoir
I finished my installation...
new coolant reservoir + fluid's (mazsport) cooling solution.
tell me what ya think
Attached Thumbnails Pettit Super Charger Owners-sany0756.jpg   Pettit Super Charger Owners-sany0758.jpg   Pettit Super Charger Owners-sany0759.jpg
Old Nov 17, 2009 | 02:21 PM
  #6504
Rotr8's Avatar
whines all the way home
Looks nice, how hard was it to re-route the coolant lines?
Old Nov 17, 2009 | 03:16 PM
  #6505
olddragger's Avatar
thats looks nice.
heat shielded from exhaust?
OD
Old Nov 18, 2009 | 06:22 AM
  #6506
JMKuco's Avatar
Thanks,
I'm not an expert but the coolant line was not hard to reroot:
The only point to think of is a T hose from under the reservoir to the top of the rad.
No heat shield yet...but I will work on this too soon.
I'll wait to lift my car so I'll take out the pipe going to the header.
Old Nov 18, 2009 | 07:57 AM
  #6507
Rotr8's Avatar
If you end up working on a heat shield, I would like to see one down like Racing Beats shield for thier TII engines,,, Very simple, very clean, looks easy to install also considering our engine bays, and maybe instead of having the studs comd off the LIM they could be incorporated into the exhaust mani bolts.
Old Nov 18, 2009 | 07:48 PM
  #6508
olddragger's Avatar
who has built their own cai was it rote8?
How did you do it?
OD
Old Nov 18, 2009 | 09:51 PM
  #6509
Rotr8's Avatar
yup Rote8 and Phil has one that Ray built as well,,,
Old Nov 19, 2009 | 07:09 AM
  #6510
JMKuco's Avatar
How do you install this ?
Old Nov 19, 2009 | 07:33 AM
  #6511
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
How did you do it?
OD
If you want to see mine, look at my profile album pix and click on the pix of Ray working(?)
Old Nov 19, 2009 | 08:57 AM
  #6512
olddragger's Avatar
Thanks Phil---great pics and exactly what I was looking for--looks like he used 3" aluminum pipe+connectors.
I am thinking of using a 3 1/2 OD pipe.
OD
Old Nov 19, 2009 | 10:00 AM
  #6513
Phil's 8's Avatar
No OD, all is 31/2" pipe, couplers and filter
Old Nov 19, 2009 | 11:11 AM
  #6514
olddragger's Avatar
Ok --guess my bifocals were not on straight.
thanks
OD
Old Nov 19, 2009 | 08:24 PM
  #6515
olddragger's Avatar
found a great site for cold air intake parts
" intakehoses.com" they have everything and it is cheap.
OD
Old Nov 19, 2009 | 08:28 PM
  #6516
Race Roots's Avatar
Former Sponsor
OD
I thought you were building an intake, nice find
I will let you know about the other thing soon.
Old Nov 20, 2009 | 12:52 AM
  #6517
Moon Assad's Avatar
Well, almost completed Wesses install but hit a road block. Ok , I went to remove the bolts to hold the heat exchanger and spun the metal tab that seats in the plastic of the rad. Any ideas?
Old Nov 20, 2009 | 08:54 AM
  #6518
olddragger's Avatar
Moon--- you talking about the oem radiator --right?
sounds like it is a nut and bolt time? Just drill through and use a nut on the backside or reem the plastic out and install a nut there--anchor with a good automotive silicone sealant like window weild.
Got ya RR and thanks--no rush just dont forget me?
OD
Old Nov 22, 2009 | 05:02 PM
  #6519
zenrx8's Avatar
While you're at it Denny (or anyone else), I need a source for new oil cooler hoses. The junctions on mine look like they were hand-packed with Ohio salt and then wrapped in Saran wrap to enjure maximum corrosion. Now is the time to replace while the clip is off. I've been searching the net but can't find any OEM source.
Old Nov 22, 2009 | 05:34 PM
  #6520
Rotr8's Avatar
Mine are the same way...
Old Nov 22, 2009 | 09:35 PM
  #6521
olddragger's Avatar
How is Cam doing everyone--I heard second hand that he may be sick?
OD
Old Nov 22, 2009 | 09:38 PM
  #6522
Rotr8's Avatar
I talked to him late last week and he seemd fine, and Im talking to him tomorrow too....
I'll ask on your behalf...
Old Nov 23, 2009 | 07:20 AM
  #6523
Rote8's Avatar
OD
Oh, crap.
Will call today.
Old Nov 23, 2009 | 07:47 AM
  #6524
JMKuco's Avatar
Question Need to confirm if what I did is correct !
Ok So you know that I change my oem coolant tank for an alluminium one.
if you look at the pict attached, you'll see the OEM one with numbers.
#1 - don't car about that one !
#2 - return for the thermostat.
#3 - going to the engine.
#4 - going (or return ?) to the radiator.
my question:
As My new tank does not have 4 hose plug, I tee the #4 hose in the #3 way.
Is it correct ?
HELP WANTED
thanks
Old Nov 23, 2009 | 08:31 AM
  #6525
olddragger's Avatar
i wouldnt do that---the number 4 is an overflow and PRESSURE RELEASE, by piping it back to the engine the excess pressure/air bubbles have no were to go.
Others please correct me if i am wrong.
OD
