Axial Flow Short Shifter
Old Jun 14, 2006 | 02:58 PM
  #526
dtorre's Avatar
Ultimate ****** Goderator
Hmm I don't know first time i've worked with the shifter and I got it in ten...
colsole popped right off no problems with the sensitive clip, don't have the seat controls so I only had one of those little buggers to remove on the boot screws which actually ended up easy thanks to reading the DIY before install. Shifter popped right out, short shifter popped right in and everything took half the time to put back together...
hell the longest part of the install was looking for a greaser to be safe with the shifter =P
Old Jun 14, 2006 | 04:53 PM
  #527
strong bad's Avatar
I am still awesome...
found that it was hard to engage reverse.. has this been mentioned before? i'm sure it has.. anyway so i called the number at RP and was told to file that edge down a lil bit... so onto installation #2..
aha. i've solved the wire harness clips.. see, i only could find one flat head screwdriver.. and with that, i was trying to get both sides of the harness clips off at the SAME TIME before lifting up.. without a suitable tool, i had used a paperclip and flathead for each side.. not effective.
then i suddenly realized that i could just pry the clips from any one side while lifting up on the harness until the teeth clicks up on the next highest thread.. then zig-zagging my way up, alternating sides until it came out.. duhh.. im stupid =(
ANYWAY.. so i busted out some power tools.. and filed the top part of the reverse lockout tab so that it tapers off.. then used a file to round and smooth the edge.. now, there is no contact with the tab and plate, and thus.. no struggle getting into reverse. Hooray!
Old Jun 14, 2006 | 06:29 PM
  #528
got mine. will install tomorrow or the next
Old Jun 14, 2006 | 07:59 PM
  #529
jeffe19007's Avatar
Got mine today also! Thanks!
Old Jun 14, 2006 | 08:36 PM
  #530
Ejay's Avatar
Got mine, installed it . will try it out tomorrow.
Old Jun 14, 2006 | 10:18 PM
  #531
i cannot understand how late you are on this mod....
hope to god you have synt oil in the tranny to feel the joy...
Old Jun 15, 2006 | 06:47 AM
  #532
willofgod's Avatar
dtorre, what did you grease it with?
Old Jun 15, 2006 | 08:39 AM
  #533
vIce^gRip's Avatar
Honor & Integrity
heheheeheheh...
I use RedLine in both Tran and Diff.
MT90 Tran -N- 75W90 Diff
It Roooocks... well along with RP's SS!
I will update the site in a few.. gotta head to work now... You all Always make me run late in the mornings!!!
Old Jun 15, 2006 | 09:27 AM
  #534
Royal Purple in tranny and differential.
Old Jun 15, 2006 | 09:30 AM
  #535
Genom's Avatar
Not so Super right now
Still hoping mine gets in before the weekend.
Old Jun 15, 2006 | 01:55 PM
  #536
very nice!! been out driving- no problems with reverse. itll take a few more drives before im used to it but its very very nice. install was easy after that first clip. thanks richard.
swoope et al- I HAVE NO MONEY even this has got me in hot water a little. im a stay at home dad with a very meager expense account
Old Jun 15, 2006 | 02:13 PM
  #537
No worries Zoom. If you come out for the next SevenStock, I'll buy the first round.
Old Jun 15, 2006 | 02:24 PM
  #538
oh im coming-bern says possibly the kabura will be there!
YOU READING ME MAZDA? IM COMING TO 7STOCK SO HAVE THE KABURA THERE!!!
Old Jun 15, 2006 | 02:51 PM
  #539
I will now use my Jedi Powers to decipher this message:
Translation: Bern has now confirmed to Zoom that there WILL in fact be a SS9!!
Hmmmm....maybe there will be a really cool Super Charged yellow RX-8 there as well.
Old Jun 15, 2006 | 03:17 PM
  #540
lesper4's Avatar
T-29 years and counting
oh great news, i am liking this.
Old Jun 15, 2006 | 03:37 PM
  #541
Unless of course Zoom is just referring to the BYOB bbq that we're throwing at Bern's house...
Old Jun 15, 2006 | 03:53 PM
  #542
exactly- its happenign whether it is or not
hehehe
bern did say yesterday in the kabura thread they almost have a date
Old Jun 15, 2006 | 08:00 PM
  #543
jdzoom8's Avatar
Just installed my short shifter tonight. The short throws are a big improvement! It is a little harder to get into reverse, anyone else have this issue.
Today I realized that I had already broken the infamous clip on the console by the e-brake when I took off the paneling for my PIE install. It made it much easier to remove the paneling with this clip gone. You wouldnt know it is missing unless you knew it was supposed to be there.
Old Jun 15, 2006 | 08:54 PM
  #544
MezMorada's Avatar
havent got mine yet...(sigh) Should of just drove down to the shop and picked it up...
Old Jun 15, 2006 | 09:33 PM
  #545
Richard Paul's Avatar
They are all in the hands of the USPO.
Anyone having a problem with reverse can file a little champher on the edge that goes under the lockout plate. Doesn't take much, just a little help to clear the edge when you push down on it.
This is due to the tolerence Mazda has on the hieght of the shifting tower. If it is a little low then you'll have this problem. Turns out that Mazda makes three part numbers of this part. The difference is in how high it is, there are three letter numbers stamped on these. At the factory they match shifter tolerence to the tower. This keeps them from having to scrap parts.
As you can see from the 60 shifters we have here that so far we have only 2 that need a little tuning.
There has been one that was so far out of tolerence that I had to remachine the tab 2mm lower. That was Spice Boys. His must have been one of the letter towers. It is the only one ever to be that way. It was then that Gomez looked it up and found out about the three different part numbers.
Old Jun 15, 2006 | 09:35 PM
  #546
i have no reverse issue but had difficulty finding 6th- its not right against the "wall" on that side. just a little in. just a few drives and ill be used to it
Old Jun 16, 2006 | 01:31 AM
  #547
it just take a while to adjust to the shift to sixth..
Old Jun 16, 2006 | 02:03 AM
  #548
takahashi's Avatar
I always fear that I could get to R with that move - but it is so unlikely to happen
Old Jun 16, 2006 | 10:31 PM
  #549
Hotsauce's Avatar
RRDI Member
Well I got mine today and I was able to install it this evening. Installation was a breeze, I knew what to expect after reading the DIY thread. After I slipped in the AF SS and bolted down the retainer plate, I thought Richard scammed us with a 4 speed shifter. I couldn't find 5th and 6th gear, but after a test run they were there to the right. It takes a little while to get use to it, I also had no problem getting into reverse
Man this shifter is **** man ****! I love the 1-2-3-4 shift, I can now downshift with confidence!
Old Jun 17, 2006 | 02:11 AM
  #550
MezMorada's Avatar
Got mine also and installed it today. 5th gear was hard to get into at first and i still have to get used to getting it into 6th. It grinded a few times but i still needa get used to the 6th... Love the shifter!
