Review : Knight Sports Final Drive 4.777 on 4AT...
Old Jul 27, 2006 | 09:48 PM
  #26
mkl22's Avatar
maybe the 4.777 final drive should have been standard from the begining. But i think the reason why 4.44 was used was for 0-100km/h timing. cause if 4.77 was used, the 2nd gear in the 6mt can't hit 100km/h and will require another gear change to 3rd gear and so the 0-100km/h will be slower and thus affect its "performance" timing. well this is the usual marketing strategy we usually see from car manufacturers.
Old Jul 27, 2006 | 10:25 PM
  #27
kennyyeo's Avatar
Gfoo, do u know which brand do final drive for RX8 beside Feed and Knightsport.
How much is the Knoghtsport one cost including install.
How long it take you to get it install?
Do you have to remove the diff at the back too ?
DO monster garage have stock now?
Sorry for asking too much
Old Jul 27, 2006 | 10:35 PM
  #28
gfoo's Avatar
Kenny, best is to email monsterg@singnet.com.sg or pm coupe07 for orders/price.
No, other than FEED or KS, no other final drive i know that's japan-made. The US folks are talking about using a Kia FD at 4.778 but i wouldn't even touch that with a barge pole. Others are talking about using the supra or something etc - do a forum search lah
It's a full day job, not easy to install. i left my car the night before and it was ready for collection mid afternoon the next day.
I don't think you will remove the whole differential - just replace the final drive gear bit.
I believe stock is arriving soon, best is if you check with coupe07
Old Jul 27, 2006 | 10:47 PM
  #29
coupe07's Avatar
SC 300HP!!
so long as they are rotary tuners, they shld have the final drive. Wat brand do u wan? U wan premium brand, then RE AMEMIYA. But u have to pay premium price.
final gear is not at the gearbox side. Its at the LSD side.
Stock wise, August.
Old Jul 28, 2006 | 01:24 AM
  #30
sqflyer's Avatar
Heavy Machinery Operator
I thought it will mess up with the actually speedo reading, is it? For example when you are traveling at 80 km/h your speedo will probably show 75 km/h
kennyyeo, I'm not sure where the speedo reading is taken from. I think it should be read as accurate as possible to the actual movement of the vehicle which means it should be at the wheels, therefore only changing rims/tyres/type pressure will affect the speedo reading. If it is read upstream of the wheels to the point where changing the final drive will affect it's reading, then it's probably going to be the opposite of your example; meaning the speedo will overread instead of underread. Eg. Actual speed 75km/h and speedo speed 80km/h. As it is, the speedo is already overreading by about 3km/h for my stock setup. Which also explains why the Gtech does not capture a 0-100 time if stopped exactly at 100km/h.
Are you absolutely sure that 4.777 final drive cannot reach 100km/h on 2nd gear? Don't misunderstand it as doubting your statement. It's just that I'm interested to know the real answer. If nobody has the hard facts, it's ok. Somebody will provide the answer or test it out soon enough.
Old Jul 28, 2006 | 06:22 AM
  #31
mkl22's Avatar
I think i found your facts.
http://www.artex.co.jp/Pages/CarLife...C_03_06_11.jpg
found this in one of the old posts.
after calculations, with 4.777 Final drive will be 94.8km/h
Old Jul 28, 2006 | 06:41 AM
  #32
gfoo's Avatar
mkl22....dead link
Old Jul 28, 2006 | 07:22 AM
  #33
EBS's Avatar
EBS
Bro sqflyer is correct. Stock car speedo will show higher speed than actual after the final drive. At lower speed (less than 100km/h) the diff will be around 5km/h ie speedo reading 100km/h actual around 94 to 95km/h. Speedo showing 130km/h, actual speed ard 121km/h etc.
This was the fig diff on my colleagues Cl7R when he had his FD done (diff ard 0.4 oso).
Cheers
Old Jul 28, 2006 | 12:40 PM
  #34
mkl22's Avatar
Originally Posted by gfoo
mkl22....dead link
fixed.
Old Jan 11, 2007 | 11:34 PM
  #35
mdw1000's Avatar
I'll snap his neck.
I realize i'm reviving an old thread here, but i'm thinking of doing this to my 4 speed AT with the GT package (LSD). Sounds like from the comments here, this wiill be a defininte improvement for 0 to 40 mph? I don't read the language that the road test is written end, so can someone summarize it for me?
I know you talk about gains, but how much of this is due to the final drive and how much is due to your ECU?
Thanks very much in advance!
Old Jan 12, 2007 | 03:19 AM
  #36
derekwcw's Avatar
Well, yes and no, maybe still boils down to the fact how the driver launches.
Seen auto 8s with Final Drive losing to stock auto 8s many a times, so how effective it is when installed, maybe good but maybe useless too I guess. But one things for sure, when on the move the pick up is slightly better.
As for ECU, not so much the power gains, think this been mentioned before, but more for turning the cooling fan earlier, smarter smoother gear shifting when on full auto, and maybe just slight improvment of fuel consumption.
Old Jan 26, 2007 | 05:47 PM
  #37
S2SEXY's Avatar
do you still have your stock 4.44's let me know what your asking,also i can get them brand new for $360.
Old Jul 12, 2007 | 11:08 AM
  #38
GRapify's Avatar
how do you launch an AT Rx8??
Old Jul 13, 2007 | 03:52 AM
  #39
drift_drift's Avatar
Isn't Speedo tie to wheels and not gear? How can changing final drive affects the speedo reading? Also 6MT with 4.777 should reach 100 by 2nd when hit 9500rpm... if tyre profile is not too much lowered.
Old Jul 13, 2007 | 12:22 PM
  #40
sqflyer's Avatar
Yes, speedo should be tied to the wheel, more specifically the rotation of the wheel and not the actual circumference of the wheel+tyre because there is no way the car can read a wheel circumference that is constantly changing. Therefore, changing a different final drive ratio does not affect the speedo other than having a different speed while in the same gear/rpm than before the change of the final drive (hope I didn't make it sound too confusing). If the 6MT with 4.777 final drive has a THEORETICALLY speed of 100km/h at 9500rpm on 2nd gear, that means it's impossible to reach 100km/h on 2nd because the redline is at 9000rpm unless you remove/over-ride the rev limiter/cut and risk blowing the engine.
Old Jul 14, 2007 | 11:44 AM
  #41
Vanquish's Avatar
Very tempted to try this final drive but seem to have conflicting reports... anyone can hazard an intelligent conclusion on this final drive, does it really does improve pick-up 0-100 or not??
No offence to anyone... Thanks!
Old Jul 14, 2007 | 12:59 PM
  #42
sqflyer's Avatar
I'm pretty sure it will improve your pickup, but because you will probably need another shift to 3rd gear to reach 100km/h, it will come down to your shift speed. Anyway, unless you race 0-100km/h for money, I think it should not be of concern.
Old Jul 19, 2007 | 04:16 PM
  #43
Vanquish's Avatar
Thanks bro!! much appreciated... forgot to mention my 4AT... any significant difference??
Old Jul 19, 2007 | 06:31 PM
  #44
mdw1000's Avatar
I'll snap his neck.
I should be picking up my car tomorrow with the new diff with the 4.77. Dropped it off at the mechanic's about an hour ago!
Old Jul 20, 2007 | 04:45 PM
  #45
Vanquish's Avatar
From Monster Garage?? Got stock already? Called last week no stock...
Is yours a 4AT or 6MT?
Old Jul 20, 2007 | 06:07 PM
  #46
mdw1000's Avatar
I'll snap his neck.
No, I am in the US. It is the FEED gear from JonDemand. Had the new diff built by mazmart in atlanta and then had a local mechanic install it.
Mine is a 4AT.
First impressions are pretty much the same as others have said. Revs faster, rpms are higher at a given speed and gear, acceleration is improved. Acceleration hasn't made a great leap or anything, but is definitely better. Time will tell if I decide it was worth the money
My total outlay for shipping, building, installing, etc is going to be right around 1600 USD.
My mechanic did say the diff swap was more time consuming than he thought it would be.
Old Jul 21, 2007 | 01:49 AM
  #47
mdw1000's Avatar
I'll snap his neck.
After driving it again, I'm starting to appreciate it more. It really makes it a fun car around town. Revs quite a bit quicker.
Old Jul 21, 2007 | 05:14 AM
  #48
Vanquish's Avatar
Thanks for sharing mdw1000!!
Old Oct 12, 2009 | 03:29 PM
  #49
JMKuco's Avatar
Rotary engine addict
UP !
Need more info !
I hesitate to add this to my car but want to know excatly what I gain and what I loose !
Old Oct 13, 2009 | 11:11 AM
  #50
mdw1000's Avatar
I'll snap his neck.
Your stock gear is a 4.44, so this is about an 8% lowering of your rear gear. Basically has the effect of making every gear lower. You'll gain some acceleration at the expense of top speed in each gear and a slight loss in fuel economy.
