Your iPod/MP3 Player Integration Solution is HERE!
Old Dec 4, 2005 | 02:39 AM
  #26
bigcynic's Avatar
Dension
How is this different then the Dension Icelink. Does it solve the power issues. I jave the icelink and find that I have to turn the headunit off before I turn off the ignition ot the ipod will not start when I turn on the ignition again. Sometimes I have to unconnect the ipod, then reconnect and turn on the headunit in order to get it to play. Does your unit solve these problems? If so, I am definitely interested. I would replace my icelink if so.
Old Dec 4, 2005 | 02:45 AM
  #27
truemagellen's Avatar
Attracts tree branches
Originally Posted by falcontx
No, the song/album information is not shown on the LCD. I think there are only like 8 to 10 characters available on the LCD anyhow. While in use, the LCD above your head unit will read "EX1" and a minutes and seconds timer will be displayed. On the iPod unit, the counter will reset to 0:00 when you change songs using the console or steering wheel controls, but will otherwise continue to count up as the music plays.
will you be adding this functionality?
is this the same unit from Taiwan that was being sold on the forums in spring?
Old Dec 4, 2005 | 03:41 AM
  #28
adrian-1's Avatar
Ex- member.
Installation simply requires access to the rear of the radio. I'll do a quick search for a good how-to on center console removal.
Installation instructions (from neocaraudio)
These instructions are pretty clear (the bolt on the side is a pain to get to).
The unit I bought from mp3yourcar.com doesn't have this problem.
Falcontx: Does our headunit have to be a certain version or above (like 9.55)?
Old Dec 4, 2005 | 12:52 PM
  #29
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Can this be used to change songs on a laptop? Or will it only work with an iPod?
Old Dec 4, 2005 | 12:53 PM
  #30
girliegirl has stolen my stolen avatar! oh well
Old Dec 4, 2005 | 01:50 PM
  #31
falcontx's Avatar
Those power issues do not exist with this unit. When you turn the car on, the unit instructs your iPod to play. When you turn it off, it tells your iPod to pause. You never have to disconnect your iPod or torn off your head unit if you don't wish to.
Old Dec 4, 2005 | 01:53 PM
  #32
falcontx's Avatar
No. Because we are using the external CD changer port, it does not allow this functionality. Any products that are able to provide such functionality must be connected via the TAPE/MD module port under the headunit.
I am not sure what has been sold here previously. I personally have not offered any similar products here before.
Old Dec 4, 2005 | 01:57 PM
  #33
falcontx's Avatar
I am not aware of any headunit version requirements. We have tested the unit on a 2003 Mazda 6, a 2004 Mazda 3 and a 2004 RX-8 and the unit worked fine on all of them.
Old Dec 4, 2005 | 01:59 PM
  #34
falcontx's Avatar
The iPod Integration unit uses a cable that connects to the bottom of the iPod. There would not be a way to connect it to a laptop.
Old Dec 4, 2005 | 03:03 PM
  #35
the 2004 RX-8 with headunit firmware lower than 9.55 needs to be upgraded for the cd changer auxiliary part to become remain active for input (what you are using)
Old Dec 4, 2005 | 03:23 PM
  #36
I saw the USB port and just thought that maybe it could control winamp or something.
Old Dec 4, 2005 | 04:37 PM
  #37
falcontx's Avatar
That's good to know. Is there a quick and easy way to identify the firmware version?
One other thing I was just told is that the factory satellite radio may also use that plug, in which case both the factory satellite radio and these integration units could not be used simultaneously.
Old Dec 4, 2005 | 04:55 PM
  #38
Gomez's Avatar
Shifty Bastard.
With the radio on, press and hold the "Text" and "1" buttons.
Old Dec 4, 2005 | 09:22 PM
  #39
Jabberwock's Avatar
Just wondering if a USB MP3 Player would power on when hooked up to the Audio Link. I have a USB MP3 Player I would like to use with this, which I also use as a flash drive, but wanted to make sure that the USB MP3 player would not power on when plugged into the Audio Link Module. I don't want the battery life to drain on maybe long drives.
Old Dec 4, 2005 | 09:40 PM
  #40
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Why couldn't you guys have released this a year ago and saved me $150 on Mazda's MP3 player?
When I eventually buy thel AVElectronics video switcher for my nav and a portable DVD player, the factory MP3 player will be pretty useless to me since I'll be able to burn DVDs with gigabytes worth of MP3s on them instead of being limited to CDRs with 800mb worth.
Old Dec 4, 2005 | 09:52 PM
  #41
falcontx's Avatar
If your MP3 Player will operate as a flash drive, then it will work fine with the USB MP3 integration unit. When your MP3 Player is plugged into your computer to be used as a flash drive, does it use any battery power? If not, then it will also not use any battery power when connected to the Audio Link unit. Most USB flash drives are powered by the USB port, so this is not an issue.
Old Dec 4, 2005 | 11:03 PM
  #42
BomberNYC's Avatar
This product has alot of potential... hopefully it works as advertised.. but one question i have is that is it possible to have the cable running from the Audio link (the black box) to the ipod be longer? Seems like you need to have the Audio Link box out in the open for you to connect your ipod in it. I myself dont have an ipod, i have to use the tape deck thing to get my dell mp3 player to work But i know alot of my friends like to play DJ and grab the mp3 player and work it from the back seat. Will this unit be able to reach?
Old Dec 4, 2005 | 11:13 PM
  #43
BomberNYC's Avatar
Another question... if i choose the usb unit, will i be able to hook up the ipod to the usb port of the unit (using a usb to ipod sync cable) and be able to control the ipod using the steering wheel? If thats the case.. that would solve the cable not being long enough for peopel in the back seat to play DJ in the car.
This is the cable i was reffering to:
Attached Thumbnails Your iPod/MP3 Player Integration Solution is HERE!-ipodminicable01.jpg
Old Dec 4, 2005 | 11:38 PM
  #44
falcontx's Avatar
Currently, the length of the cord is fixed. I had someone else mention the length of the cord as well, so I will definitely mention this to the manufacturer. The change may not be made immediately, of course.
If you put the iPod in "disk mode," it may be possible to use the USB unit to play songs from the iPod. However, the unit would simply be reading any MP3 files from the drive and playing them randomly, rather than actually interfacing with the iPod allowing the use of playlists, etc. It also would not play the Apple formatted files downloaded from iTunes, only MP3s.
Old Dec 5, 2005 | 07:09 AM
  #45
airspeed's Avatar
Velocity REight
PM'ed you regarding international order & shipping costs.
Old Dec 5, 2005 | 04:19 PM
  #46
girliegirl's Avatar
haha thats where i got it from...sorry well i finally got someone to put to down size my car to put on my avatar!! so its all yours now....thanks!! hehe
Old Dec 5, 2005 | 07:53 PM
  #47
dag's Avatar
dag
I bought 1 & got some sweet news
I asked them if they were coming out with something that would also let me connect a Sirius unit and here was their answer:
The iPod Integration Kit actually includes an auxilliary input alongside the iPod input. This auxilliary input could be used for an external satellite radio installation, such as Sirius. The unit switches automatically, depending on the source of sound. In other words, if you have the iPod playing and the external source turned off, you hear the iPod. Likewise, if you have the iPod turned off and the external source turned on, you hear the external source.
Hopefully this helps you out. If you have any further questions, please feel free to ask!
Donny
RPM
Sweet - now to find a place in my car for both and to start shopping for a Sirius unit.
Falcontx - this maybe worthwhile information to add to the beginning of the thread for new people who jump on and read this thread.
Edit - **** - I should read before posting - sorry
dag
Old Dec 5, 2005 | 08:59 PM
  #48
dazygirl415's Avatar
Originally Posted by PoLaK
anyone testing this know if perchance the cable is long enough to reach by the dsc off botton that way i could put my ipod in the change/cellphone holder below the buttons.
http://img235.imageshack.us/img235/4843/tiff27rk.jpg
note on a LHD not RHD
Or at least covertly to the glove box, http://media.mazda.ch/dossiers/RX-8/.../package11.jpg
or the storage box behing the cupholders?
http://media.mazda.ch/dossiers/RX-8/.../package05.jpg
With the current set-up of the wires, it plugs behind the HU, runs down the back and under the center console. This is where the little black box is hidden. There's a small black "plug" near the front of the cup holders. I have the wires coming out through there and the iPod sits in my cup holders. I do not believe the wires are currently long enough to run to the back of the hidden compartment and still allow enough slack for the driver to pull the iPod to the front of the car for use. I think the wires would be just shy to run to the DSC button area; it may be possible to run to the glove box. Donny has mentioned speaking to the manufacturer about longer wires.
Old Dec 5, 2005 | 10:50 PM
  #49
BomberNYC's Avatar
i really hope that they can make the cable longer.. or provide an extension cable of some sort.
Old Dec 5, 2005 | 11:35 PM
  #50
UG_8's Avatar
If this works for firmware lower than 9.55 than I will definately be interested....
