Speaker sizes, harnesses, kits, etc: audio install reference
Old Nov 21, 2005 | 08:37 AM
  #26
Shinka in MD's Avatar
some additions and corrections re: J-01 connectors:
Scosche Connectors:
www.scosche.com (there is another scosche website which has been abandoned and has very old info on it.... it is the one most often turned up when doing a search for 'scosche' so make sure you don't go to the wrong one!)
sales@scosche.com
Sales: (800)363-4490 ext.1
techsupport@scosche.com
Tech Support: (800)363-4490 ext.3
The connector that plugs into the car harness used to be p/n MA03, now re-named MA03B
The connector that plugs into the head unit used to be p/n MA03R, now re-named MA03RB
This is different from what you have posted above.
I have ordered these connectors from a local distributor and called back repeatedly and never been able to get one of the connectors, basically because the guy is a jackass and keeps saying he ordered them, but never has.
The manager at a local Circuit City said he could get these in a few days special order, but my Metra connectors had already arrived by the time I found this out.
Metra
www.metraonline.com
Sales/Manufacturing:
460 Walker St.
Holly Hill, FL 32117-2699
(800)221-0932
(386)257-1186
R & D / Marketing
3201 East 59th St.
Long Beach, CA 90805-4501
(800)944-6235
(562)634-9910
(562)634-9920
The connector that plugs into the car harness is a Turbowire 70-7903 - I paid $7.29 for these.
The connector that plugs into the head unit is a Turbowire 71-7903 - I paid $10.85 for these.
These are supposed to be available (special order, of course) from Best Buy and Circuit City according to Metra sales.
I got the name of the local distributor from Metra in Holly Hill. I ordered several of each gender so I enough pins to make a jumper harness between my head unit and Bose factory stereo, and tapped off BATT, ACC, and GRND from the harness for my Moto IHF1000 bluetooth handsfree adapter. I also added a pin for the MUTE function (pin L) going to the head unit (pin L). In addition I tapped off the PULSED DIMMER TNS+ and and INVERTED DIMMING signals to get some of the lighting for my add-ons to follow the instrument panel dimming.
BTW, 'PULSED DIMMER TNS+' (pin e) is somewhat of a misnomeras it is not pulsed at all. It is a line that switches to +12v when the light switch is either in PARK or HEADLIGHT position. When lights are switched off it is at 0V. It provides a +12v signal to indicate that some exterior lighting is on.
'INVERTED DIMMING' (pin g) is 0V when the panel dimmer is in the detent position. When it is switched out of detent and advanced a bit, a narrow 12v pulse starts at a period of approximately 5mSec (minimum dimming), and as the dimmer is advanced, the pulse gets wider until it is at 12v for 4.2mSec and at 0v for 0.8mSec out of the 5mSec for maximum dimming. This signal provides a varying pulsewidth Ov signal to the negative side of the panel lights.
Almost all of the info I initially got was from Stephen Fosketts' Miata website (many thanks Stephen, you saved me many hours of reverse-engineering time!!!), where J-01 has a pinout for a 2004 RX8 which is accurate for my 2005 model also, with the exception of some wires not in the harness because I don't have the navigation unit i.e. NAV: PARKING BRAKE pin k, NAV: REVERSE pin m, and a black/white wire at pin t. Strangely, there is a wire at pin h POWER ANT. This wire presumably signals when the radio is turned on, and could probably be used as a trigger to turn on an aftermarket amplifier.
Hope this helps someone else...
Old Nov 21, 2005 | 01:13 PM
  #27
Astral's Avatar
Purveyor of fine bass
Thanks, they added "B" to indicate "bag" from what I remember. I did wrongly list MA03B as the reverse harness, whereas I should've listed MA03RB. Info update, thanks for your info! I have also linked to your post for other information.
Old Jan 23, 2006 | 03:12 PM
  #28
needmorerotors's Avatar
is there ne replacement strereo faceplate adapters out for the rx.if so please let me know.
Old Jan 24, 2006 | 04:09 PM
  #29
jstkilntim's Avatar
resU deretsigeR
Just wanted to thank everyone for this great thread. I haven't been posting since I don't have an 8 YET and don't want to seem like a poser. I do however like to do my research before buying. I was very disapointed in the 8's audio/visual potential until I have read every last thread & post on this web site. I will be joining the ranks soon! Peace!!
Old Jan 25, 2006 | 10:25 AM
  #30
Asmoran's Avatar
Wow, nice information Shinka. However, I wouldn't use the power antenna lead to trigger an amp. Typically, this is only "on" when you're using the radio. If you switch to CD (or any other input), there's no voltage on this line, and your amp will shut off.
Old Jan 25, 2006 | 05:29 PM
  #31
ElPaco13's Avatar
Bite my shinny metal...
Originally Posted by ScudRunner
Right now, AFAIK, the only options for aftermarket HUs and keeping your A/C controls and display are to keep the stock HU in the car (at least portions of it) and make sure that the proper wiring still goes to those controls after the aftermarket HU is installed. In my case, you can go to this thread to see how I did my install. The wiring runs through the center console back to the A/C controls and LED readout. Eight months now and no problems with it. Devoid installed the same deck as I did, but they did something a little different with his stock HU. You'd have to ask him.
When they relocated the stock HU and installed the aftermarket HU did they just splice into the existing wires or did they use one of the harnesses mentioned?
Old Mar 13, 2006 | 02:12 AM
  #32
MrWigggles's Avatar
Originally Posted by Astral
  • Both HUs output differential speaker-level signals. Do not hook the HU signal directly to an amp's line-level RCA inputs. Instead, connect to a line output converter first or ensure that amp has speaker-level inputs. Otherwise, frying of HU may occur.
  • Some HU output analysis and LOC discussion
I'm the one of those who has been stressing that the signal between the Bose HU and Bose amp is speaker-level differential very similar the Non-Bose HU.
Well, 6 months ago when I had the first stage of my 5.1 system done, the installer tried mounting the Soundgate active LOC at the rear next to the Bose amp and got a good deal of noise. (The instructions say to put it close to the HU - this was probably his only mistake for the whole install.)
Well, as of this weekend, I finally got a chance to install the Soundgate at the HU and I have to say it works great - noise-free and clean. So you don't need to and probably shouldn't tap the signals after the Bose amp (with the wild EQ curve it applies). Tap the signal before the amp and use your speaker-level inputs on your amp or the Soundgate LOC.
This also means my install is finally complete and I should have a write-up with pics shortly.
-Mr. Wigggles
Ps. the Soundgate model is the LOCB.2: http://www.soundgate.com/index.php?r...&usereferrer=1
Old May 19, 2006 | 07:00 PM
  #33
slavearm's Avatar
Boost Junkie
I just hacked away =). The cables are too short anyways... ill take pics this weekend if you would like. Just PM me to remind me.
Old May 23, 2006 | 05:18 PM
  #34
mccomber's Avatar
Design Ninja
Only thing I've seen is this item from Corksport, bottom of the page...
http://corksport.com/store/category/...-interior.html
My question to those in the know for now is, can I just replace the bose speakers with regular old 4ohm speakers and not cook anything in the head unit? I have a basic understanding of how this stuff is supposed to work, but I'm still not totally sure. Eventually I want to do an amp, and will probably put in a sub soon (both using line level converters as mentioned several times) but can I just replace the speakers for now? Or will the lower power output because of the higher impedence make the difference negligible.
Old Jun 4, 2006 | 01:09 PM
  #35
geggatt's Avatar
adam
can anyone help me with how to hook up sub and amp to stock head unit and what are chooses to take out stock unit and put and aftermarket unit thanx
Old Jun 4, 2006 | 05:45 PM
  #36
redmaz8's Avatar
I love red
All you need is a convertor. You can get one at any audio store. I got mine at Circuit City. I took out the interior center console myself and was only charged about 30 bucks for them to hook up all teh wiring. But you can even do the wiring yourself. I ran the wiring down the center console. I just hope that the heat wont be a factor. I also hooked up an additional power wire to the 12V by the ash tray for a LED set up in the trunk.
Attached Thumbnails Speaker sizes, harnesses, kits, etc: audio install reference-head-unit-connector.gif   Speaker sizes, harnesses, kits, etc: audio install reference-pics-098.jpg   Speaker sizes, harnesses, kits, etc: audio install reference-pics-099.jpg   Speaker sizes, harnesses, kits, etc: audio install reference-pics-100.jpg   Speaker sizes, harnesses, kits, etc: audio install reference-pics-102.jpg
Old Jun 27, 2006 | 12:46 PM
  #37
unpocoloco's Avatar
Don't you know I'm loco?
Great thread! If anybody knows the power output of the head unit that'd be a good thing to add to the first msg.
Old Jul 12, 2006 | 08:28 PM
  #38
brtzrx8's Avatar
I noticed that the head unit harness (stock unit) only has wires for the front and rear speakers. Does anyone know how the tweeters are connected? Are they wired elsewhere in parallel with the front speakers?
Thanks in advance...
Old Sep 10, 2006 | 03:47 AM
  #39
great thread!
quick question: I noticed the front bose tweeters are 2" but seems like lots of people are replacing with 1" Infinity Kappas? Does that sound right?
Also: how hard is it to get that 4" to fit in the center? Should I just get the 3" infinity?
Old Sep 11, 2006 | 08:22 AM
  #40
Ice Doctor's Avatar
Howzit....anybody got pics of their installs??
Old Nov 6, 2006 | 12:12 PM
  #41
tomf's Avatar
seems like a line output converter is not needed for the base radio if you have speaker level inputs on your amplifier. The summary at the beginning of this thread says you need one, so there should be another option there.
Also the mention of using lexan (or whatever) to make 6x8 -> 6.5 speaker adapter plates can be avoided by purchasing a pair of Scosche SA68 brackets for only $8 (+ shipping). I have not actually bought these yet- I figured I would suggest it and see if anyone knows for sure that they fit.
I started a thread about the LOC vs. speaker level inputs and locations to tap into the stock HU outputs (for the BASE radio.. this info is everywhere for the bose one) if anyone wants to comment on this
Old Jan 10, 2007 | 03:40 PM
  #42
firebirdude's Avatar
User and Abuser
A link to the www.whatsmyip.org/ipodrx8 should be noted in the first post.
Also, a complete list of all the available options for adding an AUX or MP3 unit. (ie Icelink, Audiolink, Mazda OEM, etc)
Old Jan 10, 2007 | 04:14 PM
  #43
Astral's Avatar
Hey, I don't have much time these days, if someone could PM me the set of links to the different AUX/Ipod integration options like firebirdude describes, I will gladly paste that into the sticky.
Old May 8, 2007 | 11:32 AM
  #44
User and Abuser
Some notes for ya.... in the thread linked for running power wire through the firewall...
1)StealthTL says there is a large grommit next to the washer fluid and advises to use this. Seems like it would be best of both worlds. Short and no drilling required. EDIT: Just tried to use this path for my own install. While I was able to squeeze a coat hanger through there, no way in hell was 4awg power wire fitting through there. I used the bottom passenger side tube as my guide. If you dig your fingers in there, you can feel the opening through the firewall. No way. If you're reading this StealthTL, which of the 4 pipes did you squeeze along side? EDIT: Stealth just PMed me back. He was able to get 8awg through there. So this is an option for those using 8awg.
2)Supra0083 notes that people with a Bose system can use an acc lead right off the bose amp. No need to tap into the seat heater controls. EDIT: I've just searched for this wire and I have no such thing on my Bose harness. Measuring with my DMM at the Bose harness, I noted that the yellow/white and pink/black wires are hot only when the key is in the acc mode. Makes no difference if the headunit is on or not. Anybody know what exactly these two wires are for?
Both of these, if indeed are true, should be noted in the first post of this thread. They are both superior ways of doing an install in the 8.
Old Jul 25, 2007 | 06:16 AM
  #45
auzoom's Avatar
Hmmmmmm.........
Astral, can you add to the 1st post the corksport link http://corksport.com/store/category/...-interior.html and this one http://www.kanack.co.jp/english/TBXE/tbxe_t003.html which can be bought from japanparts (I think they are the same part but anyway).
Old Jul 25, 2007 | 10:00 AM
  #46
Astral's Avatar
OK, added! thanks for the tip!
Old Jul 26, 2007 | 05:37 PM
  #47
canaryrx8's Avatar
Would it be possible to get the pinouts for the other harnesses behind the radio? An installer friend and I are trying to devise a cheaper "magic box" so we can lynch the radio and still have a/c w/o having to keep the boards connected or whatever. I've looked all over for this with no luck, anyone have any ideas? I hate to buy an entire wiring book just to get one small piece of the puzzle.
Old Aug 9, 2007 | 08:37 AM
  #48
auzoom's Avatar
Hmmmmmm.........
OK just got HyperRev 110 and found the following.
canaryrx8 if your japanese is good the feast kits have some details about doing that.
http://www.feast-power.com/rsf/parts/rx8_audiokit.htm
http://www.feast-power.com/rsf/parts...a_audiokit.htm
http://www.beatsonic.co.jp/adapter/aok/aok-12.php
http://www.rmagic.net/catalog_all/pd..._catalog_2.pdf
Old Aug 20, 2007 | 08:28 PM
  #49
User and Abuser
???? So people don't continue to tap into the rear cig lighter...?????
And again, really believe http://www.whatsmyip.org/ipodrx8/ should be included in first post. Perfect walkthrough on headunit removal.
Old Aug 20, 2007 | 08:56 PM
  #50
auzoom's Avatar
Hmmmmmm.........
I used that to help me get started but struggle dto get the clips off. As a result I took a bunch of pics, including what the clips on the back look like. Unfortunately they are a bit blurry http://s144.photobucket.com/albums/r...veRX8HeadUnit/
Andrew
