Snow
Old Aug 19, 2005 | 02:10 PM
  #26
crisis's Avatar
Originally Posted by Vazoom
I've read the thread and would appreciate any definitive advice for purchasing tires/wheel for use in a Missouri winter. It seems like snow tires might be overkill here, but has anyone driven successfully through a winter on all-season tires? My commute just changed from 3 miles to 37 miles. I can't walk to work if it snows. My Potenzas are worn. Please help me decide.
I want to know as well, although I live in DC, I keep getting mixed responses. Some say snow tires are a must, others say good all season are fine too. I now leaning more towards good all season tires for this winter to see how well they do.
Old Aug 23, 2005 | 08:21 PM
  #27
High Revving's Avatar
i have to agree do not drive in the snow unless the streets are cleaned 100 percent the slighest bit of salt can make you skid out and kill urself
Old Aug 23, 2005 | 08:31 PM
  #28
D2RX8's Avatar
Snow tires in North Carolina? Last year it snowed one day... year before that maybe 3.
It hangs around for about two days... does that mean I won't be able to go anywhere for two days?
I'm not too excited about spending $1k for a few days of usage
Old Sep 7, 2005 | 09:15 PM
  #29
yandrs's Avatar
Originally Posted by connor@tirerack
You can use either 215/55/17 or 225/50/17 and still maintain the overall diameter. There are several tires you can use in these two sizes but in my opinion the best tire is the Bridgestone Blizzack LM-22 (161.00 each). I have also listed several other snow tires in thes fiitment.
Curiously, how many miles do you think you can get on any of these tires in the winter when (in Chicago) you have a fair combo of dry, wet, & snow Nov to March? If I drop $1200 on tires, how many seasons can I expect when I'll only be puting 1000-2000 miles during the season.
Old Sep 8, 2005 | 10:54 AM
  #30
connor@tirerack's Avatar
Forum Vendor
Snow tires are rated by "seasons used" not by mileage due to the fact the conditions that you drive in will affect the tread life of the snow tire. Basically the colder the weather and the more snow you are driving on, the longer they will last. The warmer the weather and a lack of snow (more clear pavement) will cause the tires to wear faster. I have heard of people that live in the northern midwest running blizzacks for 5 winter seasons and people who live in southern midwest states getting 2-3 winter seasons due to a much lower volume of snow.
Regrettably you are at the mercy of the weather as to how long the tires will last. The down side is when you decide your area doesn't get much snow and you decide not to get them. That is the winter that you will end up getting a huge snow storm and will end up being stranded.
Old Sep 8, 2005 | 12:36 PM
  #31
willhave8's Avatar
FWIW -- I purchased a set of 17" Konig wheels and the Dunlap Winter M3's (235?\50) last year from TireRack. Tirerack was superb. Helpful in my decision making and fast service.
I put ~6K miles on the tires in NE PA. Moderate amount of snow and it rarely is on the roads for more than the storm itself. They show no visible signs of wear on them. I am quite confident I will get two more seasons out of them at this pace. Although, I understand that while they will have tread on them, their absolute snow effectiveness decreases since the rubber compound deeper in is different and gets less effective.
Bottom line, I am satisfied that my $1M was well spent. I was able to get home from work four times that I otherwise would not have.
Old Sep 28, 2005 | 11:30 AM
  #33
Forum Vendor
16" wheels will not fit the touring model RX8 due to the calipers. However you can down size to 17". The 16" would hit the caliper. When you are ready just give me a call and i would be happy to discuss your options with you.
Old Sep 28, 2005 | 08:22 PM
  #34
Roto8's Avatar
Klatu Virata Nictu
Here is a question. I have only 1600 miles on my tires that are stock, can I.....
A. Use these in the winter in Albany NY and still get around?
B. Get only rear SNOW tires?
C. Must I get all 4 replaced with snows for the winter?
Old Sep 28, 2005 | 11:17 PM
  #35
vectorwolf's Avatar
Totally confuzzled...
^Just a personal suggestion, but I'd REALLY reccomend against going with two rear snow tires on this car. Problem being, our car, unlike the majority of other vehicles on the road, does NOT come with all-seasons. It has no-compromise summer tires, that perform well only on dry/wet pavement. I actually did the rear-only snows on my last car ('97 Miata) and it was a tank. Only got stuck once in 3 years of ownership (ironically, it happened when I was helping another Miata driver get going... lol). But, it had a really nice set of all-seasons...
If you get rear snow tires on the 8 with factory tread still on the front, you'll be able to take off just fine, but the front tires will basically become an expensive set of snowshoes. In even light snow, you'll have absolutely no directional control, and will not be able to properly slow or stop the vehicle.
Old Sep 29, 2005 | 08:33 AM
  #36
Roto8's Avatar
Klatu Virata Nictu
hmmm, sounds fun. Well what about just getting rid of the factory tires all together, and getting a good set up All Season Tires? I have been doing some research and for All Season, these came out on top? Any feed Back
Bf Goodrich g-Force T/A KDW NT
PS Anyone need and extra set of stock Potenzas ONLY 1600 miles on them
Old Sep 29, 2005 | 08:55 AM
  #37
BlueRenesis82's Avatar
Registered Tracker
You will kill yourself in snow with the stock tires! Get 4 snows or excellent allseasons or a 4wd winter beater
Old Sep 29, 2005 | 12:07 PM
  #38
Forum Vendor
The Tire Rack will not sell snow tires in pairs due to liability issues with the DOT. Due to a law suit several years ago against Les Schwab tires, the DOT changed their guidelines on snow tire stating that if you are using snow tires then they have w to be used in a complete set of four.
The reason for this is because even if you have snow tires in the rear to get you moving but none in the front you still may not be able to steer. the same rule account for front wheel drive cars. if you have snow tires on the front of the car but not in the rear you will increase your traction levels for speeds under 20mph. However if you are going around a corner or have to perform emergency braking, what is going to keep the rear of the car from sliding around.
Trying to drive with only two snow tires is not only dangerous for you but also dangerous for the people around you.
Old Sep 29, 2005 | 12:56 PM
  #39
Roto8's Avatar
Klatu Virata Nictu
Well that answers that question. What about the all season tires that I listed above. The BF Goodrich g-Force T/A KDW NT. Any feedback on those? Thanks
Old Sep 29, 2005 | 01:05 PM
  #40
Forum Vendor
The G-force T/A KDW (D-dry, W-wet) isn't all season. it's a summer only tire. The all season tire would be the G-force T/A KDWS (D-dry, W-wet, S-snow) which i do not show in the 18" sizes for the 8. I would say the most popular all season tires for the 8's are the 225/45R18 Avon Tech M550 A/S which are 136.00 ea and the P245/40R18 Pirelli P-Zero Nero MS which are currently 151.00 each.
Old Sep 29, 2005 | 01:24 PM
  #41
Roto8's Avatar
Klatu Virata Nictu
Which one would you reccomend? You think I could sell my Potenza'a on ebay?
Old Sep 30, 2005 | 11:10 AM
  #42
Forum Vendor
If you plan on using them in the snow i would recommend the 225/45/18 Avon tires. The Narrower tire will cut through the snow better than the 245/40/18 size tire.
Old Oct 6, 2005 | 02:28 PM
  #43
Former A4'er's Avatar
WTF?
Hi Conner,
I have a set of really nice snow tires from my last car in 225/45 R17, would these fit the 8 and if so do you have wheels?
Thanks!!!
Old Oct 6, 2005 | 03:06 PM
  #44
Forum Vendor
Technically, if you wanted to use the 225/45/17 on your 8 you could. the maximum load capacity of the tire meets the minimum load requirement by Mazda. Because they are almost one inch shorter they would throw off the speedometer and the odometer, the shorter side wall would make the tire stiffer than the factory recommended size which would make the tire stiffer and reduce snow and ice traction. You would also need to run these at a minimum of 36 psi to meet the required load capacity for the RX8. The extra air pressure in the tire would cause the tire to wear unevenly. Personally i would not recommend using it.
Old Oct 6, 2005 | 03:33 PM
  #45
RA-Eight's Avatar
Scuderia
Connor,
I have a similar question, but the tires I plan on using is a little taller. I got a set of Michelin Winter at an unbelievable price that I'm willing to deviate from OEM specs. The tire size is 225/55/17 on 17x8 wheels. Thanks in advance for your help.
Ra
Old Oct 6, 2005 | 03:53 PM
  #46
WTF?
Thanks for the info! I guess you will be seeing a order from me for some M3's in the next week or so.
Old Oct 6, 2005 | 04:08 PM
  #47
WTF?
Are these the M550?
Old Oct 9, 2005 | 02:45 PM
  #48
Roto8's Avatar
Klatu Virata Nictu
Connor,
I am looking to purchase a set snows and 17" rims from somone. They came off an
RX-8. What do you think of these Tires? Bridgestone BLIZZAK LM-22 WS-50 215/55 R17
Old Oct 12, 2005 | 09:56 AM
  #49
Forum Vendor
Connor,
In my opinoin the LM-22 are an excellent tire and the best snow tire for a performance oriented vehicle. However the LM22 are not made in a 215/55/17, the WS50 is though. The WS50 offer excellent ice and snow traction but they do tend to have a loose or squirmy feeling on dry pavement.
Old Oct 12, 2005 | 10:04 AM
  #50
Forum Vendor
Originally Posted by RA-Eight
Connor,
Ra
I could not say for sure if the 225/55/17 (26.7" tall) would fit without rubbing. the correct size would be 225/50/17 ( 25.9" tall). the tire would be almost an inch taller and under suspension compression or when you are turning, the tires may rub. Regrettably i cannot give you a definite answer on this one.
