ECU Clear/ Reset
Old May 14, 2005 | 04:34 PM
  #26
MazdaManiac's Avatar
Ahh. That is not the "after repair" procedure. That is the confirmation procedure.
The official after repair procedure requires the WDS.
It is a good way to verify the repair of a CEL event, but normal driving will do the same thing.
Old May 14, 2005 | 04:53 PM
  #27
Charles R. Hill's Avatar
Owner of BHR
Well that's all I've got, Man. The strange thing is that I have no cat and have been fine tuning my nitrous all day and STILL no CEL. Not even a blink. I'll take that.
Any ideas on the effectiveness of the actual "after repair" procedure with regard to some of the issues experienced by us around here?
CRH
Old Jun 21, 2005 | 12:28 PM
  #28
Nubo's Avatar
Lubricious
Does resetting NVRAM and KAM get rid of things like "you redlined the car X number of times", etc?
Old Jun 27, 2005 | 12:57 PM
  #29
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Old Jul 1, 2005 | 11:10 AM
  #30
pcimino's Avatar
Originally Posted by Rotary Rasp
I think he's worried the dealer will use the data to say something like "you exceeded the recommended number of warrantied redlines"
I doubt it, anyone know if there any CEL codes for redlining?
Old Aug 5, 2005 | 03:47 PM
  #31
davefzr's Avatar
Originally Posted by MazdaManiac
Well, I do it when I am experimenting with different tunings on my E-Manage or when I want to compare to the OEM tuning.
You can also do this to clear a CEL/MIL.
What if this procedure does not clear your CEL? I performed this procedure a few days ago and my light is still on.... Are you sure it's supposed to remove an active CEL light?
I'll try it again to make sure I did the procedure correctly.. BTW, I am on an old flash.. I think it's before M even...
Old Aug 6, 2005 | 12:59 AM
  #32
davefzr's Avatar
Nope didnt work.. I still have the CEL. The only procedure that has worked is to disconnect the battery for an hour....
Old Aug 6, 2005 | 11:31 AM
  #33
get a scanalyser or a canscan and read and clear the cel yourself. CEls do turn themselves of after a number of drive cycles withotu the problem re-occuring . unless it is really serious. if it doesnt go away you might want to findout what it is
Old Aug 16, 2005 | 06:40 AM
  #34
valpac's Avatar
Ahead of its time
A read of the following TSB says that brake pumping resets the NVRAM and I believe that the hold odometer button resets the KAM.
http://www.finishlineperformance.com...7-04-1298b.pdf
The procedures were previously posted in reverse.
Old Jan 3, 2006 | 06:04 PM
  #35
chikmag382's Avatar
I'm sure everyone is sick of stupid questions but what exactly is the CEL light. What's the acronym stand for and what is the purpose of it. If it comes on when you put on a catless midpipe then why would it go away if you leave the midpipe on there and continue to have to catalytic conversion?
Holla at your boy,
Whitey
Old Jan 3, 2006 | 06:08 PM
  #36
chikmag382's Avatar
....no catalytic conversion.....not (to catalytic conversion)
sorry for the typo
Old Jan 3, 2006 | 08:02 PM
  #37
Tamas's Avatar
Registered Lunatic
Check Engine Light - it will be illuminated if the PCM recognizes an error in one of the signals it gets from various sensors and stuff. It will also store a code (or multiple codes) that the dealer can use to diagnose the problem.
Old Jan 5, 2006 | 01:42 AM
  #38
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
good definition of CEL
Old Mar 2, 2006 | 12:54 AM
  #39
Like Whoa's Avatar
Nope shouldnt be, unless theres a misfire or some other type of problem then it'll be stored in the freeze frame data (data that is saved at the time of problem)
i dont know why you would want to reset your ECU tho (besides clearing codes) its got your adaptives saved in it. raadracer, your airbags are wired diffrently to another power source (or the info is saved somewhere else i forget) so if you disconnect the batt, it will not lose the airbag update.
Old Mar 19, 2006 | 10:54 AM
  #40
needmorerotors's Avatar
how do u know what falsh you are on mazda never told me any thing about flashes and nothin on paper work either
Old Mar 19, 2006 | 02:11 PM
  #41
Go48's Avatar
Have you had the gas tank recall done? If so, you almost certainly have the latest PCM update. If you really want to know what it is, have the PCM scanned by someone with a CANbus scanner. Try AutoZone or one of those places, but makesure the scanner they use is CANbus-capable. Or purchase a sCANalyser setup for $250+USD.
Old Mar 21, 2006 | 03:47 PM
  #42
When i reset my ecu does it still have the flash
Old Mar 21, 2006 | 04:08 PM
  #43
Go48's Avatar
Tutorial: In this forum (and in computerese generally), the term "flash" refers to the process of updating the PCM (aka, ECU) software by rewriting the firmware in a solid-state device in the PCM. Once the PCM is "flashed", the "flash" does not remain in the PCM.
Answer: When the PCM is "cleared", the basic software resident in a solid-state device in the PCM is unaffected.
Old Mar 22, 2006 | 02:10 PM
  #44
You should of used more idiot terms but I get what your sayin. Thax
Old Mar 22, 2006 | 05:42 PM
  #45
Go48's Avatar
I'll remember that next time.
Maybe I should write a book: Flashing for Dummies. ........Well, maybe not.
Old Jun 11, 2006 | 05:39 PM
  #46
redcivic's Avatar
Guns, God, and Country
How do I find out what recalls my car has had? I bought the car used and I took it to the dealer to get the visors replaced and the dealer I took it too (brand new dealer closer to house) said no because they had already been replaced and had all the recalls done? So I took my car to the dealer I bought it from and they replaced the visors and said the other dealer was full of **** about them being replaced before. So is there some dealer network or was the first dealer just being prickish?
Old Jun 11, 2006 | 06:49 PM
  #47
Go48's Avatar
Stick with any good Mazda dealer you find. There is a great disparity from one to another it seems.
There have only been 2 or 3 actual recalls on this car, but there have been several tens of service bulletins. To find out if there are any outstanding recalls on your car, call Mazda North American Operations at 800-222-5500 and ask them to check. You will need to provide your VIN. Keep in mind that most recalls are safety-related and dealers are bound to carry them out per the manufacturers agreement with the government. Service bulletins are not usually safety-related and dealers sometimes must be convinced that a particular issue exists before they will agree to effect repairs. Like I said, if you find a good dealer, stick with them.
For most of the service bulletins issued on this car go to:
http://www.finishlineperformance.com...ins_index.html
You can check your VIN against the VINs in the bulletins to see which ones apply to your car and if you think you have any of the issues, print out the service bulletin and see your dealer.
Old Jun 11, 2006 | 09:05 PM
  #48
redcivic's Avatar
Thank you sir!
Old Jun 13, 2006 | 06:14 PM
  #49
btw dont call 800-555-2200 with a speaker phone at work
Old Jun 13, 2006 | 06:17 PM
  #50
redcivic's Avatar
Why?
