Rims that takes TPMS
Old Jun 9, 2004 | 09:57 PM
  #26
cortc's Avatar
19" Axis hiros take the sensors no problems...
Old Jun 12, 2004 | 09:22 AM
  #27
cortc's Avatar
Most one piece wheels take them, some multi piece... It has to do with the angle of the valve stem mounting hole and the shape of the wheel behind it...
Old Jun 14, 2004 | 04:42 PM
  #28
MrWigggles's Avatar
cortc,
Yes, according to Tirerack most wheels do take them. It is strange that the Mazaspeed wheels don't take them and they are one-piece, correct?
-Mr. Wigggles
Old Jun 17, 2004 | 10:34 PM
  #29
cortc's Avatar
Thats what Mazda says, but I have heard they do work...
Old Jun 18, 2004 | 06:21 PM
  #30
BigOLundh's Avatar
#1 Legend
what is a TPMS Sensor?????
Old Jun 18, 2004 | 11:23 PM
  #31
rx8cited's Avatar
Try this:
TPMS Service Bulletin. The sensors go into each wheel and are also called wheel units.
rx8cited
Old Jun 20, 2004 | 08:30 PM
  #32
spank1's Avatar
they work with ssr wheels
Old Aug 4, 2004 | 03:15 AM
  #33
MazdaManiac's Avatar
To disable the TPMS, go to this thread: https://www.rx8club.com/series-i-do-yourself-forum-73/diy-disabling-tpms-35708/
Old Aug 15, 2004 | 06:03 PM
  #34
Rob Tomlin's Avatar
Glad to see they will work with Axis Hiros....currently at the top of my list for aftermarket wheels.
Old Aug 19, 2004 | 07:04 PM
  #35
TORacing's Avatar
can't we just trash the TPMS, it's not even right half the time. Almost every morning last month they went off because my garage is at like 67 F and outside it was like 98 F and when I pulled out of the garge the TPMS went off and each time i checked it and they were all at 30psi. Is there anything wrong with trashing them when I get a new set of wheels?
Old Aug 19, 2004 | 07:28 PM
  #36
rx8cited's Avatar
Sure, you can trash the TPMS! Have the sensors removed and re-balance the wheels(optional if you want to save weight), and/or follow MazdaManiac's post on how to disable the TPMS light :D.
From what you've described, I'm betting your TPMS is working fine, but first: After you pulled out of your 67 deg F garage, how many minutes and miles of driving did you do before you checked the tires and read 30 PSI?
rx8cited
Old Aug 19, 2004 | 07:31 PM
  #37
paul yaw designed his wheels for proper fit of the tpms.
Old Aug 31, 2004 | 01:13 PM
  #38
connor@tirerack's Avatar
Forum Vendor
Rather than typing pages of wheels that will work with the OE TPMS sensor you can click on the link below and be able to see the wheels that Tire Rack carries for the RX8 on your RX8.
http://www.tirerack.com/a.jsp?a=AC7&url=index.jsp
Old Sep 5, 2004 | 09:05 AM
  #39
wakeech's Avatar
mostly harmless
...knowing that almost no one will click that link unless they think the wheels "look cool", here is a pic:
these are a performance wheel, 3 piece, price is around $600 or so. mega strong, mega light (i forget the exact number, he did tell me a good long time ago).
Old Sep 19, 2004 | 02:34 PM
  #40
philodox's Avatar
Rangers Lead The Way!
I have Mille Miglia EV-R in 18x8 front and 18x9 rear.. They accept the TPMS stems. Here is a pic
Old Nov 2, 2004 | 06:54 PM
  #41
RX-9's Avatar
T rue P re M enstrual S yndrom.
Very common, in most gases you cannot do anything about it!
Old Nov 2, 2004 | 06:55 PM
  #42
RX-9's Avatar
..cases..
sorry to confuze you!
Old Nov 11, 2004 | 05:00 PM
  #43
Dinhx8's Avatar
My Rex goes to 11!
I just ordered my winter tires and rims, and decided not to deal with TPMS transfer, as when i put my summer rims back on in a few, ill have to deflate the stock tires, put the TPMS back on, and re balance right? Ill just have to deal with the light- Im pretty sure this is correct- but my main question is, is there any way to 'turn off' the light and deactivate? the above link didnt work if anyone has that if they can repost the link it'd be great. Thanks
Old Nov 12, 2004 | 01:37 PM
  #44
jesse@ptp's Avatar
How much is the option for the tpms sensors from tire rack????
Old Nov 12, 2004 | 02:48 PM
  #45
VividRacing.com's Avatar
There is a great deal going on right now for some SSR Speedstars In the vivid racing section these rims will not mess with the TPMS and there for an awesome price!
Old Dec 27, 2004 | 10:57 PM
  #46
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
Originally Posted by Omicron
Sorry, but you are mistaken, most rims will NOT take the TPMS sensors. These are little "boxes" on the inside-wheel side of the valve stem, and the wheel needs to have either a "niche" to take it, or at least a flat enough surface that it will mount. Try to put them on incompatible wheels and they will either not mount at all, leak, or come off at speed - which would result in a rapid decompression of the tire... not a good thing.
Are those what those lil boxes are....i thought so.....ahh mine are coming off the tire and most are sliding out of place.....would the dealer fix this for free
Old Jan 8, 2005 | 09:37 AM
  #47
pjr's Avatar
pjr
Originally Posted by rx8cited
... I guess you're prepared to deal with the flashing TPMS warning light that will happen after the sensors are removed....
Sorry for the noobie to RX-8 question (had the car for 3 days) ... so, if I put on different wheels and tires without the sensors, the only issue is anaannoying dash ligh, right? No buzzers, or anything else?
Old Jan 30, 2005 | 04:32 PM
  #48
\\Konig\\'s Avatar
turrrbo!
does anyone know if the RO_JA R2-5 Mercury wheels will take the tpms sensors? Thanks in advance.
Old Jan 31, 2005 | 06:18 AM
  #49
rx8cited's Avatar
Sorry for the late response. I'm just seeing this today. Yep, you're correct based on my understanding ........ flashing TPMS light only, no buzzer.
Old Jan 31, 2005 | 02:29 PM
  #50
Fanman's Avatar
I'm putting the 19" Stern Touring Sport II's on my car soon. Anybody know if it will accept the TPMS ?
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
