Series II ECU Tuning
Old May 21, 2010 | 04:57 PM
  #26
Benz05ZZ's Avatar
I drive an '09...
^^ Anyone? ^^
Is the pinnout for the ECU even the same?
Old May 21, 2010 | 05:42 PM
  #27
Brettus's Avatar
Boosted Kiwi
Originally Posted by Benz05ZZ
EManage Ultimate? INT-X? Something is better than nothing...
I sent an email off to the guy who develped the Powermod I used to use to see if he can help.
Old May 23, 2010 | 12:15 AM
  #28
very smart shot in the dark!
Old May 24, 2010 | 07:07 PM
  #29
Brettus's Avatar
Boosted Kiwi
Assuming the crank angle sensor is the same , the Powermod guy seems to think it would work .
As far as pinouts go he has not tried it so does not know if they are the same .
I do know where there is a unit that could be cheap enough to use to test out ......
Old Jun 2, 2010 | 02:01 PM
  #30
ASH8's Avatar
Super Moderator
Crank angle sensors are the same...Mazda Part Number, so I they are the same...
Over to the smart asses who want to argue they are different.
Old Jun 16, 2010 | 05:29 PM
  #31
Psylence's Avatar
Back in the family
Is the ecu used in the S2 that much different from the S1? Sure, they probably changed pinouts or something just to **** with people... but is the ecu model different? Are there different sensors in the S2 than the S1?
Old Jun 22, 2010 | 12:41 PM
  #32
paulmasoner's Avatar
Asshole for hire
yes
Old Jun 22, 2010 | 12:50 PM
  #33
ilikecars's Avatar
i know this would be a year away, but is there a possibility that the rx9 and rx7 will have a similar ecu setting? if the ecu is similar maybe cobb will rethink accessport for our s2. is there any possibility of this happening?
Old Jun 23, 2010 | 08:58 AM
  #34
Psylence's Avatar
Back in the family
Just like the RX7 continued to sell in Japan... the RX8 or something with the S2 Renesis will probably be sold until a global rollout of a new model. The most likely place to look for any sort of ecu mods for this engine will be Japan. Which will make setup, installation and tuning less than pleasant!
Old Jun 23, 2010 | 08:11 PM
  #35
ilikecars's Avatar
FL
i would like to go the turbo route in the future depending on how the future plays out (hell if i kno) so im assuming ill have to go w/ a standalone, but i have no idea what id be doing so id be looking for professional (experienced rotary tuner) help. still hoping cobb will change their mind (unlikely). besides, anything JDM will require modifications to the wiring harness and other stuff i dont know about (correct me if im wrong. i like correction because its a chance to learn). haltech has some good stuff so if anyone has experience let me know what ill be looking at.
thanks in advance
Old Jun 27, 2010 | 05:53 AM
  #36
Psylence's Avatar
Back in the family
Full standalone is a serious serious hassle. And if you have to pass any sort of emissions tests/inspections where they plug into the obd2 port you are boned. The port just does not work with standalones.
After having a Motec M4Pro on a Subaru for a bit... I never want to deal with that again.
Old Jun 27, 2010 | 05:34 PM
  #37
ilikecars's Avatar
are there any other ways to do this other than going the standalone route?
from what ive read, a piggy back could work but is not preferable since it cant handle ignition timing very well. is it possible to run something in parallel a possibility?
i have no idea what that would entail. and i dont need to worry about emissions.
Old Jun 27, 2010 | 11:12 PM
  #38
Brettus's Avatar
Boosted Kiwi
/\ pretty sur the power mod would do it if someone wanted to invest the effort into it .
Old Jul 4, 2010 | 01:04 PM
  #39
Asshole for hire
yeah, but if anyone cared that much brettus we'd have MS and half a dozen other options confirmed to work by now.
Old Jul 12, 2010 | 04:11 PM
  #40
reddozen's Avatar
Gold Wheels FTW
wouldn't the FSM show you the pin-out?
That I would think would be the easiest way to tell the difference.
Old Aug 4, 2010 | 06:07 AM
  #41
edi.ckv's Avatar
Ecu
Cant we just replace our ecu so that we can do tuning to our car ?
lol ~ just some silly thought
Old Aug 4, 2010 | 09:08 AM
  #42
yiksing's Avatar
the giant tastetickles
If you can afford it, why not
Old Aug 4, 2010 | 09:55 AM
  #43
edi.ckv's Avatar
is it expensive ?
i heard alot ppl saying " change ur ecu , this and that .. can make ur car go faster "
does it means by really changing ur whole ecu unit ? or just the ecu chips ?
Old Aug 4, 2010 | 09:18 PM
  #44
yiksing's Avatar
There are many different kinds: Standalone, piggybacks, reflash, etc.
The main thing you want is a "tune" for mods or to extract the most potential out of your engine. Google "engine tuning"
Old Aug 5, 2010 | 06:04 AM
  #45
edi.ckv's Avatar
ah .. ok .. so i want to know .. can the r3 be piggyback or reflash ? if we can do it ... which means we can use cobb with that ecu .. can we .. ?
Old Aug 5, 2010 | 06:25 AM
  #46
bse50's Avatar
#50
A search would give you the right answer to this question: No, the accessPORT will never be available for the s2 rx8 and is discontinued for the s1.
Piggy backs won't work well, stand alones are expensive (and often a wiring nightmare).
Old Aug 5, 2010 | 10:31 AM
  #47
edi.ckv's Avatar
cool, i know is not available for s2 .. but if we change our ecu to s1 .. will available ? :D
Old Aug 5, 2010 | 11:39 AM
  #48
jasonrxeight's Avatar
engine is different
Old Aug 6, 2010 | 04:56 AM
  #49
edi.ckv's Avatar
boooo
Old Aug 17, 2010 | 10:56 PM
  #50
Renesis07's Avatar
Vtak just kicked in yo!!
The cobb was really the only thing worth buying, nothing else will provide the same results and you will more than likely end up with problems.
At the end of the day, is the 5-15whp worth all the money and headaches anyways. Put a midpipe on your car and a ram air duct, cheapest power you can get and will actually yield you something.......noise mainly.
