GL5 vs. GL4 Gear Oil for Transmission
Rating: Thread Rating: 4 votes, 5.00 average.
Old Nov 18, 2008 | 10:42 AM
  #26
mysql's Avatar
Doppelgänger
I still run the RP GL5 stuff (that gave me transmission problems) in my diff without issue. No brass syncros to eat away back there.
Old Nov 18, 2008 | 10:51 AM
  #27
use GL4 tranny. Soft metal ftw :o
Old Nov 18, 2008 | 12:01 PM
  #28
magikone69's Avatar
hey guys i have a few dumb questions :'-(
im reading that chart with the viscosity b4 and after the testing and looking how bad royal purple did, there is now doubt in my mind thats why my tranny has been messing up so bad. I am going to be switching over to somethin else. What id like to know is why RP seems to be popular when the tests show it has a signifigant reduction after testing, is it the brand name that made it a popular choice?
ill admit i only put it in because i hear of word of mouth how good their products are. The initial viscosity in the chart is very good...is this the type of fluid you use for short term useasge, sort of like using it for a track day or two then swapping out? I used it on a street driven car for a little over a year and i admit for the 1st 2 months my shifts were incredible...precise and effortless. Now shifting is a real chore.
A side question, i saw seafoam has a tranny cleaner, since ive been using this RP stuff, id like it all gone, is the tranny cleaner ok to use in our tranny to do a flush and start off with fresh fluid? I want to make sure i give the tranny a fresh start...there may still be hope i can salvage this tranny :-)
As for the diff ive been using Mobil 1, how can i tell if there is something wrong with it...as far asd i kno ive had no problems in the dif lol...sorry if this Q was a thread HJ
Old Nov 18, 2008 | 01:03 PM
  #29
Nubo's Avatar
Lubricious
Originally Posted by tunerwannab
API GL-4 and API GL-5 products typically use the same extreme pressure (EP) additive system, with the API GL-5 having about twice the concentration of a API GL-4. In service, these additives become active under extreme load and temperature when the protective oil film can be squeezed away. EP additives work by forming wear-resistant compounds with the metal of the gear tooth surface. As the gears mesh, these compounds shield the gear teeth from direct metal-to-metal contact that would cause wear and damage to the gears. If too little of the active additive is present, proper protection would be compromised. Too much of this additive could cause excessive chemical corrosion of the gear surface. If an API GL-5 gear oil is used in a application where API GL-4 gear oil is called for, chemical corrosion of "yellow metal" components may occur, such as bronze synchronizers, brass bushings, etc. This may lead to shifting difficulties or shortened equipment life.
I use GL4 to play it safe, but I still don't quite understand the real-world application.
GL-5 sounds like it would be better, except it eats yellow metal (synchro rings).
So, are there transmissions out there that *don't* use yellow metal? How common is that? And why would a Mfr list both fluids as an option for a tranny which does use brass alloys?
Old Nov 18, 2008 | 08:48 PM
  #30
tunerwannab's Avatar
In my expierence if you use gl5 in a gl4 transmission in cold weather it can make it very stiff to shift.
Old Nov 21, 2008 | 06:07 PM
  #31
TrochoidMagic's Avatar
is adjusting valve lash
Originally Posted by newguy
I dont know the mazda trans at all but in any trans with any brass parts like syncros it is a big no-no to use GL5, it contains additives that eat away at brass. GL4 for me and hopefully a non sulfer based fluid after reading the horror stories of trans oil stinking in the cabin right after the fluid is changed, with no real resolutions to the problem that i read
hate to admit my suspicions with RP not performing its best during cold temps. fluids were drained after only a few thousand miles of use... and the rest RP was used up and blended with valvoline. needless to say, occasional shift imperfections are still there, but it was dramatically improved.
i have one word: SYNCHROMESH
it will most likely be blended with valvoline durablend(synthetic blend) and even then, i'm hesitant. it'll most likely be reserved for the diff... maybe blended with valvoline high performance regular fill.
--input needed--
Old Nov 21, 2008 | 06:21 PM
  #32
Originally Posted by LionZoo
Next time I change my gear oil, which should be in a few months, I'll try a Motorcraft synthetic blend that the Miata guys say is very helpful in curing any grinds and is supposedly specifically formulated for NB 6 speeds of which the 2004-2008 RX-8 transmission is a variation of. I'll check back when I do.
i might have heard about that between a tech at a miata meet ( i did used to own one you know).
and i've also heard of synchromesh being used.... and also popular in the honda crowd.
on a side note, have you checked walmart for your motorcraft fluids? you might want to check that out... i might have seen that there and wanted to try it out.
but if you go ahead and try it out first, let me know of your immediate results.
wait, i might see you 2morrow at the meet. more details to come.
Old Nov 21, 2008 | 07:15 PM
  #33
MazdaManiac's Avatar
The Eneos made the tranny silky smooth.
I went back to Redline only because of the worry about the "yellow metal" issue.
Redline is good, but not as nice as the Eneos.
If the "yellow metal" issue is a non-issue, then I will go back to the Eneos.
Old Nov 21, 2008 | 07:27 PM
  #34
I haven't had any issues with the Eneos GL-5 fluid but I wanna hammer my trans some more before I come to any conclusions about it. I still lean on the Mobil1 stuff, though.
have either of you had any expierence with amsoil gear fluid? I was thinking about useing that in my diff and tranny.
Old Nov 21, 2008 | 09:02 PM
  #35
mac11's Avatar
Rotary , eh?
It took quite a few miles and lots of track sessions to realize my issues with GL5 in the trans. All of a sudden I didn't have 4th gear on the track @ ~90mph. Not once, but all weekend. Made probably 70+ tries for 4th gear.
Swapping out to a GL4 resolved the issue without a rebuild. No grinding or any issues after the swap. Was running/shifting fine the last time the car was run.
Old Nov 21, 2008 | 09:06 PM
  #36
mac11's Avatar
Rotary , eh?
Fantastic stuff. Love it, have had much success with it in several vehicles that have seen hard track use.
Transmission:
http://www.amsoil.com/storefront/mtf.aspx
Differential:
street:
http://www.amsoil.com/storefront/svg.aspx
track:
http://www.amsoil.com/storefront/svt.aspx
GEAR OIL IS CHEAP! CHANGE YEARLY!
Old Nov 22, 2008 | 01:36 AM
  #37
Conundrum's Avatar
Originally Posted by rx8dad
Just bought some of the Motorcraft manual transmission oil.
http://www.fcsdchemicalsandlubricant...ission%20Fluid
It's a full synthetic GL-4, supposedly German made.
Hope it is as good as the Miata/Focus guys say it is.
Probably install it this weekend.
Where did you find them and how much does it cost per quart?
Old Nov 22, 2008 | 01:39 AM
  #38
LionZoo's Avatar
road warrior
Motorcraft tranny oil should be going in tomorrow.
Old Nov 22, 2008 | 01:40 AM
  #39
anyone with any experience on pennzoil synchromesh and valvoline durablend and/or synchromesh durablend together?
Old Nov 22, 2008 | 01:53 PM
  #40
Potentiated's Avatar
We should remember that years ago, when everyone was on the Royal Purple versus Redline hype, many people chose Royal Purple for their transmission because those idiots at Royal Purple told us it would work great. I remember calling them myself and getting the same encouragement.
Luckily, I decided to go with Redline for my trans and Royal Purple for my differential.
Can Royal Purple be sued for this?
Old Nov 22, 2008 | 02:48 PM
  #41
mac11's Avatar
Rotary , eh?
Sorry but what one does to their car is their responsibility alone.
Old Nov 22, 2008 | 04:55 PM
  #42
mac11's Avatar
Rotary , eh?
Ray you know as well as I do how much bad advice is there out there on the 'net. I can't believe people are still willing to just take some guy's word for it. Mine, yours or otherwise. Especially when said guy has a financial interest in selling that product, like a sales rep from Royal Purple that you get on the phone. Like the lubricants I just recommended in this very thread. I have used them, I like them but what does someone across the world know about who I am? I haven't run any scientific studies on any of that stuff. I put it in my car. That is all.
People need to take responsibility for their actions. There is a lot of money at stake when you are talking about a motor vehicle. Why rely on someone else when they are not going to pay for your car if it breaks? Some vendors may have a conscience but that doesn’t mean they have the knowledge. And if they are turning a profit off of their recommendations their motivations should always be scrutinized.
Old Nov 22, 2008 | 08:11 PM
  #43
olddragger's Avatar
learned a lot--changing out to mobil 1 tomorrow for the trans==it doesnt have sulfur in it per report.
OD
Old Nov 22, 2008 | 09:51 PM
  #44
I have penzoil gl4 in my tranny right now and it feels about the same as factory stuff. it has been in there for almost 8 months and feels the same as the day i put it in.
Old Nov 23, 2008 | 08:56 AM
  #45
04RX8man's Avatar
Rotary Powered Countryboy
so what weight should we be using for out transmission and diff....Is 80/90 for the tranny good and same for diff?
Old Nov 23, 2008 | 02:18 PM
  #46
rx8convert22's Avatar
I've always used Redline MT-90 (GL4) in all my Mazdas. Good stuff.
Old Nov 23, 2008 | 02:53 PM
  #47
LionZoo's Avatar
road warrior
Put in the Motorcraft last night and ended up putting about 250 miles on the car last night. There's a distinct improvement in smoothness when the transmission is warmed up. It now slides from gear to gear effortlessly. The tranny also seems to reach operating temperature quicker. The 1-2 shift when cold still requires a delicate touch. It feels like the Motorcraft isn't as "clingy" as the Redline because even if the tranny is hot, when you let the car sit for a little bit of time, the first couple shifts after you start driving again is a little more notchy.
The miata.net guys report this oil requires some miles to break in, so I'm hoping it'll get even better in the coming days.
Old Nov 23, 2008 | 05:44 PM
  #48
olddragger's Avatar
mobil one works nice--trans is actually quieter(noticeably so) and the shifts are just as good if not a little better. mine is a +60K trans.
Mobil one is easy to get around here.
OD
Old Nov 23, 2008 | 06:32 PM
  #49
LionZoo's Avatar
road warrior
I have been saying that for 3-4 years now. Glad to have validation.
I guess for some it's just too hard to believe that off-the-shelf stuff that sells for $8 per quart might might work pretty darned good.
Royal Purple has made some of us a bit gunshy and so we're hesitant to touch anything with a GL-5 rating.
Old Nov 23, 2008 | 09:41 PM
  #50
LionZoo's Avatar
road warrior
I have been explaining all this as have TeamRX8 and JaxRX8, as well, although our opinions may vary. I first discussed the problems with RP 4 years ago and it had nothing to do with the rating.
The point is, I am glad people are starting to "get" it. Now I wanna see what the Eneos GL-5, 75W90 will do to my trans in the long-term.........
Well I'm sure a lot of people understood the GL-5 issue before regarding synchros, but I think some of us had a lapse in judgment and decided to take Royal Purple's claims that even though it was a GL-5 it wouldn't result in any synchro damage at face value. Now of course we're a bit shy about believing any other company claiming their GL-5 oil doesn't hurt synchros. Regardless, I think I've found a transmission oil that I feel comfortable sticking with. The Motorcraft really is nice and one other rx8club member put it in at the same time I did and reports the same.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
