Anyone has coolant over flows at the track?
Old Sep 1, 2010 | 03:51 PM
  #26
MagnusRacing's Avatar
Originally Posted by TeamRX8
the problem completely went away and never came back after switching to waterless Evans NPG-R coolant, but it's not for everybody ...
Unfortunately almost all race sanctioning bodies require that you run only straight water in the cooling system. Coolant (or Evans NPG-R) would not be allowed in a race.
Old Sep 2, 2010 | 11:25 AM
  #27
wankelbolt's Avatar
1% evil, 99% hot gas.
[citation needed]
Neither SCCA nor NASA require straight water in their race cars. They are the largest amateur race sanctioning bodies in the US. NASA specifically prohibits ethylene glycol but says nothing about propylene glycol (Evans). Neither they nor any other body I know of prohibits any kind of coolant for their HPDE (non-competition) events.
Now, I know the pro racing organizations all prohibit ethylene glycol, but I don't know that they all require straight water.
Old Sep 2, 2010 | 11:36 AM
  #28
Spin9k's Avatar
Momentum Keeps Me Going
Coolant overflow - I saw a little coolant dried around the catch can once, then again another time, then again, then the engine got replaced. I don't think it's good or normal. The catch can is so that doesn't 'normally' happen.
Old Sep 2, 2010 | 03:23 PM
  #29
Originally Posted by wankelbolt
[citation needed]
You are correct. From the NASA rules:
Ethylene Glycol-based antifreeze and other additives that may cause a slippery condition if spilled on track are prohibited.
SCCA says:
Glycol-based coolants are not permitted. Additionally, any other coolants that significantly reduce the friction properties of the track beyond what plain water does are not permitted.
I suppose if Evans is not "slippery" it might be allowed by NASA. However SCCA just says "Glycol-based" which I think would include Evans. Does it cause a slick surface or is it just like water? I have no direct experience. If in fact Evans is not "slippery" it might be an interesting option for NASA races.
Old Sep 2, 2010 | 03:28 PM
  #30
I never found a coolant catch can that useful....
I never have small drips...it's usually nothing...or a catastrophic dump...that a catch can is useless for
Old Sep 2, 2010 | 08:34 PM
  #31
Please provide the specific SCCA GCR regulation that states this ....
Old Sep 2, 2010 | 11:19 PM
  #32
2010 SCCA Pro Racing Regulation 2.7.4.4 (This is the World Challenge regulation but all the other pro series rules say the exact same thing, MX-5 cup, etc...)
http://cms.scca.com/documents/Pro%20...rsion%2021.pdf
Of course this is SCCA Pro Racing Regulation - perhaps Club Racing or Autocross has less strict requirements.
But I guess what really matters is if Evans is slippery like traditional coolant if spilled on a track? Anyone know?
Old Sep 3, 2010 | 07:28 AM
  #33
I can't recall, but will check it out later today.
I'm pretty sure it's not a club racing rule, but will be seeing the SCCA Tech Director later today and will ask for a clarification. Any type of coolant is allowed for SCCA Solo use.
Old Sep 18, 2010 | 12:03 AM
  #34
Originally Posted by dannobre
Also run your overflow down to the bottom of the rad..then it will run out onto the road...instead of all over your power steering connectors and the rad fans.....electrical bits, connectors and hot coolant don't mix
ding ding ding.
that is the simple easy answer..
