Descreen the MAF
Old Dec 21, 2003 | 06:29 AM
  #26
WhoDiddy's Avatar
these airbox mods for our cars really don't work. the 6 yeilded about 1-2 HP. and is louder. glad i have my INJEN CAS now.
Old Dec 21, 2003 | 06:41 AM
  #27
Hymee's Avatar
Race Steward
Call me an old boring fart, but from my experience:
Rule 1: "Don't mess with the MAF"
It is just fooling the computer into beliveing something that is not true. Yes, I know it is a common mod to do on various cars, and with a lot of buggerising around one might get it correct. But the MAF is the most accurate sensor on the car telling the computer how much air the engine is digesting. Fiddling with something is effetcivley putting it out of calibration. If you put a less resticted MAF in AND tell the computer it's calibration - that is the best way.
Just my 2c. I can already see the flames leaping towards me
But until we have something better, who am I to argue!
Cheers,
Hymee.
Old Dec 21, 2003 | 06:43 AM
  #28
WhoDiddy's Avatar
Originally posted by Wildcard
More to report....
After driving to work and back today (60km) the soot is back. It doesn't appear to be piling up as quickly as it usually does though.
Perhaps in my frenzied drive yesterday I was going so hard that I was spitting flames and burning the evidence?
Perhaps too Omicron is correct about the ECU learning and hence the a/f ratio is slowly returning to normal, along with the soot.
that's your best bet! ECU relearns and adjust accordingly. a mod like this might last twice. just reset ECU to keep this up. j/k
Old Dec 21, 2003 | 11:21 PM
  #29
RX-8 friend's Avatar
Us old fart rotarians know that soot as smoot. It's oily soot. The bane of rotary owners.
Old Dec 30, 2003 | 06:14 PM
  #30
Mazda Monkey's Avatar
Cheers,
Hymee.
I agree. Some who have replaced the airbox and / or screens have experienced rough idle, due in part to the screens being removed. The turbulent airflow cause the rough idle.
Old Dec 30, 2003 | 08:21 PM
  #31
pp13bnos's Avatar
Pineapple Racer
Any a/f ratios to report? CJ
Old Dec 30, 2003 | 09:15 PM
  #32
syntrix's Avatar
I like cheese!
Should have some time to log this weekend. That will also ensure that the car has fully adapted, and I can calibrate the wideband in the morning.
Old Jan 2, 2004 | 04:39 PM
  #33
syntrix's Avatar
I like cheese!
Here's some data, finally got the tps and maf hooked up. Just a run back from the store with the car warmed up:
Old Jan 2, 2004 | 07:00 PM
  #34
pp13bnos's Avatar
Pineapple Racer
Looks like its pulling a 12ish a'f ratio under wot? Any numbers prior to the descreening? CJ
Old Jan 2, 2004 | 07:04 PM
  #35
syntrix's Avatar
I like cheese!
If you have time to compare, I have some other ones prior to de-screening here:
http://rx8.swankmonkey.com/airfuel/
I haven't compared yet, but will be doing so very soon!
Old Jan 14, 2004 | 12:10 AM
  #36
sferrett's Avatar
Whaaaa?
Any longer term updates on this?
Old Jan 14, 2004 | 12:16 AM
  #37
syntrix's Avatar
I like cheese!
Old Jan 15, 2004 | 08:30 AM
  #38
darkducati's Avatar
So, I am curious why you didn't remove the second screen.
Old Jan 15, 2004 | 08:41 AM
  #39
syntrix's Avatar
I like cheese!
Just haven't tried it yet!
Old Jan 22, 2004 | 03:09 PM
  #40
darkducati's Avatar
Okay, for the love of God; DO NOT TAKE OFF BOTH OF THESE SCREENS! I tried it both ways and reset the ECU each time, giving the ECU some time to relearn some parameters. With just the first screen removed it works great, no change in idle or driveability. Without both, it is horrible. It won't idle for crap, and low end power went into the toilet. The idle would sit there and go up and down as the electrons ran around screaming "THE SCREENS ARE GONE! THE SCREENS ARE GONE!." Bottom line is, do not do this unless you have some way of messing with the ECU. What I want to know is how the intake manufacturers are getting around this? Are the aftermarket pipes the same as the factory pipes? Or are they a bit smaller? Perhaps they are able to have a longer straight section before the MAF. Any information?
tjohnmeyer
Sep 28, 2017 05:03 PM
poacherinthezoo
Aug 3, 2016 11:01 PM
Evan Gray
Nov 24, 2015 01:00 AM
Evan Gray
Sep 26, 2015 12:30 PM
