5W30 Oil Don't Cut it, Engine Bearing Pics 58K S1 RX-8 from England.
Old Oct 31, 2009 | 04:23 AM
  #451
bse50's Avatar
#50
So would the pressure regulator be a good idea for the ones that are mad enough to often see high load\high rpms?
Where are you in the uk?
Old Oct 31, 2009 | 10:15 AM
  #452
olddragger's Avatar
anyone use marvel mystery oil for premix---thread jack--sorry?
OD
Old Oct 31, 2009 | 10:49 AM
  #453
TX
OD
I think Swoope is. FYI, it's only $2.50 at the dollar store.
Old Oct 31, 2009 | 12:17 PM
  #454
@!!narotordo's Avatar
FLAME ON!
^Or was.
Old Oct 31, 2009 | 12:38 PM
  #455
FLAME ON!
Lightbulb
Originally Posted by TZ250
This is a great question. What is the temp of the oil as it flows through the bearings, compared to indicated temp? I believe the mid range viscosities flow more quickly and draw the heat off much more efficiently than the highest weight viscosities. One man's opinion.
Good point!
Old Oct 31, 2009 | 07:16 PM
  #456
madcows's Avatar
Originally Posted by PhillipM
There's pressure exerted from the centripetal force generated by the stroke of the rotor too, that increases at the square of the engine speed, so more rpms = massive jump in stress, and because the surface speed differential on the bearing is higher at high rpm, it slings oil out of the bearing faster from the hydrodynamic wave traveling in front of the bearing oscillation, which is also why you need more flow for higher RPMs.
Thank you for the explanation, sir!
Old Oct 31, 2009 | 07:57 PM
  #457
TZ250's Avatar
It is my understanding that separation presssure, or the force applied by the oil film to keep the bearing surfaces from touching, increases in direct linear proportion to flow. In other words, doubling the flow of the same oil at the same temperature doubles the separation pressure within the babbit/journal. Doubling of pressure, same oil, same temp, also has a direct linear effect on flow: twice the pressure, twice the flow. Comments?
Old Oct 31, 2009 | 08:41 PM
  #458
PhillipM's Avatar
Not quite right, as it's an orifice, twice the pressure will actually equal slightly less than twice the flow, same with the seperation, at twice the pressure, you experience fast flow loss through the bearing and more power loss = slightly less than double.
Old Oct 31, 2009 | 09:01 PM
  #459
madcows's Avatar
Phillip, then what parameters do we need to know (bearing orifice size, total surface area of rotor bearing, etc) in order to determine what the ideal pressure would be for a given RPM, oil viscosity and temp?
Also, do you think an increase in oil flow rate on a renesis would be beneficial for any reasons other than oil/engine cooling?
Old Oct 31, 2009 | 09:18 PM
  #460
PhillipM's Avatar
To be honest, without proper modelling software, or a long time sat working things out with some imperical testing, you could only get a rough rule of thumb, even the best modelling and CFD software can't give you a perfect figure.
Old Oct 31, 2009 | 09:28 PM
  #461
TZ250's Avatar
Shocking that I was that close to being right. I'm chuffed. Are you a fluid dynamics engineer?
Old Oct 31, 2009 | 10:39 PM
  #462
olddragger's Avatar
if hes not he should be.
OD
Old Nov 1, 2009 | 08:55 AM
  #463
PhillipM's Avatar
No, but as I said, reworking and redesigning dampers is part of my job, so there's a fair bit of fluid dynamics involved, but I won't pretend I know anywhere near enough on the subject!
Old Nov 1, 2009 | 04:49 PM
  #464
olddragger's Avatar
ok oil pressure gauge installed
I run diesel oil
was unable to get the oil temps over 175f with moderate spirited driving (my redline is 7.5--8K)
ambient temps 62F
my idle is at 1.2K
oil pressure on start up---80psi (warm up rpm 2K)
at 175F----30psi
3K rpm @ 175F =58psi
4k rpm @ 175F =71psi
6.7K rpm @ 175F = 80
Car does not go above 80psi with my diesel oil regardless of rpm.
So from 6.7K to 8K no change in oil pressure
Now to see how the 09 compares---someone?
Higher rpms may be the weak area of flow? And maybe there is a lot of oil dumping into the pan causing some problems? Foaming/ air captivation? Another reason for the 09 baffles etc.?.
oildrragger
Old Nov 1, 2009 | 07:39 PM
  #465
Those number are inline with mine.
Old Nov 2, 2009 | 07:49 AM
  #466
Mazmart's Avatar
I run diesel oil
ambient temps 62F
my idle is at 1.2K
at 175F----30psi
oildrragger
Are you suggesting that you believe you have a problem?
Paul.
Old Nov 2, 2009 | 09:09 AM
  #467
olddragger's Avatar
Trying to make me think aren't you!, You know that makes my head hurt.
Problem?---I am not sure. But, do remember these readings are with a 40wgt oil and a temp of only 175F. I wonder want is happening at 210F?
I think a bypass is opening --I can see this occuring at cold start. Innitial pressure is 80psi but in just a few seconds the pressure does drop to 72-74psi.
I also think the pump has the capicity to drive a higher oil pressure evidenced by the relief valve opening at 74psi but the pressure continues to climb a little.
I am a little concerned that there is no increase in the pressure from 6.7K forward.
I am also questioning why such a high oil pressure at cold start? Is it really that much more resistance from the oil at cold start of 72F versus the 175F? If it continues on a linear scale then another--say 50 degrees (oil at 225) wouldnt the pressures be substantually affected? We would probably have a very low idle pressure.
I do like the 09 oil pan baffles and pick up.
See I told you--now I have a headache.
olddragger
Old Nov 2, 2009 | 10:06 AM
  #468
ayrton012's Avatar
Ayrton Senna Forever
olddragger
1.I have the same max pressure with 30w (0w-30), as it is normal. So there has to be a limiter with 71 PSI ( as Ash attached), but where, if according to Mr Engman and Paul there are only an emergency first relief valve (about 156PSI), and the rear relief valve with 78-91 PSI value. I'm confused.
2. Yes the cold oil resistance is horrible high vs hot oil (even 0w). ...and we have this high pressure with opened e-shaft pellet (under 60C)
Old Nov 2, 2009 | 10:39 AM
  #469
Mazmart's Avatar
Seems to me that everything is fine pressurewise, as it tends to be with rotary engines. Some increase from this is not a bad thing (If you need it and can use it) but we don't need to re-invent the wheel or conduct every test that Mazda has done already. The chosen viscosity is where I have a problem and Mazda has expressed the reasons for their choice and it's no different than any other modern manufacturer: They must achieve better CAFE numbers and every little bit counts.
So, again, one more time: These engines are not starving for oil at startup nor are they running a deficiency of pressure in everyday useage.
Paul.
Old Nov 2, 2009 | 11:18 AM
  #470
olddragger's Avatar
How about when you go with forced induction and track? Thats me.
I think if it will work out then the updated oil pan would not hurt and since the pan is off why not bump the pressure up a tad?
Besides I need to buy something else from you anyway. I just enjoy the experience.
By the way my engine idles with 21 of vacuum----thank you very much!
Old Nov 2, 2009 | 05:43 PM
  #471
Ouch.
Old Nov 2, 2009 | 08:17 PM
  #472
HockeyRX-8's Avatar
TNC
....that's some bad wear...
Old Nov 2, 2009 | 09:39 PM
  #473
Originally Posted by 9krpmrx8
Ouch.
did u found that engine at a dumpster or something?
running without filter?
anyway, ouch
Old Nov 2, 2009 | 11:53 PM
  #474
It's a local member here that is rebuilding his engine.
Ran 10W-40, 70k on the motor. Front Apex seal was ****, says the rear was perfect.
http://www.flickr.com/photos/8253620...th/4067199003/
Old Nov 3, 2009 | 02:09 AM
  #475
bse50's Avatar
#50
Uhm... that doesn't look like an oil viscosity problem
More infos on the engine?
