Alignment settings for street/track use
Rating: Thread Rating: 4 votes, 5.00 average.
Old Jul 12, 2010 | 03:49 PM
  #276
Winning 8's Avatar
Hot Pit
Originally Posted by rx 8speciale
Hi i will be getting allingment this week . this are my only mods: bilstein b12 suspension=eibach springs + bilstein b8 shocks , everything else is stock. i will be DD the car with occasional track days at the nurburgring in germany . suggestions?
If you could go to the Nurburgring , you should tell us what to do with our suspension and alignment setting, that's what the GT-R did. They go to Nurburgring to test out their suspension and alignment for heir factory setting.
Old Jul 12, 2010 | 06:01 PM
  #277
rx 8speciale's Avatar
Relax baby!
i was thinking of Alignment
front camber -1.5
toe -1/8"
rear camber -1.8
toe -0
Thoughts?
Old Jul 12, 2010 | 06:57 PM
  #278
takahashi's Avatar
Hmmm
I am a fan of rear toe in, quite aggressively too. I have total of 4 mm rear toe in even on the old days of the car being a daily. It brings the rear back very well even when the car is thinking of understeering. As our cars are lack of power, you really need to power out early.... Or racing on race track anyway.
Minus toe in the front. In Australia that means toe in. I prefer 0 or 1mm toe out. We do everything upside down theree I suppose. +1mm here.
Old Jul 13, 2010 | 07:27 AM
  #279
Spin9k's Avatar
Momentum Keeps Me Going
front camber -1.5
toe -1/8"
rear camber -1.8
toe -0
Thoughts?
On my mildly lowered car...
front camber -2.00 < wear is normal using this
toe +3/32" < helps turn-in and powering around corners
rear camber -2.15 < same as front, no strange wear
toe 0 < neither helps nor hinders rotation, it's up to me
Old Jul 13, 2010 | 11:12 AM
  #280
Winning 8's Avatar
Hot Pit
-2 degree without uneven wear, you either deliver tofu through a mountain or a instructor at a track....lol
Old Jul 13, 2010 | 03:02 PM
  #281
Spin9k's Avatar
..damn...how'd you know about that tofu ? Since May07 I had -1.6 fr/2 r, but needed more so Sep09 got the 2fr/2.1r. It's better with my r-comps, but I want moooorrrrr 'cause I'm still wearing the outside a bit too much, but not as bad as before. Street tires thou, I swear, are straight/flat wear. It's the toe that kills tires not so much the camber. Think what toe looks like to the pavement - yea - you got it - tire belt sander
Old Jul 13, 2010 | 09:07 PM
  #282
Winning 8's Avatar
Hot Pit
yup toe kills, specially the camel toe......LMFAO
Old Jul 14, 2010 | 11:59 AM
  #283
olddragger's Avatar
oem shocks on aftermarket springs are a problem blackenwings?
rear end will get squirrely on hard braking (and worse when you go to r compounds).
traction can be an issue when a car is under dampered?
I have ran all kinds of settings for the track, various chamber, camber, and toe. Various size tires. To tell you the truth i cant tell much of a difference between a -1.5 versus a -1.8
versus a -2. Turn in , mid, exit or braking.
Toe end i could tell a little on turn in. Zero toe is harder to drive on the street however--wants to wander more.
A good quality alignment + good tires with the right air pressures and proper suspension will do much more than various setting changes.
Dont chase settings on the RX8 when it is only used for a weekend warrior/DD.
my 2 cents
i am running -1.5 all the way around and have been for some time.
Just my 2 cents.
Old Jul 23, 2010 | 01:42 PM
  #284
Dirt_Nasty's Avatar
Filth in a world of Clean
I've had these settings for a while couple of months now, very close to the OP's. Stock coils/springs. I haven't been to the track or Auto-x yet, but have hit the nearby twisties a few times and have be pleased so far.
Camber: RF -1 5/8 LF -1 5/8 RR -1 1/4 RR -1 1/4
Caster: RF 7 1/4 LF 6 3/4
Front Toe: 1/8 in
Rear Toe: 1/4 out
The shop I go to does everything the old fashined way, with hand tools so that is why all the fractions, guess I could of converted them, but oh well.
Prepaing for a honeymoon roadtrip through Deals gap and Moonshiners 28, next month.
Any thoughts?
Old Jul 23, 2010 | 08:21 PM
  #285
Winning 8's Avatar
Hot Pit
you sure about the toe, I think is the other way around. 1/8 toe out on front and 1/4 toe in on rear.
Old Jul 29, 2010 | 09:05 AM
  #286
painoracing's Avatar
Not only that. That amount of toe is usually used for racing aplications with almost a full suspension setup. I think is pretty aggessive for the street and will damage the tires in a short time. It also could be basically holding the car a bit in long straights as in a expressway.
Tks.
Old Jul 29, 2010 | 03:39 PM
  #287
takahashi's Avatar
1/4 of an inch is each rear tyre or total? Even 1/2 inch total or 1mm toe in is ok. Well I don't do a lot of miles. My 2003 rx8 has only done 60000km only. Mostly on track. But when it was my daily I had it with my Michelin PS2 and it will last 30000km on 4mm total toe out.
For sure on street only car I will put the front zero toe. It is just nicer to drive, just lighter feel and more responsive and the speed on road will never need aggressive set up. 0.2 of sec is not important @ each street corner.
My 2 cent
Old Jul 29, 2010 | 06:03 PM
  #288
Dirt_Nasty's Avatar
^Total, not in each. I plan on zeroing out the toe when I get back from my honeymoon road trip (~1200 miles of twiwties, and 800 of highway,much of which is through VA and WV, so I don't think those count, ha).
Old Jul 30, 2010 | 08:42 AM
  #289
wankelbolt's Avatar
1% evil, 99% hot gas.
Yeah, toe out on the rear is not stable and will decrease handling by making it way tail-happy. It will be like driving a bowl of jello. Ask me how I know...
Old Jul 30, 2010 | 09:32 AM
  #290
For a street car that is tracked occasionally..
I would stick to zero toe in the front and a bit of toe IN the rear...
Old Oct 6, 2010 | 04:26 AM
  #291
Relax baby!
, i went to do a aligment and to my surprice they were no neccesary adjudments, this are the numbers i been running since i installed my suspension with 18 laps at the ring in germany
any thoughts
front camber - 1.50 -1.44
rear camber - 2.18 -2.24
front caster 7.05 7.08
Old Oct 6, 2010 | 10:19 AM
  #292
REDRX3RX8's Avatar
That camber looks good on paper, but I'm running about that, and tracking at the limit, I think I want the rear to rotate better.
So in a few months I'm going to set camber -1.6f/-1.0r, and see if that's better.
Old Oct 6, 2010 | 12:15 PM
  #293
04Green's Avatar
Moder8
redrx3rx8,
I am only a few tenths off the rx8speciale numbers with my current setup. Only had it for a few weeks, does feel weird, like the car rotates and sets, but the back stays tucked in. Track is in early November. Is your car feeling strange, is it impacting your track times? I am trying to figure out if I should back a degree of negative out of the rear. Problem is that I did new tires (grippy Hankook V12) and the alignment at the same time. I am not sure what is tires and what is alignment. I asked for -1 in the front, and stock in rear, they seem to have misunderstood....
Old Oct 7, 2010 | 04:10 AM
  #294
REDRX3RX8's Avatar
04Green,
My "new" RX8 came with 625 miles, and a set of Kumho SPT's which is a good starter tire for track. I knew it was understeering first track day, but it was about the 3rd track day before I realized that I couldn't cure it with air pressure or driving smoother. I ran 40psi f, and 32psi r, and got the rear to jump around some, but still no cigar. So I took it to alignment shop that would let me "help". In other words, I needed the info of where the alignment was to know where I wanted to go. It was at -.5f/ -2.2lr, -1.9rr, so we got all we could up front -1.6, and -1.9 rear. Tracked on that twice, but still understeers.
Next step was shortening rear sway bar links about 1 1/2 inches, and the rear is tighter. Also, I put 2 - 225/40r18 Hankook v12's on the front to test the v12's versus the SPT's. I have 2 track days coming up so I think it'll rotate now. But then, the rears will need 2 - V12's, and I have s-teins, and bilsteins to firm up the back.
Ok, last step after all that is to re-align at about -1.6f/ -1.0 rear. I think other track guys have said about half a degree more negative on the front than on the back. If you look at cars on the street that have independent rear suspension, you can tell that the rear wheels have more neg camber which keeps it straight for the average driver. I tuned my RX3 to be twitchy which is what I liked, and it was very stable, not Porsche twitchy.
I don't time myself, but I know I can get better handling out of it, and I'm thrown in with a lot of faster cars that have to slow a lot on the corners, and make up the difference with shear power. I leave the traction control on, and I can catch a few by late braking "on stock brakes". I want the satisfaction of not slowing any of those fast cars down on the corners.
Old Oct 7, 2010 | 10:40 AM
  #295
04Green's Avatar
Moder8
Thanks Loads!
I have Tien-H, and Tokico D-Spec. With the shorter drop, I think all they got was -1 up front They got -2 in the back. It was stock all the way around before. I destroyed a G-Force Sport a few weeks ago on the front, it did not under-steer, I just ground off the outside tread of the tire.
I think I am heading back to the shop for the half less negative on the back you mentioned above. With the V-12 I cannot generate a good test on the street without going way too fast for street comfort. The standard play corners are now at least 10 MPH faster.
Also, I am still trying to figure out what to listen for on the V-12. They are awful quiet, no whine. I do not want to push without a huge runoff and there just are no places here to safely test at any reasonable speed.
If you decide to do brakes, I really like my HPS pads. They are OK in the cold so far. The stock ones did not fare well at Roebling (really odd smells). I also went with super blue for the fluid. Made a huge difference.
thanks,
Mike
Old Oct 7, 2010 | 01:49 PM
  #296
REDRX3RX8's Avatar
Ha! I love that brake smell!
My first track day was about 1 year and 7k miles after I got my 8. I was babying my car, and never even braked hard enough to bed the brakes. Some big girl was my instructor, and she had a hard-on for braking to the limit.
Anyway they were a gassing like a burned up clutch, and I don't get any more smells 2 1/2 years and now 20k miles.
The pads have no noticeable wear, and I could chirp the front SPT's when slowing from 96mph. I don't see why I'll be changing pads very soon, and I track 4 times a year. Maybe the pads stay good because I don't do any stop and go out here in West Texas.
Old Oct 7, 2010 | 01:54 PM
  #297
04Green's Avatar
Moder8
Brake smell is not bad, what these were doing was.. Smelled more like a muck fire.. Stock brakes are great. I have an 04, so mine were pretty old too. I also developed a desire for lots of brakes when I almost collected an M3 that turned around on the track to go back through a missed apex. You can get both feet on the brake pedal while screaming....
I am still not in ABS, but plan to investigate that area next time, if only the little VW thingies will get out of the way.....
Old Oct 7, 2010 | 02:23 PM
  #298
REDRX3RX8's Avatar
What do you mean ABS? Your 8 have traction, stability, abs? Ok, maybe you mean it doesn't kick in. If I drive right mine doesn't kick in either.
I don't turn mine off, and it saved me from going off 2 or 3 times. Nobody can brake one wheel at a time to save skid.
Yeah, people spinning in front are about the biggest hazzard, Just watch them close and stay back some. I've tracked with a lot of EVO's; they have AWD, 293 hp, and like to spin when braking hard.
So, on your alignment, try to get this: all camber you can in front or about -1.6, -1.0 or -1.1 in rear, and zero toe front and back. the tolerance on toe would be slight toe out in front, slight toe in in back.
Old Oct 22, 2010 | 12:37 PM
  #299
Definetly, for racing purpose, toe in/out are very important for maximazing suspension and cornering. Zero toe in the back is more usual in front-wheel drive cars, not meaning that it can't be done in rear-wheel cars. Front toe is a must. 1/4 or 1/8 are normally used in front -wheel cars. Those kind of toes for a daily driven car is not recommended.
Another thing that worries me in this thread is that a lot of people are talking about settings and their experience but, I havn't seen a lot info about tire temp and air preassure that justifies the claims. This two meassurements are the backbone of suspension setting. I could think that the car is handling great but, without tire temps/preassure, I can't maximaize what I have or really know what's going on.
Also, there is a difference between using normal air or nitrogen, and different compound/make tires.
My suggestion is, whatever suspension mod you will do and how much $$$ you will spend, put appart a little amount for a good pyrometer and tire preassure gauge and then you will get a real feel for your settings.
Old Nov 1, 2010 | 08:30 AM
  #300
fastlaneracing's Avatar
Rotor User
I see only street alignments in this thread...
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
