Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Official SARX Lounge
Old Feb 8, 2012 | 09:47 PM
  #6151
hoss -05's Avatar
Lucky #33
details on the car? how many miles what year... has it had an engine replacement yet?
From what you just described it could easily just need new plugs wires and coils.
  #6152
white_rx805's Avatar
^^ calling mazda dealership 2mrw.
Old Feb 8, 2012 | 10:30 PM
  #6153
hoss -05's Avatar
Lucky #33
There are Much cheaper places to buy sparkplugs, coils and wires then the dealership FYI check in with Sparkplugs.com or one of the vendors for the parts. Some believe all of these should be changed out every 30k miles or so.
How many miles do you have on the clock? You should still call the dealer with you VIN so you can check to see what major services have been done if you do not know.
Also foam on the dip stick can be caused by your engine not being fully warmed up. I use to get it bad when I only had a seven min commute back and fourth to work.
Old Feb 8, 2012 | 11:55 PM
  #6154
I was gona call mazda for the comp. test never for part lol
and its 05 had it for about 7 months. has 63k mil.
prev. owner said she took it back for a recall and got a whole new motor and papers to prove.
Old Feb 9, 2012 | 01:26 AM
  #6155
shadycrew31's Avatar
WENTGERMAN
then it might be the coils and plugs if you have a fresh reman. I was figuring it was the original engine.
Old Feb 9, 2012 | 01:30 AM
  #6156
hoss -05's Avatar
Lucky #33
If it has a new engine then most likely the compression is good. It is possible that Mazda did not change out the plugs, coils and wires with the engine. At that kind of mileage if they have never been changed out chances are you would be having your current symptoms.
Before you spend the money on a compression check I would switch those out. It will have to be done no matter even if mazda dose another engine for you. Its a fairly easy job for the average person with simple hand tools.
Old Feb 9, 2012 | 01:33 AM
  #6157
hoss -05's Avatar
Lucky #33
Burning the oll midnight oil?
Old Feb 9, 2012 | 02:41 AM
  #6158
8 Maniac's Avatar
Senior Member
I think I found a video of the last hill country run... looks like I missed out on some action!
http://www.youtube.com/watch?feature...&v=z2030Tnp6Zc
Old Feb 9, 2012 | 09:18 AM
  #6159
Dude, it's so much fun. How is the car running?
Old Feb 9, 2012 | 10:04 AM
  #6160
WENTGERMAN
I have issues with going to bed at a good time.
Old Feb 9, 2012 | 10:46 AM
  #6161
alright guess ill move plugs and wire to the top of the list
any website yall recommend for the parts?ima start researching on how to change them.
Old Feb 9, 2012 | 11:01 AM
  #6162
Oh and just to add i had the car recently diagnosed and they told me i had a craked head casket or the head itself was cracked. they came to that conclusion because of the milky oil and almost a qrt of oil low?
is this false from what i read both of those are normal?
Old Feb 9, 2012 | 11:06 AM
  #6163
J8635621's Avatar
Pew Pew Pew
roflroflroflrofl There is no head on the engine. The rotary burns oil by design and we already explained the milky oil. If there was actually coolant in your oil, it would be a BAD thing
Old Feb 9, 2012 | 11:10 AM
  #6164
lmao i was scared the whole way driving home and googled rx8 head,bam nothing so i starting researching and now im here
Old Feb 9, 2012 | 11:19 AM
  #6165
heres the rx8
fyi the cars actually my gfs.
Attached Thumbnails Official SARX Lounge-285516_210765005639922_100001192723216_555637_2680774_n.jpg
Old Feb 9, 2012 | 11:28 AM
  #6166
hoss -05's Avatar
Lucky #33
lol this is a joke right? If not a joke please tell us who diagnosed the car as having a "craked head casket"?
Make sure you pick up the coils as well.
Old Feb 9, 2012 | 11:35 AM
  #6167
WENTGERMAN
Nice looking 8! Don't trust a regular mechanic, needs to go to Mazda or a rotary mechanic. Also check the oil at every fill up!
Old Feb 9, 2012 | 11:37 AM
  #6168
The fact that even a normal mechanic doesn't know that the engine is a rotary and that it does not have a head gasket is scary. No proper training I guess. I was speaking with the husband of one of my employees the other day and I was astounded by his knowledge of the rotary, specifically the Renesis. He is an ASE certified master mechanic and he said they covered the rotary extensively in his last classes. But he said in 20+ years he has only worked on one or two.
Old Feb 9, 2012 | 11:58 AM
  #6169
Yea pretty much when i got home i knew the "mechanic" ddnt knw what he was talking about lol. and i had took it to firestone just for a check up and and the guy called me out and starting talking about i shouldnt drive it no more becuase of the cracked head and so lol
and yes sir already priced most of the parts i need,and the guy at the counter said the rotarys have no spark plug wires?? i knw for a fact im not taking a rotary to any shop besides mazda or maybe alamo rotarys.
Old Feb 9, 2012 | 12:01 PM
  #6170
J8635621's Avatar
Pew Pew Pew
You can do most of the work yourself no problem. Pretty much everything has a documented step by step do it yourself thread on here.
Old Feb 9, 2012 | 12:02 PM
  #6171
Thanks and she absolutely loves the car and does not want to ever let it go. so instead of telling her about the "cracked head" i started reading lol
just changed the oil yesterday with 5 20 non synthetic oil and oil filter.
Old Feb 9, 2012 | 12:04 PM
  #6172
i've read about 4 pages of changing plugs and coils in the past hour doesnt seem so hard. taking off the driver wheel for the plugs and taking off the air box for the coils.
Old Feb 9, 2012 | 12:13 PM
  #6173
cornholio135's Avatar
SARX
you can get the coils and plugs from AZ or Oreilly's the wires you might have to go to the dealer... speaking of coils I still need to reinstall my BHR ing kit been too busy moving...
Old Feb 9, 2012 | 12:16 PM
  #6174
WENTGERMAN
I prefer 10-30 but the minute you start talking about what weight oil is best, 30 threads will magically appear with thousands of pages of data and facts.
You just throw in whatever weight your heart desires!
Also if you look around on the buy/sell threads you can find some sweet deals on parts, heck I've purchased 80% of my parts on there haha.
coil/plus change is easy as pie! If you can change the oil you can do the plugs and coils.
Old Feb 9, 2012 | 12:20 PM
  #6175
Lord ET's Avatar
Is that a bike rack?
^ nailed it.
I helped a fellow member earlier this week do a coil/plug change and it took about an hour. You will only need basic tools. phillips and flat head screw driver, 10mm socket 12mm socket, 21mm socket extensions (wobble bit helps) and a tq wrench to be safe.
