Corvette LS1 Ignition Coil Project..
Old Feb 8, 2008 | 06:15 PM
CnnmnSchnpps's Avatar
No means yes
I say go for it (we all want to know the results )... Worst that can happen is you flood your engine or fry your PCM.
Old Feb 8, 2008 | 06:22 PM
well maybe I'll learn something new then because I'm looking at the prescribed setup page and I don't see how it will interface properly on an RX-8 Renesis:
http://www.msdignition.com/pdf/6304.pdf
Old Feb 8, 2008 | 06:38 PM
ltrx8's Avatar
04 Silver GT
Ignition controller isnt needed . We already have that.. .
Tell you what .I'll see if I can get a wiring diagram..
I'll get back .
Last edited by ltrx8; Feb 8, 2008 at 06:48 PM. Reason: wrong link provided by user
Old Feb 8, 2008 | 06:44 PM
ltrx8's Avatar
04 Silver GT
Actually the part # 6302 dual coil ignitor... Ahh I'm even beginning to see how this is gonna work
http://www.msdignition.com/2007/light.html
This is why I need two dual coil ignitors..Leading and trailing.
Old Feb 8, 2008 | 06:49 PM
Well, no.
Anyone that would bother to read my threads on the subject (having experimented with the RX-8s ignition system pretty extensively for the last 3 years), would see that the OE coils have a trigger cycle and dwell that is unique.
Even if you get the coils to fire (which is the easy part) the ignition timing will be off and will get more and less off as the RPMs change (the hard part).
The end result is sudden, unpredictable detonation.
Old Feb 8, 2008 | 09:15 PM
ltrx8's Avatar
04 Silver GT
Well, no.
Sorry MazdaManiac but its gone from the LS1(mk ultra project) to the MSD (dual coil ignitors) and (Blaster coil) project.. for reasons mentioned in this thread. Check it out..What you say above is correct (I searched) if you have any Idea why or how this new arrangement would have negative effects . Please get back to us..It would benefit other members as well. I also edit alot because I broke my hand the last time we chatted .lol
Old Feb 8, 2008 | 11:24 PM
No means yes
Well, no.
I stand corrected. I was thinking they would most likely not work... As a hacker I tend to jump the steps from "partially works" to "fully works"
I confess I have yet to read much on the subject.... Will get on that
Old Feb 9, 2008 | 12:12 AM
Well, what I would do is hook up whatever coil/ignitor combination you are planning to experiment with in tandem with the stock coil and run it to a plug that is just grounded on the block.
Then, run two inductive pickups to a scope and free-rev the engine through the full RPM band and compare the plots. If they are in sync, you are golden.
Having done that with a few different possibilities, I found that most third-party coils produced plots that went in and out of sync.
Old Feb 9, 2008 | 05:09 AM
swoope's Avatar
Zoom-Freakin'-Zoom
well.
then time to start a new thread with the right heading...
as the topic here failed... btw, you failed....
Old Feb 9, 2008 | 12:39 PM
ltrx8's Avatar
04 Silver GT
Originally Posted by swoope
well.
I will .But to be be fair I'll keep it open for anyone already interested /or subscribing .
For any members who wish to follow this up
NEW THREAD IS " MSD Ignition Project " in aftermarket performance section.
Old Feb 9, 2008 | 12:57 PM
ltrx8's Avatar
04 Silver GT
I will pass this along to Ron @RMJ Racing.. This might help him test .Good Idea! Thanks .
I do believe thats why pn#6302 (dual coil ignitors)come into play .But I'll know more as we progress..MazdaManiac do you or anyone else have any idea how or why tech would suggest the dual coil ignitors? . I think each one handles leading and trailing spark, but I'm sure you or others know more about this kind of thing.Please get back. Also feel free to check out new thread started on topic as instructed by swoope " MSD Ignition Project" and post any info you might have there..
Old Feb 14, 2008 | 05:39 PM
LS2 coils
LS2 coils:
The fit, they work and are directly compatible with the RX-8 electrically.
The only issues are plug wires (you must make your own), wiring harness (same) and fabrication of some brackets (need I say it?).
Old Feb 14, 2008 | 05:58 PM
well that didn't take long
I was going to mount them down on the side of the engine in the sparkplug area with the shorty plug wires, then build an adaptor harness for the wiring connections
guess I should have only let you have four instead of all eight, my bad there's always the MSD LS2 route though
congrat's on proving it out
Old Feb 14, 2008 | 06:32 PM
Big thanks to you, Mark. Had you not made your stuff available, I probably would have dragged my feet a few more months at least.
The MSD version of these coils would probably be even better. At some point I'll probably try a set of those as well.
I haven't done any significant tests of these coils efficacy in reducing misfires or handling richer mixtures, but I'll get to that on the dyno this weekend.
Old Feb 14, 2008 | 06:40 PM
Juice's Avatar
I made some poos
How did you make the harness?
Just splice the LS2 coil harness with the 8's
Old Feb 14, 2008 | 07:17 PM
Yep.
However, I'm looking into getting the connectors that are like the ones on the coils.
It is also the same connector that is used on the power steering torque sensor harness.
Old Feb 14, 2008 | 07:37 PM
Juice's Avatar
I made some poos
Ok thanks. Thinking about doing my ignition this summer. I look forward to hearing your dyno/testing results.
Old Feb 14, 2008 | 08:53 PM
No means yes
Sweet! So I take it you didn't experience any timing issues like what you were discussing previously?
Old Feb 14, 2008 | 10:35 PM
No. It turns out that the LS2 coils dwell is the same as the RX-8s.
The LS1 coils fire on the front edge.
The LS2 coils fire on the trailing edge and the dwell is controlled by rise time.
Old Feb 14, 2008 | 10:55 PM
No means yes
Cool! Sounds like a great lower-priced alternative to Mazsport solution... I think the next time my coils fail I'll get a set of LS2 coils regardless of any plans for FI...
Oh and while you're fabricating a custom mount, why not get the coils farther away from the engine block to avoid exposing them to heat and possible increase reliability? A while back you were asking about what to do to dress up your engine bay... Make a mount that conceals that rats nest of wires and get some nice bright red plug wires
Old Feb 14, 2008 | 11:12 PM
I've got red plug wires!
Doing an LS2 coil swap will not typically cost much less (if any at all) than the Mazsport solution. (Depending on your bargain-hunting capability! Thanks Mark!)
However, since it doesn't require an external igniter/converter, it can be used by folks that are restricted in the types of mods that they are allowed.
Old Feb 14, 2008 | 11:37 PM
No means yes
Yeah, I remember TeamRX8 mentioning something about this... I consider this rule bullshit since you're only replicating the functionality of the OEM coils. Ah well...
I did a quick search of ebay and saw sets of LS2 coils go for $300 ish
Old Feb 14, 2008 | 11:45 PM
If I can source the connectors, I'll cobble together some "kits" for anyone that wants one.
Otherwise, its a fairly "involved" DIY.
Old Feb 15, 2008 | 12:33 AM
  #49
swoope's Avatar
Zoom-Freakin'-Zoom
very nice job jeff..
and great thread kill....
Old Feb 15, 2008 | 01:58 AM
06carbon8's Avatar
wow, i'm glad i've kept up on reading through this. i almost started ignoring it when the original plan changed a million times. nice job on making a nice alternative work. if you make a connector kit, i'd be in line for one.
