DIY: You CAN lower the power seat!
Old Jan 22, 2016 | 09:42 AM
  #101
04Green's Avatar
Moder8
The seat does not impact headroom. If you have a cloth seat and sun roof, you have the same issues. New car is cloth and sun roof. The sun roof costs about 2".
Old Jan 22, 2016 | 09:43 AM
  #102
04Green's Avatar
Moder8
@ Huffle.
I kind of do the same thing.
Old May 30, 2017 | 01:02 PM
  #103
Snoopy's Avatar
This mod is great! Tnx guys.
Old Apr 26, 2020 | 11:28 AM
  #104
motodenta's Avatar
Easy way.
Old Apr 2, 2021 | 01:00 AM
  #105
kpack's Avatar
Seat Strip Down For Track Day
Originally Posted by auzoom
6' 5" here. Will be checking this out first chance I get.
Im 6'5" too and preparing the RX8 for its first track day. It has manual, cloth seats.
I tried flipping the rear seat hangers upside down, but my helmet was still on the roof.
I un did the 4 bolts that hold the seat pan in place and removed it from the car (disconnect the battery first, Id hate to lose an arm to an air bag), then I unclipped the seat cover from the pan.
Put the naked pan back into the seat frame, then put the foam seat squab from a racing seat, for padding.
I can now fit in the car with helmet just touching the roof lining.
I'll just place the factory seat squab back in the pan for everyday driving.
Old Apr 2, 2021 | 06:07 PM
  #106
that’s a really great idea
Old Apr 5, 2021 | 05:53 PM
  #107
Speedanimal's Avatar
Kpack, this looks way uncomfortable hahaha
Reminds me of an Ultrashield seat but with no padding and a couple good stabbing objects to keep you awake.
Have you tried looking at any racing seats with a low sitting bracket?
Old Apr 5, 2021 | 07:58 PM
  #108
kpack's Avatar
The pad is from the OPM racing seat in my RX7. I remove it for more head room when Im in the 7. Sitting on a thin pad of foam for 5 laps is not too much of a problem.
I may look into a race seat for the RX8, but at the moment it's a Sunday driver about to have its first outing at Lakeside, Brisbane, Queensland Australia
Old Feb 17, 2022 | 09:14 PM
  #109
thangos's Avatar
So basically, to be clear, am i basically flipping the brackets upside down and screwing them in the other way? with spacers? thats it?
Old Feb 17, 2022 | 09:48 PM
  #110
kpack's Avatar
Headroom Hack
I tried flipping the brackets, but that didn't give me headroom with a helmet on, so I removed the seat squab, by removing 4 bolts under the seat, then unclipped the seat pad and removed it. This makes about 40mm of additional head room. I can fit the seat cushion back to the metal frame without having to unbolt the squab again. It works well on track days.
Old Feb 17, 2022 | 10:28 PM
  #111
thangos's Avatar
I'm 5'7 and on manual cloth seats, and i still feel like in stock form id like to sit lower, but i probably don't need to go much lower to feel like I'm sitting low enough. the mod is very likely enough
Old Feb 18, 2022 | 02:43 AM
  #112
Silverhorn's Avatar
I'm 6'4" and I did this mod many years ago. Its plenty comfortable and is how I have it set up permanently. I now just barely fit with my helmet for track days. I would say for anyone up to my height it should be plenty of space. I don't need any more room myself, but I did have to remove my visor on my track helmet as I couldn't open it without it rubbing on the roof.
Old Feb 18, 2022 | 08:41 PM
  #113
hufflepuff's Avatar
what do you mean by squab? the seat cushion? you're literally sitting on the metal seat bottom tray?
Old Feb 18, 2022 | 08:42 PM
  #114
hufflepuff's Avatar
no, i think i've accidently done that twice and it was wrong. it seems like a minor distinction, but you need to flip the brackets out of the way temporarily in order to lower the seat pan below the brackets, and then rotate the brackets back to the SAME position.
when i rotated the brackets 180 degrees, that actually moves them higher and offsets some of the seat bottom lowering you are trying to achieve.
Old Feb 20, 2022 | 12:20 PM
  #115
ever get that feeling like you’re overlooking something only several posts away …
Old Feb 23, 2022 | 10:00 PM
  #116
apexglide's Avatar
Tried motodenta's method but could not for the life of me hold on to my washer stack enough to squeeze them in between the bracket and seat pan, so while I gained some room from just flipping the bracket it was minimal.
I'll have to give it another go when I get my car back or try out one of the other methods ITT.
dannobre
153
Apr 27, 2021 06:37 PM
abesRX8
Feb 4, 2019 10:15 PM
Loki
Jul 1, 2015 03:04 PM
BJP
9
May 20, 2013 10:05 PM
EricB
General Automotive
Aug 19, 2012 11:06 AM
