Gas/Oil Premix Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old Nov 1, 2013 | 01:57 AM
  #3876
Emery_'s Avatar
Zoomin'
Seems to be the same, but meh I would use something else. It's pretty pricey, and according to racing beat it's only a tcw 3.
I'm sure you could find something better locally, I get my Kawasaki fd rated gallon for $30 locally.
Posted From RX8Club.com Android App
Old Nov 1, 2013 | 09:18 AM
  #3877
I don't use Royal Purple anything. Overpriced and overhyped mediocre products.
Old Nov 1, 2013 | 09:28 AM
  #3878
hoss -05's Avatar
Lucky #33
This makes me dissapointed, The owner is a rotory guy but his products just dont hold up as well as other choices that cost a whole lot less money.
Old Nov 1, 2013 | 09:49 AM
  #3879
pistonhater's Avatar
But as said a million times over, what you choose doesn't really matter, any synthetic 2 stroke should be fine.
Besides, there's no evidence that premixing does anything for the RX-8 anyway.
Old Nov 1, 2013 | 09:51 AM
  #3880
J8635621's Avatar
Pew Pew Pew
There's no evidence that it doesn't do something either
Old Nov 1, 2013 | 09:52 AM
  #3881
Exactly. But is sure helps most of us feel better
Old Nov 1, 2013 | 10:46 AM
  #3882
Wrong.
What about the pile of premixed engines that have failed? Some even failed with the Sohn adapter, lol.
Old Nov 1, 2013 | 10:48 AM
  #3883
paimon.soror's Avatar
that just proves the engine failed, not that the engine failed in a manner which one would have expected otherwise due to premixing.
Old Nov 1, 2013 | 10:50 AM
  #3884
RIWWP's Avatar
"It's strange, I never would have expected that guy's premixed engine to fail. Never mind that he ran it out of coolant, the premix should have saved it anyway!"
(sarcasm to illustrate a point)
  #3885
Premixing is like the belief in god and prayers...it makes people feel good even if they can't find evidence that it works, LOL
Old Nov 1, 2013 | 10:55 AM
  #3886
I hope you are aware of the fact that many people including some vendors and manufacturers claim that premixing extends engine life.
So if you premix believing it will make your engine last longer but it doesn't , what else would you conclude when your engine dies young?
Old Nov 1, 2013 | 11:37 AM
  #3887
RIWWP's Avatar
That you...
...had a cooling system failure
...ran it out of oil
...the company lines clogged
...used wrong octane
...choked it to death with carbon
...had a poorly built engine
...had a severe cat clog
...had a lean spike from a failed fuel pump
...tuned it bad
....drove it through deep water with a low mounted intake inlet
...etc
Old Nov 1, 2013 | 12:06 PM
  #3888
Emery_'s Avatar
Zoomin'
If you run premix and expect it to be the end all of all your problems then wow... You have to be damn stupid.
Premixed engines that were torn down were generally much cleaner upon inspection than those that didn't run any premix. Take it as you will.
Series 2 renesis has an added oil injector in the center of the housing (along with other improvements) it's safe to say that those changes helped improve engine life. Premix fills the void that the series 1 is missing with only 2 oil injectors.
The center of housings of premixed engines have less wear.
If you think premix does nothing, then how could previous rotary engines get away with running nothing but premix on disabled OMP?
Yes it's a different engine, nonetheless the concept of premix and it's function is the same.
Old Nov 1, 2013 | 01:11 PM
  #3889
BigCajun's Avatar
Premix works.
Cause I said so!
Nana nana na na.
Old Nov 1, 2013 | 01:22 PM
  #3890
gwilliams6's Avatar
40th anniversary Edition
I'm surprised to hear you say that. I have been using Protek-R since I bought my car, and each time I placed an order through Pettit the oil arrived within a week, at times within 3 days.
The gallon is the better deal in terms of convenience. Buying the smaller bottles get old after a while.
I have been using Pettit Racing Protek-R in several of my rotary cars over the years with great results. Pettit has used this in their racing rotaries for years, as well as loads of street rotaries. I have used Amsoil products in the past and also Pettit products in my race-prepped and street rotaries and have never suffered a rotary engine failure ever, and that rules out any engine failures due to poor internal lubrication.
Everyone here is free to have their own favorite pre-mix choice. The fact is Pettit has sold a ton of Protek-R to many satisfied rotary owners,both racers and street drivers. I am satisfied that it works for my cars and will continue to use it. And I have had no problems with ordering it and delivery.
Old Nov 1, 2013 | 01:51 PM
  #3891
sweatr's Avatar
This debate will never end will it? lol, I have the ever non popular 2004 series one automatic( carbon catcher). I have some where over 84,000 miles now. I have tried several synthetics including royal purple. I am currently using amsoil in the crank case and a 2 cycle in the tank, 1/2 ounce per gallon. I am very satisfied at the performance and idle as well as miles per gallon increase i have experienced. Some folk need to quit trying to sell their point of view and just research and make your own choice and just do it. Synthetic and pre mix is the way to go for me.
Attached Thumbnails Gas/Oil Premix Thread-0731163620.jpg
Old Nov 1, 2013 | 02:00 PM
  #3892
Originally Posted by RIWWP
That you...
...tuned it bad
...etc
I don't follow your logic.
So you don't believe there's anything wrong with the false claims about premixing?
Old Nov 2, 2013 | 12:34 PM
  #3893
HexRX's Avatar
Hexrx
Wrong.
What about the pile of non premixed engines that have failed? Some even failed without the SOHN adapter, lol.
Old Nov 2, 2013 | 05:53 PM
  #3894
ASH8's Avatar
Super Moderator
This thread has run it's race..
There is more than enough information within the 150+ pages for anyone to decide on what owners want to do in regard to Pre-Mixing in Rotaries-Renesis.
The debate is now quite frankly boring and at times juvenile content.
Just to close the case of pre-mix, the only reason one pre-mixes is to add to and assist in additional lubrication of internal engine parts namely, Apex Seals and Side Seals and the surfaces which they run on.
If any owner starts to pre-mix (first time), on an old engine which has already done XX,XXX amount of miles then there is already 'wear' on these components, pre-mixing is not going to realistically assist these already worn parts.
The reality is Mazda failed to correctly identify the issue of oil management and wear in the center area of Apex Seals (hence the additional 2 injectors on 2009-2012 RX-8's) where Mazda has always had oil directly injected/applied in this area on all previous RE's from 1985-2003.
The only simple way to adequately issue oil into this 'center area' of Apex Seal is through pre-mixing in 2004-2008MY RX-8's.
Or if you choose to use pre-mix in 2009-2012 RX-8 it will not harm engine or work against it's existing first ever electronic metering oil pump system.
I am closing this thread for the foreseeable future.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Digitz0070
55
Jul 25, 2017 08:40 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
tommy26Germany
Sep 29, 2015 10:33 AM
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
