View Full Version : Servicing
AnilS
08-29-2003, 11:11 AM
Had a chat with my dealer today regarding servicing. Mazda are looking at menu servicing at are using the the RX7 servicing rates/tariffs as a guide. More info on this to come, but they tell me there is no planned "free" first 1000 mile oil change. The oil change will be at the first service.
Anil.
c170673
08-29-2003, 11:19 AM
If that is the case then I think I will be doing my own 1000 mile oil change.
Chris
AnilS
08-30-2003, 07:48 AM
Me too.
AnilS.
BlueAdept
08-30-2003, 02:41 PM
Reading the PDF of the owners handbook, I noticed that there is instruction on how to change the oil but they noted that the FILTER required a special tool to re-tighten, so I wonder if anyone has any more details... if we're all going to have to do our own 1000 mile oil change, then I suppose that we'll all need one... If anyone from Mazda is reading... perhaps they can put one in the glove box of my car?
mhopley
08-30-2003, 04:21 PM
see this thread for more on oil filter changing
http://www.rx8forum.com/showthread.php?s=&threadid=9604
Mark
AndyPearce
08-31-2003, 05:18 AM
Sounds like we should form the official UK RX8 owners club, buy one of these tools and all do our first oil change on the first meet up. I'm sure we'll all hit 1000 or so miles pretty quickly.:p
I've never been into servicing anything on my cars myself TBH - the only thing I ever do is tyre pressure and oil top ups. Are any of you other guys into DIY oil changes and if so how easy is it?
bugbear
08-31-2003, 12:15 PM
Andy, oil changes are about as easy as changing a wheel. Do you do those?
MikeLMR
08-31-2003, 12:18 PM
retightening an oil filter should not require a special tool. At a guess it will be the one size fits all Mazda filter used on the RX8. This is a "spin on" type and should never be tightened more than hand tight (its only a rubber seal anyway) otherwise its a bugger to take off.
You may require a tool to remove the filter but a universal one should work unless space is really restricted.
Mike
Jon H
08-31-2003, 01:00 PM
Hi
Changing the oil is easy as long as you have the right tool to undo the sump plug. Some cars have a standard thread so as long as you find the right sized socket you can take it off. Other cars need a special attachment, I guess this is to deter DIY servicing and help boost the incomes of our cash-strapped dealers. I dont know what the RX8 has got, the best way is for the next person who has a test drive to slide underneath and have a look - even then the pre-prod might be different so you might have to wait till you own the thing.
Anyway all you have to do is warm the oil by a quick drive round the block, then get a big container underneath - a washing up bowl is ideal, and undo the sump plug. Do not make the following mistakes I have made:
1) undo the gearbox sump plug
2) try to wash up the dinner things in the bowl afterwards (or let the wife / missus try and do it)
3) use something too small so the oil pisses out
4) put it in the wrong place so it misses altogether and see above.
Finally I doubt you need to change the filter after 1000 miles. But it has to be changed on a major service.
Cheers
JH
Titanium Grey
08-31-2003, 01:30 PM
Other things that will help.
1. When draining the system take a sharp tool (bradawl or phillips screwdriver) and punch a hole in the middle and around the edge of the top side of the filter, this allows the oil to drain out faster and makes removal of the filter less messy. Remember the filter is mounted upside down on the RX-8.
I don't know about the rest of you but I usually add an engine flush product to the oil just before warm up. What are everyones thoughts on this.
Sump plug is simple bolt and washer on all other Mazdas I've worked on.
Jon's right about using a sutible container though, get it wrong and it can be messy.
Most importantly dispose of the used oil responsibly, most local authority dump sites have a waste oil recycling facility now. So decant your used oil into the container you brought your fresh oil in and dispose of it correctly.
rich606
08-31-2003, 01:43 PM
If you haven't changed your oil before please take note (This is a TRUE story):-
I gave my Uncle the same advice I have been reading from Jon & TG.
A couple of days later he rang & said he had done everything as explained (even down to taking oil to the tip for recycling).
When I said that he'd saved himself a couple of quid & wasn't exactly hard his reply was " Yes but it's bloody time consuming so you can understand why people take them to the garage"
I asked if he'd had trouble getting the filter off but his reply was:
" Getting the oil out was fine put trying to pour the new stuff in through that piddly little hole was a nightmare!"
HE'D ONLY REFILLED THE ENGINE THROUGH THE DIPSTICK
ENOUGH SAID!!!!!!!
BlueAdept
08-31-2003, 02:34 PM
I don't know about other vehicles, but I've heard that a large percentage of the oil remains in the oil coolers even after you drain it at the sump plug... hence I would not do this on an RX8.
Jon H
08-31-2003, 03:42 PM
Oh yes, Titanium's note reminded me:
You can punch a hole in the filter to drain it - using a large screwdriver will do this, plus you can use that to lever it round and loosen it a bit. But, based on my own bitter experience...
Do not take out the screwdriver and try to undo the filter by hand, unless you want to lose more blood than the car will lose oil.
And remember to replace the sump plug before you refill the oil, otherwise you will be amazed how much oil the car needs to refill, as well as how dirty your shoes have just become!
JH
Titanium Grey
09-01-2003, 02:51 AM
Just had a thought about punching holes in the filter with a screwdriver.
Make sure its sharp and pointed because with the filter being upside down you dont want any metal shards breaking off and droppiing down through the filter into the oil pipework.
As to the oil coolers, not sure if those can be drained without creating air locks. Have to have a look and see when I get mine.
Probably get Mazda to do the first change, and see what they do.
Carl.
AnilS
09-01-2003, 02:56 AM
Just realised why a special tool is required for tightening the new filter in place .... the filter is rotor shaped.:D
AnilS.
jimbobjoe
09-01-2003, 04:29 AM
I agree. Only half the oil gets replaced in an oil change on this car. So don't add any cleaning products as it won't drain through. I'm sure the manual will detail this for us.
AnilS
09-02-2003, 12:26 AM
On the subject of oil, and being a rotary virgin, do rotaries use more oil than "normal" piston engines ?
AnilS.
jimbobjoe
09-02-2003, 02:08 AM
Yes.
The renesis engine is designed to use some oil. It has an oil injector that deliberately puts a small amount of oil into the chamber to lubricate the apex seals.
I believe that the car comes with a litre bottle of oil in the boot.
I'm sure some of the rX-7 owners can supply more details on this.
BlueAdept
09-02-2003, 05:19 AM
The oil injectors take oil from the engine itself... if there is a "Little Bottle" it can only be for an emergency top up, it is NOT like a 2 stroke bike where there is a separate oil supply.
That said, the amount is extremely small, and it is possible that you may never need to top it up inbetween regular services... There are several threads on oil consumption although I have never payed a great deal of attention to the exact amount that people are reporting burning, as I intend to change my oil more regularly than necessary anyway, so I doubt that I will ever need to know.
The Ace
09-02-2003, 05:50 AM
Please, PLEASE, PLEASE read the comments below carefully, and try to stick to this advice. Almost 99% of the rumours and "problems" you have heard about RX7s and rotaries in general is due to the inability of the car owners to do some simple checks:
1) All rotary engines consume oil. This is the same oil that is used for lubrication. There are additional -smaller- injectors that spray oil directly into the housings, in order to lubricate the apex seals. These injectors are fed by the OMP (Oil Metering Pump). Failure in ANY of these parts (low oil, oil pressure, OMP or injectors) could lead to a blown or stuck engine, so there are numerous checks that are performed by the ECU on this specific issue.
2) Since rotary engines consume oil, the oil checks should be more frequent. No need to do anything fancy, just check the dipstick more often. I used to do this every week (like Sunday morning). It is always a good idea to never let the oil level get below 3/4 between the "Low" and "Max" indicators of the dipstick. That is because you always need the maximum possible supply of oil, in order to maintain a high enough oil pressure. So, DONT NEGLECT TO CHECK THE OIL MORE OFTEN. ;)
3) Because of that lubrication of the apex seals, rotary engines burn oil. This is normal. If they dont burn oil, THEN you have a problem. So, oil is actually consumed by the engine, and so its level decreases more rapidly. It is always a good idea to carry around an additional bottle (about 1lt is enough) of the exact same oil you have in the engine. If you are on a long trip, never forget to check the oil before or after you reach your destination. Fill it up whenever necessary. Dont neglect it, and say "I'll do it tomorrow".
4) There have been thousands of discussions, posts, threads, FAQs, whole sites dedicated to the arguments "Dino or Synthetic Oil for rotaries ?". Synthetic is better at lubrication, but dino oil is cheaper, and burns more cleanly, leaving no ash behind (which is very dangerous for rotaries). However, since Mazda knows best, stick to the oil supplied with the RX8, and keep buying the same thing. Remember that if you want to change to a different type/brand/viscosity oil, you have to completely flush the engine, clean it, and only then pour the new oil in.
5) Oil changes and oil fill-ups are as easy as with any other car. Just check the dipstick, and if its below the 3/4 between "Low" and "Max", just fill in the rest. If its time for a change, simply take off the oil cap, take off oil filter, and then remove the lower bolt from the oil pan. Drain. Place all back in, and fill it up. Thats it!
6) Never, NEVER, ever add any "oil enhancement" products in rotary engines (like teflon or anything similar). These will lead to much faster failure of the engine, since they dont burn cleanly (some of them dont burn AT ALL), and they tend to build up right inside the housings. Guess what that means ?
7) Never, NEVER, NEVER (and I cannt stress this enough) drive around a rotary with low oil pressure, blown oil lines, or blown oil cooler lines. Its not a piston engine. If the rotary doesnt have oil, it WILL seize. The Renesis is supposed to be much, much "tougher" in this area than the 13B, but still you can all understand what I want to say here. If you lose oil pressure due to -highly unlikely- oil lines damage, just stop, see if you can repair what has been damaged, and if not, call Assistance. Its not worth it seizing your beautiful Renesis.......
So in general, rotaries need a bit more attention at their oil supply. Nothing fancy or terrible, just more often checks, and a bottle of oil in the car, just in case........
morganrogers
09-02-2003, 06:28 AM
Ace - fantastic post if I may say so.
Couldn't have said it better myself !
People should not be scared of the rotary - and you and I already know that some (most?) will come to love this amazing engine !
M.
RX-Late
09-02-2003, 06:43 AM
The test drive RX8 I had a spin in had a bottle of oil in the boot. Is this a standard feature?
The Ace
09-02-2003, 07:13 AM
No, I dont think so! :D
However this is exactly what I was trying to say: its a very good and prudent idea to have a bottle of oil in the trunk, in case something goes wrong, or you have gone on a very long trip, and you cannt find your brand of oil at the place you are ;)
RX-Late
09-02-2003, 07:18 AM
You are absolutely right of course. It was interesting though that the car had a bottle of oil. It was strapped into the boot side and did look like it belonged there. However, I will certainly be carrying one with me if my car doesn't have one as standard.
RobDickinson
09-02-2003, 07:22 AM
You 100% it was oil and not the tyre fix kit?
Wouldnt supprise me anyhow if it was oil.
RX-Late
09-02-2003, 07:31 AM
No definately oil. The "spare" was there as well but attached on the other side of the boot.
BlueAdept
09-02-2003, 08:14 AM
Does anyone know what brand of oil Mazda use?
The Ace
09-02-2003, 08:32 AM
I had to search the RX7Forum, but I found what is used in Greece for RX7s: Divinol Turbo 20W-50
The same viscosity should be OK for N/As as well.....
AndyPearce
09-02-2003, 09:26 AM
I spoke to the service manager while waiting for the previous test drive to come back and he told me that he had just found out that the service intervals had been confirmed at 12,500 miles but no suggested costings had been released.
morganrogers
09-02-2003, 09:51 AM
Well mine will get oil changed more than that - I assure you ! ! !
As for costings - Hope they are not in line with RX7 !
I have always felt the rotary servicing should be cheaper, in that there are only 3 moving parts ! Does not seem to work that way though.....
AnilS
09-02-2003, 10:40 AM
Firstly are Mazda going to charge an arm and leg for this oil, if we have to only buy theirs ? Secondly, if the oil is contantly being replenished, and turnover greater, why do we need to have, say a 6K oil change ?
Confused AnilS.:confused:
Titanium Grey
09-02-2003, 10:49 AM
The deposits in the oil get trapped in your filter, so your filter will become clogged over time, draining out the system and replacing the filter are essential to keeping the oil free of damaging particles.
BlueAdept
09-02-2003, 10:52 AM
On the RX8 the filler cap states clearly that it requires 5w20.
RobDickinson
09-02-2003, 10:54 AM
That on the US ones? US has some strange laws about oil that we dont.
The Ace
09-02-2003, 04:27 PM
5W-20 ? Thats a mighty thin oil........is Renesis that advanced in comparison with the 13B, and the seals are able to operate with such smaller gaps ?
Probably........
BlueAdept
09-02-2003, 04:51 PM
Yes, that is on the US ones... but I had assumed it was the same... perhaps I need to wait and see... but it'd surprise me if it's different.
AnilS
09-02-2003, 09:57 PM
Does the oil filter have a magnet in them to hold any swarf ? And if so, does that make them more expensive ?
Oil change is getting pricey. PHEW:(
AnilS.
Titanium Grey
09-03-2003, 02:35 AM
I dont think so the swarf shouldl get trapped between the one way rubber inlet seal and the filter medium.
Oil filter should cost around a fiver, you can reuse the sump plug washer if you want, the only expensive bit is the oil.
Or the hour of your time to do the work.;)
RX-Late
09-03-2003, 03:40 AM
Found some oil prices here:
http://www.shyauto.co.uk/manufacturers/76oil/76lube.htm
The Ace
09-03-2003, 04:50 AM
Hey, 5W-20 is not that bad.......In comparison with the new VTEC engines (which work best with fully synthetic racing oils), its actually a lot cheaper (more so if you use dino oil) ;)
Lucozade
09-03-2003, 09:18 AM
Thanks for all the info, I'll be getting the dealer to do mine once it arrives.
After waiting so long for the car and paying so much money for it I'm not prepared to screw things up with an oil change.:mad:
AnilS
09-03-2003, 06:52 PM
Lucozade you might be right. Have a read of this lengthy thread.
AnilS.
bugbear
09-04-2003, 12:36 AM
yep i've already seen that thread it's a good one. in summary half the oil remains in the coolers and the filter is next to impossible to remove without the special tool. the conclusion seems to be change the oil without changing the filter between scheduled service intervals to improve engine life. let the guys with the tool do the full works at the specified intervals.
AnilS
09-04-2003, 02:10 AM
Bugbear, trawling through the threads last night I found that the tool costs less than $6 in the states. Maybe £5 here ?
AnilS.
