Squeeky brakes
Old Sep 16, 2006 | 07:07 PM
Elliott's Avatar
Squeeky brakes
6500 miles on 2006 Galaxy Gray 06' RX-8. Brakes are already making noise. Anyone have the same problem?
Old Sep 16, 2006 | 07:12 PM
RotarySpirit's Avatar
暗闇立ち込めた。。
I believe there are a few people that have experience squeaky brakes. They have posted stuff on it too Search around a little bit. I would tell you more, but I honestly don't remember the outcome.
Old Sep 17, 2006 | 02:59 AM
yiksing's Avatar
the giant tastetickles
Its not a problem, it comes with all the 8. There hasn't been much remedy except maybe swap pads or a temporary cure by doing some hard braking.
Old Sep 17, 2006 | 03:16 AM
theboy's Avatar
RX8 newbie!
Its easy, here are the solutions:
solution 1, if u have a 16" or 18" wheel, put grease on the back of the brake pads. and
put them back in.
solution 2, if you are using 18" there might be another possibility, it might be due to
rusty brake rotor. take out your wheels, sand the back of the rims (the
contact point between the rims and the brake rotor), with very very thin sand.
grease them before u put those wheels back.
paper
Old Sep 17, 2006 | 08:13 AM
painter1's Avatar
If its notBLACK its wack
There is a technical service bullitan on the 04.. I brought it to my dealer and got new pads for free..
Problem Solved
Old Sep 17, 2006 | 09:24 AM
phxtravis's Avatar
I guess RX-8's are fast?!
lol....I post this everytime I see one of these threads but I dont think no one either notice's it or believes me.
After replacing my pads within 3,000miles I believe is has to do with the shim breaking off the back of the pad, in which cause the only true and permanent fix would be to replace the pads. I replaced mine with Hawk HPS and have had ZERO squeal since.
Old May 19, 2011 | 10:04 AM
bigseag's Avatar
hi thanks for the advice! hawks really work!!
Old May 19, 2011 | 11:06 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Mine's only squeaks when going on reverse. Still have a lot of pads left in it.
Old May 22, 2011 | 09:59 AM
cyonsinn's Avatar
my driver front pads squeal theyre farely new but i noticed its the only rotor with tiny lines going around it like the rotors not f'd up but its got tiny scratches could that make my brakes squeal?
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
