diffrence between 190 hp and 230 hp engine ?
Old Sep 8, 2006 | 11:36 AM
norwegianmazda's Avatar
Smile diffrence between 190 hp and 230 hp engine ?
Hei. I am from Norway and i baught a mazda rx8 with 190 hp.
Can anyone tell me what is the diffrens between the engine with 230 hp and the one with 190 hp?
What i mean is if it is possible to upgrade the 190 hp engine to a 230 hp engine ?
What parts must i change, or is it just tuning ?
.... I dont know anything about engines, so please dont be to technical
Thanks for good answeres
Old Sep 8, 2006 | 11:37 AM
Gambit's Avatar
Screw gas mileage
yeah....the 230 hp engine is what mazda says you get
the 190 is what you actually get
Old Sep 8, 2006 | 11:39 AM
vOc's Avatar
vOc
'04 Ti-Grey RX-8 GT MT
Just out of curiosity, is your car manual or automatic? Did you buy this car used or new? Did you do any research into the car prior to buying it?
Old Sep 8, 2006 | 11:50 AM
Deslock's Avatar
WWFSMD?
One of the primary differences (if not the biggest difference) is that your engine has 4 ports instead of 6, so your engine can't breath at really high RPM and has a lower redline. I dunno if it's cost effective or even possible to upgrade your engine to 6 ports. Also, you probably have a 5-speed manual or 4-speed auto... I believe that all high power engines come with a 6-speed manual. Here in the USA, all RX8s now have 6 ports and 6 speeds, regardless of transmission type (though the auto is still rated at slightly less power).
Old Sep 8, 2006 | 04:13 PM
norwegian mazda answeres:
I baught this car new from Germany imported to Norway. The car has 5 speed manual gear.
Old Sep 8, 2006 | 04:15 PM
Ike's Avatar
Ike
Blue By You
I know I know! 40hp!
Old Sep 8, 2006 | 04:16 PM
NoTears316's Avatar
Shock and Awe
A 5 speed manual? Never heard of one.
edit: I'm a stupid American, I guess there is a 5 speed manual being sold in other countries.
Old Sep 8, 2006 | 04:23 PM
rodrigo67's Avatar
Europe gets a high powered car and a low powered car, both are available as manuals...
Old Sep 8, 2006 | 04:28 PM
Revolver's Avatar
Shootin' from the hip
You probably don't want to hear this but the only effective way to do it is to trade in for the higher powered car with a six speed manual.
Sorry, it seems you bought the wrong one if you want the 230hp model.
Old Sep 8, 2006 | 04:32 PM
If it is the same engine it schould be possible to upgrade the 190 hp to 230 ?
Old Sep 8, 2006 | 04:34 PM
Moostafa29's Avatar
Storm Trooper
Just take advantage of the lower compression and turbo that baby.
Old Sep 8, 2006 | 04:37 PM
Revolver's Avatar
Probably right but then you're still stuck with the 5M. Personally, I think it would be easier all round to just trade up. Obviously, it'll cost but so will an upgrade.
can you buy a turbo for the car ?
Old Sep 8, 2006 | 04:38 PM
two rotors's Avatar
It is not the same engine.The major difference is the usw of additional auxiliary inlet ports.It would be costly to upgrade.
Old Sep 8, 2006 | 04:39 PM
Revolver's Avatar
Yes you can.
I recommend you spend a bit more time looking through the forum. There's plenty of good info in here.
Old Sep 8, 2006 | 04:40 PM
Revolver's Avatar
Well, there's your answer.
Old Sep 8, 2006 | 04:41 PM
Revolver's Avatar
cars are very expensive in Norway. I payed 470 000 norwegian kroners (about 70 000 dollars) and the high power engine costs 100 000 kroners more ( 15 000 dollars)
Have you considered moving?
Old Sep 8, 2006 | 04:44 PM
how much will a turbo cost ?
Old Sep 8, 2006 | 04:46 PM
Revolver's Avatar
I give up.
Old Sep 8, 2006 | 05:46 PM
glassetcher's Avatar
'04 MT RX8/71 351C Mach1
From my limited knowledge (mostly from the RX-8 anthology by Yamaguchi and Dinkel) the engines are very different. As stated previously, 3 intake and exhaust ports vs. two, totally different intake system, horespower difference (as you know) and red line difference. One of the reasons the automatic (USA - prior to 2007)) and 5spd (Europe) gets the lower horsepower engine is the transmission can't take the 9000RPM red line of the high power (MT) engine. Thus, unless I'm missing something, the only way to "upgrade" the engine to the MT version is to do a total engine swap for the high power version. But then your 5sp MT won't be able to handle the high RPM.
"Love the one you're with" or go find a good price on a 6sp MT.
Zoom, Zoom!
Old Sep 8, 2006 | 05:58 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Originally Posted by Revolver
I give up.
Indeed.
Old Sep 8, 2006 | 07:34 PM
Ike's Avatar
Ike
Blue By You
70,000 kroners and one goat
Old Sep 13, 2006 | 06:56 AM
thankyou all for good answeres!
Old Sep 13, 2006 | 08:34 AM
The Ace's Avatar
Greek Power
To the original poster: you asked the question in the wrong forum
US guys don't know jack about the 4port 5MT version that Japan and Europe have, since all they have is the 6port 6MT and the 4port 4AT versions.
Differences between the two versions of Renesis:
- 6 ports instead of 4 ports (main difference, hence the respective "names")
- 2 additional injectors for the 6port (more air, hence more fuel needed)
- S-DAIS different in 6port. Can't explain it fully in words (you should look for the picture explaining it), but it works in a way that above 5750rpm a special valve connects the two chambers so that the pulse of one rotor causes the intake charge to be "pushed" into the other, thus producing a small (5%) boosting effect.
- VFAD in 6port, which allows the S-DAIS to work as it should over 6000rpm
- Obviously different fuel maps (not only because the extended redline to 9000rpm, but also because of additional injectors and added fuel needs)
What the above come down to is this: 231HP/8500 and 21.5Kgm/6500 for the 6port, 192HP/7300 and 22.5Kgm/5500 for the 4port.
I think I covered most of them.....
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
cschoeps
Aug 6, 2015 12:44 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
