CEL after specific driving pattern
Old Sep 8, 2006 | 06:21 AM
andreasy's Avatar
I don't know if this can be reasonably explained but I got a CEL 3 times in 2 months and it was always after the following driving pattern:
Constantly driving under low RPM and then suddenly accelerating to very high RPM (9500). Usually I drive in this fashion but when it gets very intensive and for a long time, I may get the CEL.
Is it a coinsidence again or it can be justified?
Old Sep 8, 2006 | 06:29 AM
Nopstnz's Avatar
Blinking Cel that eventually goes away or constant cel?
Old Sep 8, 2006 | 08:25 AM
andreasy's Avatar
constant that never goes away
Old Sep 8, 2006 | 10:15 AM
Aseras's Avatar
what is the cel? go pull the code.
Old Sep 8, 2006 | 12:39 PM
Nopstnz's Avatar
Yes, get the code, if it was blinking then it is a misfire.
Old Sep 9, 2006 | 12:24 AM
andreasy's Avatar
Now the CEL is suddenly off. That happened the other times as well. It goes away after 3-4 days. Can I still find the code if I take it to the garage or it must be on at the time they connect it to their device?
Old Sep 9, 2006 | 10:37 AM
NotAPreppie's Avatar
What am I doing here?
Yah, the code should still be stored.
For a momentary fault that didn't run any immediate danger of damaging components, you usually get a solid CEL. The fault condition may go away but the CEL will take a few engine start/stop cycles to turn off. However, the code should still be present in the computer.
Old Sep 10, 2006 | 06:02 AM
andreasy's Avatar
This is exactly what happens. It stays on for about a week, then it turns off for about 2 days and then on again. At the garage they told me it is shown as unspecified/generic error
xAgyex
Jun 3, 2026 03:47 PM
ladnarf1
Apr 29, 2021 11:53 PM
uZu
Dec 30, 2015 12:35 PM
Rx808BI
Aug 9, 2015 10:06 AM
dbarber
Jul 25, 2015 01:34 PM
