The Tube That Connects to Nothing???
Old Sep 4, 2006 | 10:14 PM
H8SUVS's Avatar
Cubicle Monkey
I was checking my oil just as any good owner should and I happend to notice a tube that didn't connect to anything. It seems pretty obvious where it should connect, but I just got the car new 2 weeks ago and would the factory miss something like this??? It looks like it should be a breather hose of some sort since it connects to the intake tube. I guess there are 2 other tubes that connect to the same general area just before the throttle body. Looks like it would just be missing an elbow connector. Does anyone know where on the engine this connects to and if there would be anyy possible damage from running the car almost 1k miles without it connected???
Old Sep 4, 2006 | 10:19 PM
saturn's Avatar
i pwn therefore i am
My guess is that it should be connected to teh Internets as it is just a series of tubes. No wonder I couldn't download my pr0n last night -- your damn tube was disconnected screwing up the entire web!
Old Sep 4, 2006 | 10:27 PM
MazdaManiac's Avatar
It is the hose to the air jet port or the oil metering pump, I can't remember which exactly.
Both supply a "bleed" of air to the motor to atomize fuel or presurize the oil ports respectively.
It would be better that it got its air from the filter rather than the open engine bay as is it like that, but it wouldn't be likely to have caused any catastrphic damage in such a short period.
Why it is missing completely, I can't comment. Most of the time that I have seen damage to that hose, the "L" adapter is usually broken rather than absent since it gets brittle after long exposure to heat. Yours was simply deleted for some reason.
Old Sep 4, 2006 | 10:34 PM
H8SUVS's Avatar
Cubicle Monkey
Damn Guys, thanks for the quick response!
I'll head to the dealer tomorrow and get an elbow connector tomorrow if I have time. I think I'll take some time this weekend to get under the car and see what other cost cutting measures were taken by Mazda on my car.
Sorry for messing up everyones pr0n connections.
Old Sep 4, 2006 | 10:46 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
u could also but a breather on it if u wish... According to the diagram, it should be the crankcase breather
Old Sep 4, 2006 | 11:09 PM
H8SUVS's Avatar
Cubicle Monkey
Excellent Diagram! Now I can sleep tonight knowing it was just a crankcase breather hose. I'll see about getting that taken care of tomorrow. Thanks for staying up late to look into this for me
Old Sep 5, 2006 | 01:37 AM
it's a huge vacuum leak after the MAF, lucky you haven't blown the engine ...
Old Sep 5, 2006 | 02:05 AM
There is no vacuum before the TB.
It is possible to take in un-metered air, but not enough to blow anything.
Old Sep 5, 2006 | 02:43 AM
correct, should have said suction leak because it will pull in air that is not only unmetered, but also unfiltered
meaning anything large enough to fit through the orifice could get digested by the engine ...
Old Sep 5, 2006 | 06:32 AM
RX8PDX's Avatar
Correct me if I am wrong....
But that cant be a crank-case breather, right?
Since we dont have a crank and all?
:D
Old Sep 5, 2006 | 09:55 AM
There is, actually, an oil cavity breather for lack of a better word that serves a similar function.
However, that is not it.
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Nov 24, 2015 01:00 AM
archon
Oct 1, 2015 06:08 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
