Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Recall Notice - Got it saturday
Old Sep 4, 2006 | 07:57 PM
chr1s's Avatar
pwn*
anyone else from the dfdub get it?
Old Sep 4, 2006 | 09:06 PM
Raptor2k's Avatar
Club Marbles Member
I don't think I'll get it, since I got my car used.
Old Sep 4, 2006 | 09:09 PM
canaryrx8's Avatar
I gots mine, but I'm Austin yo!
Ajax's Avatar
just checked my mail. dont have it yet.
i might not get mine since mazda isnt too keen on keeping up to date w/my address changes.
I'll be going to the dealer this week anyway for oil change and stuff so i might as well have them check everything.
Old Sep 4, 2006 | 09:17 PM
Raptor2k's Avatar
Club Marbles Member
But it's not like we need it, right? All they have to check is the VIN.
Old Sep 4, 2006 | 09:20 PM
theCATALYST's Avatar
In darkness I sleep.
Mine is a lease, and I never recieve notices of this type. I do plan on keeping her, so I guess I can just take her in to get looked at?? Any ideas?
Old Sep 4, 2006 | 09:24 PM
jenkins-crew's Avatar
got it...
Old Sep 4, 2006 | 09:25 PM
Str8cold's Avatar
What is the recall regarding?
Old Sep 4, 2006 | 09:33 PM
Ajax's Avatar
possible engine replacements due to oil leakage..
check out the rx8-media news forum for full details.
everyone should get the notice, no matter if you lease or own.
Old Sep 4, 2006 | 11:20 PM
chr1s's Avatar
pwn*
Yup. I had to actually call MNAO and update my information with them, even though I've had a few trips to the dealership for TSB's. The dealer will not automatically do it for you.
So, if you haven't been getting any notices, might want to try calling mazda.
Old Sep 5, 2006 | 12:36 AM
rotory1's Avatar
Rotary redliner
RotaryNews.com has confirmed that there will be a recall on the 2004, 2005 and some 2006 Mazda RX-8s. Not every RX-8 will need a new engine, only those that fail a series of tests, including a new vacuum test. The replacement engines will correct for issues ranging from flooding, hard starting, complete loss of compression, and use of Synthetic Oil in hot climates. For those that do not require an engine replacement, the ECU will be reflashed to provide for more lubrication (an already released Flash). Recall notice letters will be sent out to owners on a staggered schedule. At this point some dealers do not know about the recall, as the bulletin has not been sent.
Jeremy Barnes from Mazda Public Relations stated: "We will not walk away from any Mazda owner." Jeremy also pointed out that other issues that have escaped on the Internet as of late were only part of the story. He hopes the recall action by Mazda will show owners that Mazda is doing the right thing after all.
We at RotaryNews say, if you own an RX-8, check over this list of TSB's (Click Here). If your car is experiencing any of the issues listed on that page, print out the ones that apply to you, and bring them down to the service department while they check your car for the other recalls. We, at RotaryNews also say: "if in doubt, do NOT use Synthetic Oil." For those of you that are "Rotary Gods" (!) and know what you are doing, it is OK, other wise stay away from synth, and use the good old Dyno Juice.
Old Sep 5, 2006 | 12:39 AM
rotory1's Avatar
Rotary redliner
RX-8 Service Bulletins
Customers should not assume this bulletin applies to their vehicle or that their vehicle will develop the described concern. To determine if the information applies,
customers should contact their nearest authorized Mazda dealership.
2004 RX-8 Front Lower Arm Ball Joint Recall Owner Letter
2004 RX-8 Front Lower Ball Joint Recall Repair Procedure
2004-2005 RX-8 Thermal Damage Recall Owner Letter
2004-2005 RX-8 Thermal Damage Inspection / Repair Procedure
2004 M/T Dynamic Damper Heat Shield Replacement Recall
2004-2006 RX-8 Powertrain Warranty Extension Program
SQUEAKING NOISE FROM SUNROOF
2004/06 RX-8 A/C CONDENSER PROTECTOR SET
MANUAL TRANSMISSION - CLUTCH HARD TO DISENGAGE
HESITATION / IDLE VIBRATION DUE TO CRACKED ENGINE MOUNT
TPMS VALVE STEM BREAKS WHEN REMOVING AFTERMARKET VALVE STEM CAPS
INSTRUMENT PANEL NOISE - DRIVER SIDE
BROKEN PARKING BRAKE LEVER COVER
W / SUNROOF - OVERHEAD CONSOLE LID HARD TO OPEN
SQUEAL NOISE FROM FRONT BRAKES DURING BRAKING
SHIFT PANEL REMOVAL CAUTION - SERVICE TIP
NAVIGATION SYSTEM DISPLAYS NO MAP OR INCORRECT MAP
ENGINE CRANKS - NO START
CLEARING ECCENTRIC SHAFT PLATE PROFILE MEMORY FROM PCM
FUEL DISTRIBUTOR INSULATOR - REMOVAL / INSTALLATION CAUTIONS
REPLACEMENT BATTERY
RETRACTABLE KEY TRUNK RELEASE BUTTON - REVISED HOLD DOWN TIME
DTC P0336 DURING ENGINE START - SERVICE TIP
REDUCTION OF TIE DOWN PLUGS
DASH CENTER PANEL (AUDIO, RADIO, CLIMATE CONTROL) REMOVAL
FRONT LICENSE PLATE FRAME MOUNTING INSTRUCTIONS
TPMS WARNING LAMP ILLUMINATED AND A WARNING BUZZER NO DTC
TEMPERATURE CONTROL DIAL AND / OR FAN CONTROL DIAL BREAK OR COME OFF
MIL WITH DTC P0128 AND / OR P0456
2004 RX8 HVAC Temp and Fan Dial Availability
LOW OIL LEVEL WARNING LIGHT COMES ON WHEN LEVEL IS NOT LOW
RX8 DIFFERENTIAL OIL
ROOM FUSE REMOVAL / INSTALLATION CAUTION
ENGINE COVER GROMMETS MISSING
SNAPPING NOISE WHEN TURNING AT LOW SPEEDS - 18" WHEELS
INTERIOR TIRE HOUSE TRIM LIFTING OVER BOTH REAR WHEEL HOUSINGS
MIL ILLUMINATION WITH DTC P2107, P2108 OR P2109
DOME LAMP FLASHING AND / OR CLICKING SOUND FROM REAR DOORS
REAR QUARTER WINDOW GLASS LOCK BECOMES LOOSE
A/C AIR TEMPERATURE FLUCTUATION AND / OR LACK OF COOLING
SOLVENT CRACKS ON REAR COMBINATION LIGHTS AND/OR FRONT SIDE MARKER LIGHTS
INTERFERENCE BETWEEN TRUNK, REAR COMBINATION LAMPS AND/OR REAR BUMPER
DRIVER'S SIDE AIR BAG RATTLE
CHIPS AND SCRATCHES IN FRONT SEATBACK COVER - LEATHER SEATS
POWER WINDOW INOPERATIVE
REAR WINDOW DEFROSTER GRID LINE DIAGNOSIS / REPAIR AND TERMINAL TAB REPAIR
NEW ENGINE OIL DIPSTICK
CONTACT MARKS ON CENTER OF SIDE SILL
MIL WITH DTC(S) P0126, P0420, P0456, P2404, ENGINE QUIT, OIL LEVEL WARNING LAMP
MAZDA SPECIAL PROGRAM (MSP04) - POWERTRAIN CONTROL MODULE (PCM) REFLASH
MILKY SUBSTANCE ON OIL LEVEL GAUGE (DIPSTICK)
SPARK PLUG INFORMATION
Old Sep 5, 2006 | 04:56 PM
Raptor2k's Avatar
Club Marbles Member
Nm, I got mine
Old Sep 5, 2006 | 06:02 PM
Ajax's Avatar
same here, lol.
Old Sep 5, 2006 | 06:06 PM
chr1s's Avatar
pwn*
im dropping mine off at the dealer tonight. They should have it ready by tomorrow barring the engine swap.
Old Sep 5, 2006 | 06:12 PM
FRANCES's Avatar
Does anyone have any idea when those of us in Corpus Christi might be at bat for the letters?
Old Sep 5, 2006 | 06:22 PM
cowboyup75146's Avatar
what yr model?
Old Sep 5, 2006 | 06:31 PM
woops got 2 in the mail just now, one on emissions , 2nd power train ext. warranty
Old Sep 5, 2006 | 06:37 PM
Ajax's Avatar
right. we all get a free powertrain extension to 60k!
that actually sucks cuz i was gonna go FI at 48k :b
Old Sep 5, 2006 | 06:44 PM
Raptor2k's Avatar
Club Marbles Member
Hopefully there will be bolt-on S/Cs by then (at least when I hit 50k), so that when something may go wrong....
Old Sep 5, 2006 | 07:13 PM
FRANCES's Avatar
what yr model?
2005 bought new in June 2006. Only 3000 miles so far.
Old Sep 5, 2006 | 07:14 PM
FRANCES's Avatar
Oops, wife just said it came in mail today...
Old Sep 5, 2006 | 08:28 PM
BigOLundh's Avatar
#1 Legend
I need to update my new address with MNAO.
I'll do that later this week.
I wonder if me and Jenkins will qualify for new engines since we're boosted. Chris, let me know how it goes.
-Harry
Old Sep 5, 2006 | 09:23 PM
Creto's Avatar
It's good to be the king.
Got mine.
And Raptor, there's one avail from Blitz for 4.5k
Old Sep 5, 2006 | 09:45 PM
RX8Carnage's Avatar
I got mine today and the warranty info doing it Thursday gonna get a loaner from the dealership said it could be all day for the test's anyone else in San Antonio get theres
