View Full Version : So whose taken off the Engine Cover
Shocka 08-27-2003, 09:38 PM Ive been wantin to look at the engine but never got around to takin the covers off from under hood.
if anyone has.. got ne pix..
sux i started a new job and havnt had time to spend with my new baby.
8_wannabe 08-27-2003, 09:46 PM Originally posted by Shocka
Uh, this may be a silly question but instead of tapping away on the keyboard here why don't you go down and pop off the engine cover? Not that it's any of my business. :)
Here's a pic with the cover off. (http://www.igs.net/~lpopp/rx8/album5.html) But if you have time to read this, you have time to open the hood and lift off the cover!
Shocka 08-27-2003, 09:52 PM its dark.. by the time i get back from work its dark... sux...
maybe tihs week.. i think i wanna leave it of, it shouldnt have any negative effects should it?
TJRX8 08-27-2003, 10:09 PM It helps keep the engine clean from road dust.
rx8daniel 08-28-2003, 12:13 AM You must take off the main cover to add your oil - if you've driven over 500 miles surely you may be wanting to add some. Please at least say you've checked the level if you've driven over 100 miles?!
Squidward 08-28-2003, 02:29 AM Originally posted by rx8daniel
What's wrong with the gauge on the dash?? is it not accurate?
Shocka 08-28-2003, 06:56 AM well i just toped 100 last nite.. so ill try to check it today when i get home from work
rx8daniel 08-28-2003, 07:40 AM that's great! I drive at least 90 miles any one day I drive it to work. The deal with the pressure gauge (it's in another thread of course) is that the gauge is in reality a 'dummy light' - if you have any pressure it looks the same as any other amount of pressure. In other words it's not reflecting the amount of oil or pressure but the presence of a minimal amount of pressure - you'd probably have to be a coupe quarts low, at least, to lose all presence of oil pressure so it can in no way be used as a guide to oil level...
which reminds me again - has anyone determined if we can get a real oil-pressure sending unit thingie for the Renesis??
A. It's shows oil pressure, not quantity
B. It's not a gauge, it's an idiot light in drag
C. Check your oil
Dave
vudoodoodoo 08-28-2003, 12:53 PM LOL!!!
8_wannabe 08-28-2003, 12:59 PM Originally posted by rx8daniel
I agree with the need to check and add oil, but I do both without removing the engine cover.
P00Man 08-28-2003, 01:07 PM how do you add oil without removing the cover? do you have a custom cover? or do you not use the fill-hole (not proper name...the opening underneath the yellow cap)?
________
Franco Cortese (http://www.ferrari-wiki.com/wiki/Franco_Cortese)
8_wannabe 08-28-2003, 01:10 PM Originally posted by P00Man
Sorry, my bad... it was a dumb comment. I haven't had to add oil yet (after 2200 miles, still nearly topped off.) I thought I recalled seeing the fill cap with the engine cover on, but I was wrong. Still, I can reach the dipstick without removing the cover. It'd be tough if you've got beefy hands.
LesPaul 08-28-2003, 01:23 PM I've had real trouble reading the dip stick. The oil seems so clear I have to feel for the wet spot. I suppose as the oil gets used and darker I'll be able to see it better.
jtimbck2 08-28-2003, 01:33 PM Originally posted by LesPaul
But then it will be time to change it :eek:
Like others here, I have not had to add oil yet -- when I check it always looks full. I have almost 900 miles on my RX-8. Now I'm wondering if I'm reading the dipstick correctly.
f1michel 08-28-2003, 02:32 PM Don't worry, pretty soon the oil light (just above the cruise light) will show and you'll think: "what the hell" than check the oil and see you're half way between the marks.
There was another thread about this earlier
Squidward 08-28-2003, 04:36 PM Originally posted by XK4
C. Check your oil
Dave
Oh, I must be idiot.. okay okay I go do C now..
hehe :D
B-Nez 08-28-2003, 08:53 PM Originally posted by LesPaul
Tilt it at an angle under good lighting, and you should be able to see the level. Good lighting is key. I have to use a drop light in my garage - at least until I get the mondo duo-flourescents installed. Makes a real PITA to Zaino in the garage at night, too.
