Detonation Pic!!!
Old Aug 28, 2006 | 07:16 PM
neit_jnf's Avatar
Detonation Pic!!!
Taken from the 7 forum:
http://www.kenscheepers.com/Rotor%20...e%20005-sm.jpg
Old Aug 28, 2006 | 07:24 PM
dillsrotary's Avatar
jersey fresh
holy hell!
Old Aug 28, 2006 | 07:25 PM
Moostafa29's Avatar
Storm Trooper
Geez!!!!
Old Aug 28, 2006 | 07:31 PM
NgoRX8's Avatar
oh man... that looks scary...
Old Aug 28, 2006 | 07:39 PM
rotarygod's Avatar
That is one possible outcome. That was most likely at VERY high boost levels. Typically you'll just break seals.
Old Aug 28, 2006 | 07:51 PM
neit_jnf's Avatar
according to the thread at the 7 forum this was at 50psi boost and the seals survived
Old Aug 28, 2006 | 07:56 PM
rotarygod's Avatar
Some of the seals those guys use are extrememly tough. They also wear the housings down faster than Mazda seals do too. The logic is that stronger seals are cheaper when it comes time for a rebuild since you won't have to replace them. They never seem to realize that something else breaks, takes other parts out with it, and it all still costs a lot in the end. If you break nothing, you still have worse housings wear to deal with.
Old Aug 28, 2006 | 08:21 PM
RX8Maine's Avatar
I wonder what that sounded like.
Old Aug 28, 2006 | 11:34 PM
He must be using Synthentic Oil !!!!!!!
Old Aug 29, 2006 | 12:44 AM
Stavesacre21's Avatar
1.21 Jiggawatts
ok, i'm gonna sound like the moron of the group here, but i'll speak for those like me less inclined to know....what caused this? And yes, i know it's obviously detonation...but what caused that?
I mean, that's absoultely nuts to blow a hole in part of a rotor...
Old Aug 29, 2006 | 03:56 AM
Nubo's Avatar
Lubricious
The higher the compression ratio, the more likely detonation. The tendency can be countered by higher octane, cooler intake, less spark advance, but at some point there is only so much air and fuel you can squeeze into an given space without exploding.
This engine was being force-fed fuel and air at 50 PSI over atmospheric pressure. That's over FOUR TIMES normal atmospheric pressure, with fuel to match. And that huge fuel/air charge was then compressed to the same small space as an air/fuel charge on a normally-aspirated engine. That's a huge amount of energy in a small space. When it exploded (detonated) instead of burning smoothly, all of its energy was released at once, instead of being spread out over time. Basically, a bomb. You can see that the rotor face isn't really all that thick. It's strong enough to withstand combustion, but not bombs.
I guess this could also have been caused by a bolt or something getting sucked into the engine, but I don't see any scratches
Old Aug 29, 2006 | 06:21 AM
neit_jnf's Avatar
running lean at 50 psi caused the detonation. and for clarification, this is NOT a Renesis rotor
Old Aug 29, 2006 | 11:03 AM
rotarygod's Avatar
Mazdatrix has a page about the effects of overboost on an engine:
http://www.mazdatrix.com/faq/boost.htm
Old Aug 29, 2006 | 11:05 AM
brillo's Avatar
Go Texas Longhorns!
really? 50psi? No F&%king Sh*t
Old Aug 29, 2006 | 11:13 AM
Good Grief!
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
archon
Oct 1, 2015 06:08 AM
FubarI33t
Sep 28, 2015 08:45 PM
