If our engines get replaced…
Well, if they WHOLE engine block is replaced, I wouldn't see any reason why you wouldn't. The reason engines have a break-in is specifically for block/rotor as opposed to any other subsystem.
First for the long answer. Even a remanufactured engine needs to get broken in. They may use the same housings and plates but the seals are all knew. If you rebuilt an engine with the same seals but didn't reinstall them in the same place that you got them from, you need to break in the engine again. The only way you wouldn't need to would be if they pulled the engine apart and put everything back exactly where they got them. This means every seal in the exact same groove that it came out of facing the exact same direction. At this point, there was very little use rebuilding it.
The short answer is yes. Break it in.
Originally Posted by Raptor2k
It's funny how so many owners are expecting their engines to replaced.
When a rotary engine is rebuilt, does the housing get honed or overbored? If overbored, is the rotor replaced with a larger one?
Just thinking of the analogy with a piston engine. In a true rebuild, cylinders are bored out, crank journals reground, and the mating parts (pistons and bearings) replaced with the corresponding new sizes.
Ken
Ken
Originally Posted by Ike
Any idea what a typical reman would have done to it? For instance, all the engines that have been replaced in hot climates, what are they going to have to do to them to make them "good" again? Are they simply replacing the seals or is there more to it?
Ken
Ken
See my post on if you love your 8.. Has updated info on recall.. Plus no they don't reset the odometer.. They do however by law have to put a sticker some where on your car(usually in the door frame) saying the engine was swapped at whatever mileage your car is at.. So, you will have proof and makes a good selling point.. But very very few people with get engine swaps.. Most with be fix with some new software..
I can't vouch for the impressions of others, but if properly done a rebuilt engine will be just as good as a new engine. Possibly better, since the castings are seasoned.
That's if properly done, of course. Not so if an engine presented as rebuilt is really just overhauled.
Ken
Ken
I'm not sure if the automotive world thinks this way, but there are basically 3 types of aviation engines; new, remanufactured and overhauled. A new engine is, of course, new. In a remanufactured engine, every part meets factory-new tolerances, regardless if it is a new part or used part. Also, in a reman engine, parts that have time limits (calendar or operating hours) are replaced regardless of how well they measure out. An overhauled engine may require some new parts during the overhaul, but it will likely have some parts that fall within the allowable wear limits. Allowable wear limits are not the same as factory new tolerances.
I think one could conclude that the first 2 engines will likely run to their expected TBO (time between overhaul) with little or no problems, but the overhauled engine might have some parts go beyond wear limits before reaching the same number of hours as the new and reman engines. So, the overhauled engine will likely need major work sooner than the first 2 engines.
1.3L
1.3L
Nah, because they don't actually give you a new engine
I hope my 11.5K mile engine doesnt get replaced.
I have a 2005 that is in the shop here in Vegas getting a new motor. It went in for stalling and a clicking noise and the dealer called yesterday to say they had ordered the new motor from Mazda and it will take 7-10 days to get here. They told me they are replacing with a new motor and it should be stronger than the original. My car only had 21000 miles on it.
A little insight on Mazda Reman motors.
Housings, Eccentrics, Oil Pans are re-used if possible. Just about everything else is new including Rotors and Gears. It costs more to clean up and check to spec let alone any machining/resurfacing then it does to just pull new parts off the line.
Thats one of the beauties of a rotary - they're relatively inexpensive to build.
cschoeps
Aug 6, 2015 12:44 PM
dbarber
Jul 25, 2015 01:34 PM
