Is excessive oil use an indicator of the recall issue?
Old Aug 22, 2006 | 05:59 PM
Curley's Avatar
Does anybody have any idea whether excess oil consumption is an indicator of the problem that's causing the upcoming recall?
My 8 -- which only has a little over 3K miles on it and has been perfect so far -- has used about a quart per 1,500 miles. I'm using Valvoline 5W20, not synthetic.
But I have no idea if that's "normal" for the RX-8.
Old Aug 22, 2006 | 06:01 PM
Tirminyl's Avatar
Listen to Zoom44
Yes. Next your transmission will go due to the oil in it. Your tires will turn against you and your cat will swallow your car.
BlueSky's Avatar
Search. 1 quart over 1500 miles is very normal.
Old Aug 22, 2006 | 06:03 PM
otherside's Avatar
I dont care...
That is perfectly normal. There are many threads related to this topic. I recomend doing a search to get more input.
Old Aug 22, 2006 | 06:34 PM
BunnyGirl's Avatar
Mine doesn't use quite that much but it seems pretty normal.
Old Aug 22, 2006 | 09:09 PM
search. to damn funny...
Old Aug 22, 2006 | 09:21 PM
TKE's Avatar
TKE
Oil consumption depends on your driving style. Under normal driving conditions yours sounds spot on.
Old Aug 23, 2006 | 12:50 AM
silverx8's Avatar
Early in their life oil consumption is higher to break it in. I bought a bunch of oil in the first 7K miles, then it just sat around. But when the motor climbs to high revvs (8K), oil consumption skyrockets.
drebbrnator
Dec 27, 2018 07:02 PM
SUKIEE
Oct 9, 2017 09:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
dbarber
Jul 25, 2015 01:34 PM
