flooding on a new car?
Old Aug 19, 2006 | 04:50 PM
TKE's Avatar
TKE
Probably covered a million times already, but i suck at searching. I know the FC's have flooding issues due to old cloged injectors. What would cause a new 8 to clog since it has brand new clean injectors?
Old Aug 19, 2006 | 05:05 PM
LostAngel's Avatar
Shutting the car off while cold can cause flooding. Make sure to warm the car up before shutting down.
Old Aug 19, 2006 | 05:57 PM
TKE's Avatar
TKE
I know under what conditions it will flood. The question is why it floods.
Old Aug 19, 2006 | 06:26 PM
Mazmart's Avatar
Here's the simplest explanation I can offer: Any engine can flood but rotaries are more prone to it because they have less static compression and the worst area of flame propogation of any internal combustion engine (Long, thin and almost divided), not to mention the motion of the rotor sweeping past the sparkplugs is more likely to put out a flame than the manner it takes place in a piston engine. Because of these issues and the relation of rotor speed to shaft speed they desire more ideal conditions to start effectively. These would include: Proper sealing, proper spark, the correct amount of properly atomized fuel and sufficient cranking speed. When you have some part of this equation impaired your ability to start will be impaired. Weak batteries lead to slow cranking and the Renesis side exhaust port design doesn't lend itself as well to the elimination of excess fuel as the older designs (Peripheral exhaust).
Luckily, it seems Mazda has reduced the chances of this occurence greatly.
Hope this helps a bit.
Paul.
Old Aug 19, 2006 | 08:20 PM
TKE's Avatar
TKE
Thanks, guys. Damn side ports!
Old Aug 19, 2006 | 11:28 PM
swerver's Avatar
My 2 cents...........I was all worried about flooding as well when I bought my 8 but I've got to the point where I don't even consider it anymore. I crank it up and shut it down regularly. I'll move it 12 feet and shut it down again...............
In fact, I actually tried to flood it (well not by doing anything stupid but by starting it and shutting it down again repeatedly)..............the "new" starter fired the engine every time without the slightest moan.......................
Like I said, just my two cents, this thread is over emphasized................
Old Aug 20, 2006 | 12:53 AM
ken-x8's Avatar
What was the ambient temperature?
I moved mine out of the garage into the driveway today for a wash and wax. Temp in the 80s, but being chicken I let it run and warm up while I gathered the hose and other implements of cleansing. Did the rev to 3K before shutoff, too.
I'm curious about what temperatures people have had flooding.
Ken
Old Aug 20, 2006 | 07:58 PM
swerver's Avatar
Im in North Carolina so it bloody hot here now. I bought the 8 in April, so its been relatively warm the whole of my purchase.
I know flooding is an issue but with the new starter, it just rolls over quickly. I'm just saying that I've given up worrying about it. I drive it. I park it. I move it...............no big deal
(of course, now I'm jinxed)
Old Aug 20, 2006 | 08:18 PM
ken-x8's Avatar
I'm in Virginia, only had my 8 a month, so I haven't hit the cold flooding weather yet either. I think I did stall it once backing out of the garage, and it re-started with no problem.
Following the ritual yesterday was no problem. I had to move the car out first to get to my cleaning stuff stash. Letting it run just used a little gas - but if you have one of these you cannot let yourself obsess over using gas.
I did have one "do I warm it first?" episode a couple of weeks ago when I was checking out of a motel. Threw my stuff in the trunk, then drove around to the front. I wondered how much to believe the procedure in the Orientation film...er, I mean Product Update DVD. I let it warm up. Chanted "4 8 15 16 23 42" to help pass the time.
Ken
Old Aug 20, 2006 | 08:41 PM
swerver's Avatar
...........and I've got a friend here in NC that bought one of the first 8's in 2004. I was all "hot and bothered" about the flooding issue and he said the same thing. He simply quit worrying about it (and his is an '04) Sure, one can't discount that flooding has happened, but IMHO, the statistics are skewed.
You only read about it here when it happens. You DONT read about the other 8 gazillian startups that don't flood. Like I said, I'm sure I'm jinxed now. But if it happens, I'll call road side assistance. In the meantime, I get in my car and go, regardless of the distance or warm-up..........
And I'll offer one last anecdote. I tossed my car keys to my 17 year old nephew to simply move my car out of the driveway (it was blocking others). He came back inside and sheepishly admitted he stalled my 8 like 6 times before he could move it.......and no harm done (except to his pride)............)
Old Aug 21, 2006 | 02:23 AM
TKE's Avatar
TKE
My fc with over a 185k miles on her and the original injectors and starter only flooded once on me in the 3 years i had her. Even then the gas pedal to the floor and cranking her over a few times got her running on the first try.
Old Aug 21, 2006 | 11:18 AM
Silver_Surfer's Avatar
I4NI
Why move the vehicle?
Old Aug 21, 2006 | 11:57 AM
9291150's Avatar
Any car can flood, I have a motorcycle that will do it every time if I stall it on start up.
This just happened Friday...everyone at my job knows I'm a motorhead and asks me for car advice. A female friend bought a new 3 series sedan on my advice, and was complaining to me about it flooding.
My 8 has yet to flood, even though I often start her up just to move it. Still, mazmart might have real reasons why the 8 is more prone.
Old Aug 21, 2006 | 12:07 PM
Design1stCode2nd's Avatar
I've only had mine 2 weeks but I make sure mine won't flood by following the guidelines. I won't be taking any chances of having to have my new car towed to a dealer. In winter it might be an issue but usually just a 5 minute drive is all it need to warm up.
Skyl3r
Dec 2, 2019 04:51 PM
RXeckless
Aug 16, 2015 12:52 PM
Obivious
Jul 29, 2015 05:57 PM
harithac
Jul 25, 2015 04:21 PM
thedragonrotar
Jul 22, 2015 08:46 PM
