belkjz
08-14-2006, 03:00 PM
i sold my shifter to smome asshole in canada and hes disputing the sale thru paypal saying he only got a rock. meanwhile the shithead posts this shit on the forum:
I did the install today and everything went smoothly...i took the car for a test drive and the first time shifting through the gears with the new shifter it made a bit of a noise which just seemed to be the shifter adjusting itself.
I drove around for about an hr and then went to a movie..i came out of the movie and there was a huge puddle of some sort of oily substance, not sure what...so i took everything apart and double checked it and all seemed fine, even the shifter seems fine, its definatley coming from my car and i'm fearing its tranny fluid.
is there anything i could have done wrong???? the install went like clockwork (thanks to the gomez diy)
help me!!!!!
****************UPDATE**************************** *
Ok now things just got a whole lot worse..i took everything apart to check and see if maybe something had come loose, everything appeared to be normal so while putting it back together I was bolting the plate that holds the shifter in place and I snapped one of 3 bolts off, so its stuck halfway in there..now when im shifting theres this awful winding sound, like if anyones been rolling up to a stop go situation, push clutch in, put in first that sound it makes, like something winding up?? it sounds like that but 1000x louder, doesn't sound good at all. The shifter still works fine though, but i'm pretty concerned something is majorly wrong here...
AND
It's definatley mine..i just don't understand what could be leaking. All I did was remove the shifter housing, which consists of a few pieces of rubber and 7 bolts, pulled the old one out, put the RP shifter in, bloted the 3 blots and the plate on, tested to make sure it was in place and that was it. How could something be leaking? I think i'm gonna go take it all apart and check it again. Funny thing is the shifter still feels fine, no strange noises or anything..not even a cel
AND
BTW how does the RP shifter feel compared to stock? The stocker is already one of the best in market I believe.
It feels incredible...everyone told me it was mind blowing...but you really have to experience it. It's like a bolt action rifle.
AND
it seems to be making alot of noise now....i know others have reported it being noisy but this doesn't sound right.
the tranny makes alot of noise just spinning in neutral, but where the real problem lies is when shifting gears, while pushing through the shift gate there's alot of whining, like as if the synchros are spinning too fast or something.
best way i can describe it is if you've ever been coming to a stop sign/light at speed, pushed in clutch then put in first gear preparing to quickly stop and go you hear that noise that sounds like something spinning quickly and then the gear shifts into place...if i try that with the short shifter it sounds like its winding up but more like its going to explode.
his id is rxgr8t and if i evre fucking meet you i will fucking destroy you you stupid son of a bitch. goddamn stupid fucki8ng people
help me!!!!!
AND
AND
AND
