About to lose warranty...
I am about 5k miles away from the end of my factory warranty. Does anyone know of anything i can have the dealership do that would be covered and help me later? Im not sure if the warranty covers anything that isnt broken but i thought i would ask. thanks
ryan
ryan
just be sure all wro work has been done and all tsb's connected to your vin #have been repaired or replaced(battery,spark plugs,h.o.starter.only if you had hard starting or flooding)wish you luck and enjoy your ride!!
drop a untuned gredy turbo in it and blow youre engine then take the turbo stuff off and go to Olympia Mazda in Olympia Washington- they'll fix everything under warranty
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/i-need-stock-parts-96215/
About the only thing I can thing about is the updated Starter & 650 CCA battery. They are mentioned in the hard to start TSB. I have 70,000 miles on my 8 and I dont do anything different now than I did under warranty. My 8 always started fine so I only have the larger battery (1st gen starter). If you can get a break on the labor rate get a baseline compression check now is not a bad Idea. Should your engine start to act funny you can compare it to a time it ran fine. The other thing you should do is getting a code reader for the RX-8. Many times you can fix the problem yourself or with our help if you can read the trouble codes.
Originally Posted by wisconsinben
I'm in a similar situation...47,500 miles on her. Where is a good place to get a code reader for the 8?
get the hymee scanalyser available from one of our fine forum vendors mazda parts.com
http://www.mazdaparts.com/ProductDet...000-1151625265
http://www.performancedesign.com.au/?content=scanalyser
You can also try the scangauge2.
http://www.thinkgeek.com/gadgets/electronic/8426/
I just recently installed it in my car. It's good for instant readings of batt voltage, open/closed loop, mpg (which is very accurate btw), etc. Plus reading of CEL codes and resetting.
don't think there is a way to log the readings like the canscan yet (I hear a usb connector option will be available shortly though)
Shankapotamus3
Mar 14, 2021 03:53 PM
duworm
Oct 1, 2015 04:57 PM
