Looking for a High Output Alternator
Old Aug 10, 2006 | 09:05 PM
Boxcar's Avatar
Round round round we go
Well as the title states I'm looking for a high output alternator for my 8. I've tried google, calling around town and the forum search button but haven't had any luck. I've seen a couple crazy audio setups so someone must have found a replacement. Any help you can give me would be appreciated.
Old Aug 10, 2006 | 09:24 PM
lurch519's Avatar
www.evoperform.com
ohio generator makes em for the 8, i will be getting one once i get the rest of the amps for my setup.
http://www.ohiogen.com/
Old Aug 10, 2006 | 09:55 PM
Boxcar's Avatar
Very cool. Thank you. Are you going through them directly for your purchase or do you have another source?
Old Aug 10, 2006 | 10:10 PM
jstkilntim's Avatar
resU deretsigeR
Also check the local auto electric shops. They can usually rebuild yours for a very reasonable price.
Old Aug 10, 2006 | 10:36 PM
Boxcar's Avatar
Nice. I didn't know they could be rebuilt into anything more then they started out as. I'll look into that tomarrow. Thank you.
Old Aug 10, 2006 | 10:59 PM
lurch519's Avatar
www.evoperform.com
i will be going through them directly, as i work in a specialty car audio retailer.
even though you CAN have an alternator "rebuilt" (read rewound), it is not generally a good idea. drop the guys over at ohio generator a line, and they will fill you in. also, if i remember, the alternator from them will be approximately 180 amps hot rated.
Old Aug 11, 2006 | 11:50 PM
jstkilntim's Avatar
resU deretsigeR
Though I understand where you are coming from, I don't necessarily agree. I did take for granted that the consumer would talk to the shop and see if they were capable of the required task.
Now this is only an opinion, but if a alternator is "rebuilt" (read rewound) properly, it will have all new major components. There are only so many ways to wind copper around a core, so as long as the alternator is not so overbuilt that it can not remain cool, the major issues become the voltage regulators & recitifiers. As long as quality rectifiers & condensers are used, it should produce a nice quiet DC voltage.
One issue often overlooked is the rpm at which the voltage regulator turns on. If you do a lot of idling (say car shows etc.), the lower the better. If not, it isn't as important, especially in our lovely high revving rotories.
For full SQ competition vehicles, there probably are some advantages to some of the HO Alternator Manufacturers that cater to the Audio Market, but for most, (and without knowing prices) I would imagine this to be an expensive route.
However, I will talk to "my guy" who has rebuilt hundreds of alternators, starters etc. for us over the years and see what his thoughts are on the subject.
Peace!!
Old Aug 12, 2006 | 01:32 AM
check the vendors group buy section... there is a feeler for this item.
Old Jun 4, 2007 | 04:21 PM
Gianni's Avatar
what is the highest power system you can get without upgrading the alternator? 1000 watts? 1500watts?
In other words what is the highest power amp/amps i can use in my system?
thanks, Gianni
Old Jun 4, 2007 | 06:23 PM
lurch519's Avatar
www.evoperform.com
that depends on how long you want to play the system before having to turn it down. and how much you really care about the lights dimming.
Old Jun 4, 2007 | 06:34 PM
N rider89's Avatar
^NieL
thanks, Gianni
not even joking, thank you for searching
Old Jun 4, 2007 | 07:11 PM
mac11's Avatar
Rotary , eh?
really it depends on the efficiency of your amps and your listening preferences
Old Jun 5, 2007 | 10:47 AM
Gianni's Avatar
im looking at the ORION HCCA 10.2 subwoofer. i want to put one if them in a ported box around 1.5 cubic feet. with a Hifonics BXi2607D amp which outputs 1700 watts at 2 ohm or a Hifonics BXi 2006D which outputs 1300 at 2 ohms.
i likw to listen to it LOUD for short periods of time(a song) and then just reasonably loud the rest. Sometimes i turn it off. What do you think it the best solution?
The 1300watt amp will underpower the sub as it is rated for 1500rms. is this setup possible without a new alternator and such??
thank you
Old Jun 5, 2007 | 03:46 PM
Georgia8er's Avatar
I wonder if you could find a Ford alternator rated correctly that would work. Not sure of the mounting points, but externally the alternator looks like a late model Ford type.
How about a second battery for your amp?
Old Jun 5, 2007 | 09:55 PM
Gianni's Avatar
so your basically saying that 1300 watts is too much power for the RX8 without upgrading the charging system...so what is the highest rated amp i can get?
should i rather get a jl 10w7 which is rated at 500rms. is that LOUD enough in 1.5 cubic foot ported enclosure.
i dunno any other combination that would be louder. thanks for your help.
gianni
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
