Interesting cause cited for visor meltdown
Old Aug 10, 2006 | 05:13 PM
torbee's Avatar
So my visor woes continue - as the dealer was able to fix the electronics problems in my car, but the sun visor remains on order.
Interestingly, and as predicted by one of the posters here, the technician said the cause of the meltdown was not the excessive heat, but rather a leakage of some kind of acid inside the visor assembly that corroded it and made it break apart. That corrosion also caused the electronics problem.
The tech said the reason I have to wait so long for the visor is that quite a few of them across the country are self-destructing the way mine did - some causing electronic problems, most simply ruining the visor.
I know dealers and dealer service folks aren't always considered reliable, but this info all seemed quite plausible to me. And apparently, this Mazda tech at my dealer has a pretty good reputation from some folks I've talked to.
Old Aug 10, 2006 | 05:16 PM
Crazy Rx-8 Driver's Avatar
XYELLR8
think a future TSB might be in order for this?
what year is your car? and build date?
Old Aug 10, 2006 | 05:19 PM
zoom44's Avatar
there already is a bulletin on the visor and the part was already changed once-
Old Aug 10, 2006 | 05:38 PM
RX8Maine's Avatar
What kind of acid is in the assembly and why?
Old Aug 10, 2006 | 05:47 PM
otherside's Avatar
I dont care...
there is no acid in the assembly. I took one apart once from a customers car. The molded plastic simply comes apart from the hinge mechanism inside the visor.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
dezau
RX-8 Racing
10
Mar 9, 2016 09:50 AM
JCTaylor
Sep 30, 2015 07:31 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
GK1707
Sep 27, 2015 07:33 PM
