225/45 vs 235/40 Tyre side height?
Old Aug 8, 2006 | 05:52 AM
King105's Avatar
Hi all,
Was given 235/40 Goodyear F1 becos there isn't a 225/45.. Tyre shop says wheel overall size identical for both.. Can't figure this out. Pick ur brain, can?
45% of 225 = 94mm
40% of 235 = 101.25mm
Difference = 7.25mm x 2 = 14.5mm (for total wheel diameter). . What makes them equal? (wild thought) Thicker tyre thread? Thanks..
King105
Old Aug 8, 2006 | 05:56 AM
Spin9k's Avatar
Momentum Keeps Me Going
235s are smaller diameter, wider tread width. Makes about a 2% dif on your speedometer, no biggie. If it says 100, you're only doing ~98.
Old Aug 8, 2006 | 06:32 AM
EBS's Avatar
EBS
The 2 sizes are not identical. The diff is 2.2%. In real life, no prob living with it.
Cheers
Old Aug 8, 2006 | 01:33 PM
mkl22's Avatar
the tire shop can be right in saying they might be the the same. why so? cause not all 225/45/18 tires are the same. take for instance the RE040 and AD07. AD07 is wider than the RE040 of the same size. so it could be that it might be the same after all. maybe you should have measured the diameter of the two tires and compared.
Old Aug 8, 2006 | 04:39 PM
brothervoodoo's Avatar
RainMan is Back
Here's a good link, tire calculator has been up there for years..
http://www.miata.net/garage/tirecalc.html
Attached Thumbnails 225/45 vs 235/40 Tyre side height?-tire.jpg
Old Aug 9, 2006 | 09:51 PM
King105's Avatar
Hi all,
Indeed my suspicion.. Thanks for the advice!
King105
Jst4fun
Apr 17, 2021 07:43 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
SimonT182
Oct 2, 2015 10:33 AM
GK1707
Sep 27, 2015 07:33 PM
