I hope and pray that the RX-8 has good low-end Grunt.
Old Oct 8, 2002 | 04:12 PM
Spoonie's Avatar
163-lb ft of torque sounds a little low. Almost Honda like. I just hope that 5-6 thousand RPM shifting aren't the norm for everyday driving. As fast as the Honda S2000 is, you have to work its engine way to hard just to keep up with traffic. I just would like for the RX-8 to have the low-end torque feeling similar to the G35 or BMW 330i. I can drive all day in my 330 without having the RPMs go over 4000. The car has nice low-end torque and by the time you hit 4,000 rpm you have more than enough speed. The car feels gutsy even at low rpms. I hope that the RX-8 doesn't require high revs to have a little fun. There is nothing like effortless speed.
Old Oct 8, 2002 | 04:24 PM
snow_tires's Avatar
you have to consider the rx-8 is made to spin fast.
4000 with a 6000 redline is two thirds
4000 with a 9000 redline is not even half way up the rpm range.
Old Oct 8, 2002 | 04:27 PM
Sputnik's Avatar
Well, from what you're describing, you will probably be disappointed.
---jps
Old Oct 8, 2002 | 04:33 PM
Quick_lude's Avatar
Love to rev!
It's nice to see that trolls are religious. :p
Old Oct 8, 2002 | 04:51 PM
zoom44's Avatar
yep there is still a loooong way to go :D
Old Oct 8, 2002 | 05:25 PM
Spoonie's Avatar
Troll?
How am I a troll? Trolls don't leave their E-mail addresses.
Am I a troll because I'm complaining about the RX-8's lack of torque? Road and Track editor Sam Mitani said after driving the RX-8 that it needed more power down low. If the RX-8 is underpowered or has week torque down low, there are going to be A¡¦holes like "Quick_lube" or whatever the hell his name is calling everyone who complains about it a troll.
163lbft of torque ain't $hit. Considering that the car is going to weigh about 2900-3000lbs. If I wanted a car without Torque I would buy a Honda Prelude but that would be a big, big step down. Well, Maybe as a second car but never as my main ride.
Old Oct 8, 2002 | 05:33 PM
PatrickB's Avatar
FAQMeister
Re: Troll?
Maybe you should read what Mitani wrote again. He said the first prototype he drove had a lack of low end torque (I seem to recall this was in a renesis in a test-mule body), which he said should be corrected. The mazda engineers at the time said they were working on that. He *also* said that in his later test-drive of the pre-production model that the low-end torque was much improved, and it chirped off the line quite satisfactorily.
Old Oct 8, 2002 | 05:43 PM
zoom44's Avatar
spoonie you need to look at the power to weight ratio. and the torque curves posted in other threads on this forum. do a search they are not hard to find. and last but not least- wait until it comes out and drive one. if it odesn't have the power you are looking for don't buy one. just remember that this is a 1.3l engine with weight less than most 4 cyl engines and power better than a lot of 6cyl and a 9000 rpm redline. stop thinking about it in terms of the piston engines you are used to. and by the way the weight will be under 2900lbs.
remember- it's not the numbers it's how it feels when your behind the wheel ( or maybe that should be "when your spinning the wheels" that way it rhymes ):D
Old Oct 8, 2002 | 06:05 PM
tgd's Avatar
tgd
Spoonie I understand your concern
As much as I love my S2000, the lack of any low end pull does bother me... enough to get a 350Z or Mustang, NO.... but it is a concern.
I plan on getting the RX-8 IF the low end is better than the S2000. From what I have read it looks as though that WILL be the case..... keeping my fingers crossed!!!
Old Oct 8, 2002 | 06:41 PM
Grimace's Avatar
Certifiable car nut
Buy a 350Z. You won't like the RX-8 if you think driving the S2000 is "work" because you have to use the shifter a lot. I call it "joy".
90% of peak torque on the 8 is available from 3250 - 9000 RPM. That, my friend, is a flat torque curve. Just because the peak number "ain't ****" according to you doesn't mean the car won't move down the road. If you are going to short shift it and lug the engine, you don't want this car.
Read the FAQ.
Old Oct 8, 2002 | 07:53 PM
rpm_pwr's Avatar
Torque numbers at the engine don't tell you anything. If you like, when you get an rx-8, change the numbers on the tacho. Scribble out 2 and write 1 all the way up to 10 (write 5). So the next time you go for a drive you can brag to your passenger - "look we're only at 1500RPM and it's pulling hard"
Alternatively write the rotor speed numbers (divide by three). You'll have a 3000rpm redline but god it will idle low.
-pete
Old Oct 8, 2002 | 08:05 PM
Hercules's Avatar
Yes, you're a troll.
We already discussed gearing, weight, and the fact that this is NOT a piston engine.
Read the posts, get informed, then come back and make your comments. At least then we won't identify you as a troll right away, but our TDS (troll detection system) is at high alert for people like you.
Go get a 350Z if you want a torque monster, or a Mustang. I'll just see you in the twisties, okay?
Old Oct 8, 2002 | 08:55 PM
Rich's Avatar
Junior Member
Spoonie, welcome! I think you have a few misconceptions that we might be able to help with if you're willing to put in a little time reading some old posts. Since this has been covered in many many posts already, I'll provide the link that I think best explains some of the issues. To the other forum members, I *promise* that I won't post anything about torque on this thread other than links.
Try looking at this thread. It goes into why a torque number of 162 lb. feet means ABSOLUTELY NOTHING unless you talk about gearing.
Second, if you've never driven a rotary engine, get ready for a treat when you rev it! Rotaties get more and more smooth as the revs rise. Even a fantastic engine like in the S2000 or the Maxima V6 (the closest to the 350Z engine that I've driven) gets harsh as the revs approach redline. Rotaries are the opposite. They start smooth and turn buttery as you get to 6k and above. If you like to really drive (I don't ever shift before 5k in my non-rotary car), you'll love reving a rotary. If you want to pull tree stumps at 1k, you simply won't like the RX-8. It will have more (a lot more!) low end grunt than you think based on the 162 lb. feet of torque, but it's not going to be like the 350Z or a 330i. It should be every bit as fast (and I expect faster in the twisties) but it might take more driver involvement than those cars to get the most out of it. To me that's the pleasure of a real sports car over a GT, muscle car or sport sedan, but it's certainly not for everyone. Hopefully looking around here will help you get a feel for if the RX-8 is a car you should have on your test drive list. It's certainly not a car for everyone, but should be pure nirvana for those of us it was designed for.
I hope that helps! If it doesn't, please ask more questions (preferably after looking around a bit more) and I'll be happy to give you more details, opinions and guesses.
Old Oct 8, 2002 | 11:52 PM
R.Cade's Avatar
Rotaries are silky smooth, they run at 5k rpm smoother then a piston does at 2k rpm. You will WANT to rev it up more then you are used to doing now. I HATED having to shift my rx7 at 8k, it was just getting gooood! :P
Old Oct 9, 2002 | 01:33 AM
Sputnik's Avatar
[MODERATOR HAT ON]
Those of you accusing Spoonie of being a troll need to relax. His post was nowhere near a troll question.
[MODERATOR HAT OFF]
---jps
Old Oct 9, 2002 | 10:31 AM
tgd's Avatar
tgd
OUCH!!!
You guys are getting nasty!!!
I really think his concern/question are valid.... I have the same myself. I have never had the pleasure of owning a rotary, so I am at a disadvantage when discussing engine specs/feel etc...
I love the S2000 on the open road & twisties, but I also commute in it at least 3 days per week... bumper to bumper gets "trying".
I am encouraged by the fact that you guys have repeatedly stated that the engine actually becomes smoother at higher RPMS. Anyone that has spent any amount of time in the S2000 knows that it becomes banshee like above 5500. Great on weekend drives... not so great at 6am on your way to work!!
Really, the best advice for Spoonie (or people like me) is to wait for it to come out and test drive it.
Now, let's all play nice!!!
:D
Old Oct 9, 2002 | 01:20 PM
Spoonie's Avatar
I appreciate all of the helpful responses (you know who you are). As for the rest of you guys; it’s a shame that when someone voices a legitimate deficiency they get so defensive. What? The RX-8 is God and should be exempt from all criticism? Be a man live with it. I could have done a search, but what about fresh ideas and opinions? And besides, the car isn’t even out yet. What else is there to talk about?
Old Oct 9, 2002 | 01:50 PM
PatrickB's Avatar
FAQMeister
I agree that a number of people were overly harsh. However, you still appear to have missed the legitimate point that we've talked to death in the past the fact that the low peak engine torque number is in fact very misleading and not really a deficiency. As others have said, this is because wheel torque is what is relevant, and harping on engine torque neglects the advantages that gearing can provide if the engine has a high redline. Since you still refer this a "deficiency", I'm still not sure you understand this point. Perhaps I should add another question to the FAQ...
-Patrick
Old Oct 9, 2002 | 03:38 PM
pelucidor's Avatar
Pure Gold
I need to see this for myself BADLY. If this is true and the gear-shift is sweet then nothing will stop me from getting the RX-8.
I agree with some of what Spoonie said: no car is perfect and there will be deficiencies even with the RX-8. However if Mazda does it right then torque should not be one of them - no matter what the numbers say.
Let's bitch about the BOSE stereo instead (I'll carry a boombox in the car to replace it)...
Old Oct 9, 2002 | 03:52 PM
Grimace's Avatar
Certifiable car nut
Originally posted by pelucidor
I need to see this for myself BADLY. If this is true and the gear-shift is sweet then nothing will stop me from getting the RX-8....
Go borrow someone's Miata for a test drive. Shift feel should be very similar (Aisin manufactures the 'box for both). Haven't been in another car that feels better to shift.
Old Oct 9, 2002 | 04:01 PM
Hercules's Avatar
BMW's have great gearboxes.. I haven't driven a Miata so I can't say but I'll take your word for it
Old Oct 9, 2002 | 04:21 PM
BryanH's Avatar
2009 BS Nat'l Champ
Miatas do shift sublimely. Especially the 5spd ones.
Old Oct 9, 2002 | 04:56 PM
Quick_lude's Avatar
Love to rev!
Why? Is the 6 spd gearbox inferior to the 5spd? Just curious, since the 8 is getting a 6 speed..
Old Oct 9, 2002 | 05:19 PM
Elara's Avatar
Hercules,
There is no comparison between the BMW's shiftbox and the Miata- the difference is really unbelieveable. Until I drove a Miata, I thought that shifters were supposed to be kind of jerky- on a Miata, you can practically flick it with your finger and in it goes. It's amazing. I keep telling my husband (who thinks his BMW shifter is easy too) that he should drive the Miata, and then he'll know what great shifting is.
Old Oct 9, 2002 | 05:24 PM
Grimace's Avatar
Certifiable car nut
Some people think the 6-speed is a little more notchy than the 5-speed. Most can't tell the difference. A little Redline oil in the turret seems to be a cure nevertheless.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
