storage
Old Aug 7, 2006 | 09:37 PM
Speedtrap4's Avatar
storage
I was thinking of driving mt RX-8 through the winter but I have a truck so for the snow monthe I will sore it. Does anyone have any input on storage of vehicles....especially THIS one and it's motor.
Old Aug 7, 2006 | 10:20 PM
SayNoToPistons's Avatar
Wheels, not rims!!
change fuilds, make sure you have at least 1/2 tank of gas so water vapors wont freeze and crack your lines, put it in first gear and dont engage the ebrake or youll stretch it... I. wash and wax it and put a safe cover over it. remove the battery. put it on jack stands if you can to prevent tires from having flat spots. DO NOT START IT EVERY NOW AND THEN IF YOURE NOT GOING TO DRIVE IT AND LET IT PROPERLY WARM UP, IF YOU DO YOU WILL RISK FLOODING THE ENGINE , throw some moth ***** in the interior. stuff your intake and exhuast with a shirt or something. fill it up to ~ 3/4 full and put some Sta-Bil in the tank.... and yeah thats about it.
Old Aug 7, 2006 | 10:36 PM
most of what he said. but i would add a car cover after the wash and a battery tender jr...
start it once a month and let it warm up all the way..
Old Aug 7, 2006 | 11:24 PM
New Yorker's Avatar
Based on movies I've seen, I think you're also supposed to add cobwebs.
Old Aug 7, 2006 | 11:31 PM
Wheels, not rims!!
it will not warm up "all the way" unless its been driven. a friend tried to store his 65 Shebly stang under a car cover in a properly sealed garage and the car cover started growing mold.
Old Aug 7, 2006 | 11:37 PM
so you are going to tell me a motor will not warm all the way up without being driven??? and a dry car cover on a dry car in a garage will mold???
ok. i guess you know more than i..
Old Aug 8, 2006 | 08:26 AM
ALP22's Avatar
A bar of soap in the interior will keep the critters away, and doesn't smell nearly half as bad as mothballs. Also an alternative to jack stands is just to shove a load of pressure in the tires (50+ psi) and park on some sheets of corrugated cardboard - these will subside before the rubber in the tires does, thereby avoiding flat spots. Also if you have an alarm, do not arm it, that will drain the battery.
Old Aug 8, 2006 | 12:04 PM
Wheels, not rims!!
ok swoope. go start your car and let it sit then turn it off.. repeat every week for 4 months. then get back to me. i never say the garage was dry, i just said the doors and windows were closed properly.
Old Aug 8, 2006 | 01:20 PM
User24's Avatar
I followed the advice found on this forum, and performed a 6 month indoor store. I had a full tank of gas in it, I had instructions on how to start and move the vehicle if necessary, I told them not to perform their weekly start-up procedure, I told them to park it where it won't have to be moved. I told them not to touch the oil. I told them not to put the car on blocks.
I put a baking soda can in the center cup holder for moisture, with the lid taken off. Arm & hammer makes this baking soda that comes in a plastic can container that fits. I also had one in the trunk, as I keep moist microfiber rags there.
I did some leather cleaner and conditioner, quick detail and wax prior to storage, and during they took care of battery removal and trickle charge and maintaining tires at 32 psi.
They put 2 car covers on it. I dropped coverages except for comprehensive.
When I picked it up 6 months later, everything was just as I had left it and in working order, as if it was just yesterday that I dropped it off. The odomoter had not changed. Then I called insurance to add all coverages back. Then I turned the steering wheel all the way left and right, if I remember correctly to reset whatever it is. Then I drove it to the DIY auto hobby shop, changed the coolant, engine oil, and a few days later the transmission fluid and rear differential fluid. Already had the hand pump tool in the trunk for this purpose, screwed fine onto the RP maxgear bottles.
I don't know if they set the parking brake, but it works the same as before.
Old Aug 8, 2006 | 01:30 PM
Huey52's Avatar
Registered Zoom Zoomer
At present I drive my RX-8 five days a week and my Jeep once a week. I'll reverse the use come winter (snow free weekend providing). Simple.
Full tank of gas in Winter is always a good idea.
Old Aug 10, 2006 | 01:33 AM
Speedtrap4's Avatar
Ok....good knowledge but we have a couple discrepancies.
1= Start it once in a while or not?
2= Car cover or no car cover?
3= Blocks or no blocks? (I always keep the race car on stands when not in use, why not the RX-8?)
Old Aug 10, 2006 | 01:37 AM
car going to be stored inside or outside???
yes jackstands.. and fire the car and let it warm up...just to run some oil...
batterytender jr. a must... and yes a fuel stabilizer is good..
Old Aug 10, 2006 | 07:07 AM
Wheels, not rims!!
DO NOT start it once in a while unless youre going to drive it. no one touches te car when rx7 owners store them. you will risk flooding it. cover it if the place youre storing in is dry. put the rx8 on jack stands if you can.
Old Aug 10, 2006 | 10:20 PM
Speedtrap4's Avatar
Ok we REALLY need to settle this "starting or NO starting" situation. Does anyone have any input here? I know it's perfectly fine for normal engined but I know little about rotaty thus far so I can't say either way.
Old Aug 10, 2006 | 10:42 PM
Wheels, not rims!!
ask on rx7club and see for yourself.
Old Aug 10, 2006 | 11:08 PM
Easy_E1's Avatar
You know that if it is sitting on jack stands you can drive the car.
As long as they are GOOD jack stands.
Just don't pretend you are on a Dyno. Be gentle with it.
Might I suggest only first gear. This would circulate the trans and diff fluids.
Oh ,don't forget to open the garage door !
Old Aug 11, 2006 | 12:04 AM
User24's Avatar
I would run a search to see all the opinions and the reasons for them. I sorted out the varied opinions in my head, and I decided not to start due to condensation, and not to block since it made sense to me that the suspension is designed to support the car's weight. And also I did not add fuel stabilizer as it was only 6 months. And 6 months later it was driving as if I had just dropped it off yesterday.
I don't think you will have any problems with a 1 month indoor storage if you perform it just like I did mine.
Old Aug 11, 2006 | 01:06 AM
sorry i had this wrong, i thought the ? was about a rx8..
stupid me...
oh wait,, it was about a rx8... well i have one.. have put 52k miles on it without a flood...
last i remember you are still a 17 year old little boy that does not own a rx8.... at best you have been driving for a year...
Old Aug 11, 2006 | 01:17 AM
RX8babe's Avatar
RX8UL8TER
glad im in fl and dont have to worry about this cause i drive it all the time...
Old Aug 11, 2006 | 01:27 PM
Wheels, not rims!!
stupid me...
the renesis has the same concept as the rx7 motors. stop picking on my age. you being older doesnt nesscarily mean you know more than i do. this is a fine example of it.
to speedtrap - i suggest taking a look at rx7club, they have the experience youre looking for.
fireishot34
Sep 5, 2015 06:45 PM
Obivious
Jul 29, 2015 05:57 PM
SayNoToPistons
NE RX-8 Forum
Jul 29, 2015 03:43 PM
RXzooomer8
9
Sep 14, 2004 01:27 PM
