View Full Version : My muffler- he said "CUT IT OFF"
jbanfield
08-04-2006, 12:10 PM
Hi ,
I've been exploring options for getting a upgraded exhaust - mainly for sound.
I have a problem with spending $600 + though. I took the car my exhaust guy (who's secret garage is behind the bowling alley), and he said...."since you have the cat converter and a resonator inline you could take off the muffler and hook up the pipes direct."
He also stated that you would have to unhook your battery in order for the car computer to tune itself to the temperature & flow change.
I wanted to hear your thoughts on this "operation". I will probably go ahead an do it then post some video, unless someone knows of a big no-no.
wish me luck - Jamie
MazdaTed
08-04-2006, 01:11 PM
If you are looking to use cheap mufflers they dont really hold up to Rotary BBQ.
Personally I would just get the RB exaust. The one on my miata was well worth the $400 I spent on it.
EDIT: the common thought on the RB exaust on the RX-7 club is that the RB exaust sounds just like God Bitch slapping sombody.
zoom44
08-04-2006, 01:12 PM
its not going to throw a cel for taking the muffler off. and muffler has nothing to do with emissions themselves but it may not be legal to run without a muffler in your state. need to cxheck that out
misterwilson007
08-04-2006, 01:13 PM
i guess you owe him a pepsi :wallbash: or 1/2 of one!!
Gambit
08-04-2006, 01:15 PM
is that part about unhooking the battery to let the computer tune itself true?
MazdaTed
08-04-2006, 01:17 PM
I know little about emmissions testing (yay mid-Ga) but dont you have to have a CARB sticker or something for exaust? without that you would fail (If you would have to have the CARB sticker).
If this is true you all owe Notears a pepsi.
NoTears316
Pepsi? What are you guys talking about? :dunno:
Trekk
I think you all are way off. Looks like all he is saying is, take off the muffler and make a Y pipe out of the car. Srt-4's didnt come with mufflers, hey just had the cat and res. but the turbo did silence it abit.
I'd say go for it if he can do a nice job and Y pipe. If you dont like it and it was done well you could just unbolt it and put the stock back on or have it cut and 2 mufflers placed in later.
MazdaTed
08-04-2006, 01:18 PM
You deleted your post you cheater.
NoTears316
08-04-2006, 01:20 PM
It is still gonna cost money to fabricate that. What is the limit you are actually willing to spend on this? Exhausts aren't that freaking expensive (if you are purchasing just for sound).
416to212
"I will never understand why people like you are the first to reply to a thread. You mess with the newbies too much."
Hahaha! The above words were in reference to a guy who said a CEL will be activated by removing the muffler! His posting has been deleted - that's why this thread makes no sense at all now! LOL
BTW Jamie... Synthetic oil will void your warranty. ;)
misterwilson007
08-04-2006, 01:21 PM
very 007ish!!
NoTears316
08-04-2006, 01:24 PM
You could also just get one of these for a sound upgrade...
http://www.thegag.com/a1025.html
MazdaTed
08-04-2006, 01:28 PM
Notears the thread ruiner!
And why are you talking about synthetics in a thread about exaust?
Hightshoe
Dont you need back-pressure? Wouldnt this eliminate all back-pressure?
Dro
08-04-2006, 01:29 PM
http://www.thegag.com/a1025.htmlIm soooo getting that.
Woo Woooooooooo
thas only in da mo'nin
NoTears316
08-04-2006, 01:44 PM
Quit Hating! :bootyshak
jbanfield
08-04-2006, 02:24 PM
The muffler guy is going to charge me $140 to take off the muffler and fabricate a Y.
I asked about back pressure and he said "back pressure schmack pressure - you'll have plenty with the cat and resonator"
Trekk
08-04-2006, 03:17 PM
Sounds fine to me. Just make sure he doesnt cut the pipe, Have him make a new pipe from the from the flange back. This way you can just bolt the old system right back up if your not happy.
You could unbolt it to see what it sounds like w/o a muffler, but the exhaust is gonna exit under the car instead of behind it so thesounds will be alittle differant.
Clavius
08-04-2006, 03:53 PM
Um.. I kinda see this ending badly!! not sure why.. I just do....
Spin9k
08-04-2006, 04:20 PM
be sure and post us a sound clip, yeahear...
.... I said do you hear!!!!! :mdrmed:
MazdaTed
08-04-2006, 04:23 PM
I dont think Cats really give much backpressure, and resonators dont give much backpressure either.
for some reasonThis guy sounds like he has a mullet, and drives a trans-am.
Does he?
NoTears316
08-04-2006, 04:29 PM
Actually, he sounds like a guy that wants to make money fabricating an exhaust wether it works or not.
alnielsen
08-04-2006, 05:09 PM
I have to agree. This is going to be too loud with just the cat and resonator. Do you want to know how loud? Pull off the cat back and rev the engine. No if you also pull the cat and resonator off, that will make your ears bleed.
knight7
08-04-2006, 05:14 PM
wow this is the type of things that give a car a bad name, I. E. Hondas, Acura. rx8 makes the most beautifull sound as is why you gonna go mess up the cars name by HONDANIZING it that way.? just retarded
MazdaTed
08-04-2006, 05:40 PM
If thats the case he might as well put one of these on it.
rotarygod
08-04-2006, 05:42 PM
Back pressure is a bad thing. You never want any backpressure under any circumstances ever!!! You show me a race car with backpressure and I'll show you a loser. What you want it velocity. When people go to larger pipes they think that they reduced backpressure. What they actually reduced was exhaust velocity and velocity is necessary for scavenging. Using a pipe that is too small will kill top end power because there is backpressure up there. The pipe can't flow enough for the top end flow requirements. This logically tells people that backpressure equals low end torque. Nope. All you did was to increase low end velocity which helped down low. Backpressure varies with rpm. The lower the rpm, the smaller the pipe can be due to less air. However this small pipe is not good for higher rpms. The goal is to have zero backpressure with the smallest pipe possible. Optimally you would want a pipe to change size and length as rpms rise but we can't do that yet.
There is nothing wrong with removing the muffler. It has no other purpose than to silence. That's it. Removing it may give you 3-4 more hp but that's it. It will give you a lot more noise though. At idle and light loads it might just sound throaty but at full throttle it will probably just be unbearable. Try it but don't do it in the hopes of going faster. It's not going to help in a usable way.
Razz1
08-04-2006, 07:44 PM
Check for sound clips of a straight midpipe here on the forumn and you will see it is loud.
Easy_E1
08-04-2006, 07:57 PM
Use to run my RX-4 on the strip with uncapped headers and a turn out pipe to not burn the underside of the car up. Was at Seattle International Raceway on the line and my buddy said the guy in the tower said "Here we have one of the loudest cars out here today next to the Funny Cars." So I hope you have some earplugs when that thing hits 9000 RPM.
Not to mention the backfire blasting that will more than likely be going on during decelleration. Should wake up the neighborhood.
Have Fun.
AdRoCK3217
08-05-2006, 01:11 AM
Holy shit - is everyone in this thread a goddamn retard? (Most of you, anyways)...
He never said anything about removing the cats! Nor putting on a header!!!
The stock exhaust manifold is very thick, and much quieter then a header. Comparing them in sound levels is STUPID.
He never said he was removing the cat. Comparing a car with a stock manifold, and cats inline, with a car that is straight header, is STUPID!!
:mad:
AdRoCK3217
08-05-2006, 01:13 AM
Hmm, yeah, find a sound clip of a car with no cats, listen to it, and now you have a PERFECT idea of what your car will sound like WITH cats.
.......WTF?!
EyeBall Fixer...(o)(x)
08-05-2006, 01:37 AM
Just unbolt your muffler at the flange and pull it out. Drive it for a day or two and you'll know
if it's something you want permanently. That way you're not out anything...
Have your muffler guy fab you some tailpipes or put your old muffler back on...
Why does everything have to be so difficult around here?
Easy_E1
08-05-2006, 02:11 AM
:mad:
NO SHIT
AdRoCK3217
08-05-2006, 03:32 AM
NO SHIT
So, your response is "NO SHIT." Err, that doesn't make any sense. Your fact was false, so I countered, and you say "NO SHIT." Is that admitting defeat?
Easy_E1
08-05-2006, 11:01 AM
I was saying that you are narrow minded in your views.
AND JUST WHAT FACT WAS FALSE?
The fact that his exhaust will be VERY loud with out a muffler?
I think you missed the whole point of his thread, I was simply enlightening him to think about the noise level his exhaust will obtain.
Unlike a piston engine the Rotary is EXTREMELY LOUD.
Something you obviously know nothing about.
I am trying to give him an idea in my post that he should be aware of the decibles that he is going to get from taking the muffler off. You seem to think campareing it to open headers is just not realistic. I dont think you have ever heard a rotary with out any type of exhaust restriction such as a muffler. And how much noise is a cat going to stop?
Why dont you stop policeing the threads looking for something that YOU think is not to your specs (which seem to be very tiny) and take in the whole picture.
You are the one that is defeated... :op:
If that is the game you want to play.
AdRoCK3217
08-05-2006, 01:49 PM
Holy cow. You made a whole lot of assumptions about me, all of which were...wrong. Defeat? Hah!
I happen to have heard a rotary in all types of condition. Open exhaust manifold, Open header (dual and collected), header and presilencer, header and cat...manifold and cat..
Oh, did I mention this was all on my own car? Yeah, pwnt.
Taking JUST the mufflers off of the RX-8 does NOT make it incredibly loud. The noise compared to an open (collected) header rotary is NO WHERE NEAR THE SAME. Thats like comparing a tame monkey to a wild ape.
I'm pretty sure you just got defeated.
Have YOU ever heard an RX-8 without mufflers, but everything else stock? Hm, oh yeah, I have. You apparently haven't. DEATH COMES FOR YE!
EDIT: Just noticed the cat comment. Yes, the stock cat is actually the most quiet-ing peice of the entire exhaust system. Try starting a car peice by peice when putting on the exhaust, and you'll know that.
Easy_E1
08-05-2006, 02:20 PM
You are just amazing. I have seen inferiority complexes but man you got a problem ,,were you just abused by all the bigger kids in your life? And now you have to take the context of something and twist it around so as to make yourself look like a genius,
YOU THINK LIKE YOU KNOW IT ALL AND EVERYBODY ELSE IS JUST WRONG IN ALL THEY SAY. No one is going to look at you as a genius when it comes to the Rotary. Oh great wise and powerful Sh_t for Brains.
Plus the fact that you dont know how to READ.
The statement I was making was a comparison, not an exact duplicate as to what the sound was going to be.
So what the FU_K is your problem?
OK I will concede,,,THAT YOUR A MORON.
You got a lot of nerve calling all the people on this forum "Goddamn Retards"
Why don't you pull your head out of your ass and inhale a breath of common sense.
This is the last thing I am going to write about how STUPID you are.
I know you will come back with some sort of retort.
So in closing "go Fu_k yourself you Pusillanimous Twit !"
I will not waste my time with you any more. I have wasted enough time already.
MORON,,,,, Shesh
1stgen8
08-05-2006, 08:00 PM
D@$n...you guys are cut throat. Can't we all just get along. One thing you could try is putting a round dynomax muffler in place of the resonator then add your Y pipe.....just a thought. Hey man just let us know how things turn out.
RedSheDevil
08-05-2006, 08:16 PM
http://i12.photobucket.com/albums/a245/rsd428/Smilies/popcorn/popcorn.gif
TKE
08-05-2006, 09:47 PM
Def untrue, cat will silence some, no where near as much as stock mufflers though.
Haven't f'ed with an 8's exhaust yet. But non turbo 13B on the 7 is very loud with out mufflers. very very loud w/o cat or mufflers. Currently have no cats and the RB
"cat back" for the win. Loud but the RB sounds sexy as hell. Plus it shoots fire balls at all the pistons behind her for the win.
IMO get the RB ehaust, materials and build quality are unmatched and the sound = the sex. Worth every penny.
AdRoCK3217
08-05-2006, 10:38 PM
^^^^ Hmm...I'm gonna have to recheck this with my car.
The difference I found last time was that with the mufflers off, cat still on, the car was entirely bareable, tons quieter then most Honda's you hear running around :P. Taking off the cat, after that, made me want to commit suicide.
NoTears316
08-05-2006, 10:54 PM
Probably how you should have originally replied instead of calling everyone "goddamn retards".
Terrance26
08-05-2006, 10:58 PM
I took my exhaust can off, and now I run a straight pipe back from the cat into a Y then I put 4" tips on the end. It sounds awesome and looks good as hell. And its not as loud as everyone may think.
AdRoCK3217
08-05-2006, 10:59 PM
Err, or maybe people shouldn't respond with comparisons which make no sense at all? :\
NoTears316
08-05-2006, 11:07 PM
http://img.photobucket.com/albums/v348/BPMdotEXE/Random/O_RLY.jpg
Try reading #1 and #2...
http://www.rx8club.com/showthread.php?t=63513
knight7
08-06-2006, 01:58 AM
lol so i was probly one of the retards he mention earlier, but didnt he just compared the sound of the car to some HONDAS outthere... some people from maryland are stoopid....
