removing the front plastic grill
Old Aug 2, 2006 | 05:34 PM
nez's Avatar
nez
Ask a ninja!
i was thinking of removing the front grill just to see how it looks. how is the removal process..is it fairly simple? i want to make sure i could put it back on just in case later on.
anyone had any experience with it?
Old Aug 2, 2006 | 09:38 PM
SC-ed's Avatar
Remove the bumper, look at it from behind and you will see how simple it is. 1 minute job.
Old Aug 2, 2006 | 10:42 PM
Student Driver
One minute?
The first time you remove the front bumper, it may take a tad bit more then 60 seconds...
... unless you're using a chainsaw...
Old Aug 3, 2006 | 05:32 AM
SC-ed's Avatar
1 min after the bumper is removed. The grill only.
Old Aug 3, 2006 | 01:34 PM
NgoRX8's Avatar
bumper takes... 10-15 minutes tops if its your first time. bolts on top. fastener screws on side. screws/bolts underneath. screw bol where clear corner is. and then take it out.
Old Aug 3, 2006 | 01:38 PM
Gambit's Avatar
Screw gas mileage
^and remember to disconnect the fog lights before you take off the bumper
Old Aug 3, 2006 | 01:40 PM
NgoRX8's Avatar
ahh yes. if you have foglights, pull the bumper out a lil to reach in and unplug it or u can pull back the tray at the bottom to unplug.
Old Aug 4, 2006 | 12:10 AM
nez's Avatar
nez
Ask a ninja!
i luv u all. hugs?
Old Aug 5, 2006 | 01:36 AM
DOMINION's Avatar
I don't buy Kool-Aid
Its better the second time lol
Old Aug 5, 2006 | 01:39 AM
Student Driver
Wire snips work well...
Warrior777
Jun 24, 2019 04:47 PM
fullsmoke
Nov 24, 2015 04:09 PM
motohegg
Aug 23, 2015 08:14 AM
